Hello Ross support,
I feel like i write too much on forum those days, sorry)
I found something strange: i have string choice constraint, with 3 values - so i see them as 3 buttons. now i want to change the values - ok, i create new array, and change it with another 3 values. Until now all good. So, now i want to replace it with new constraint that include 4 values instead of 3. And nothing happened. I tried also intChoice with same result. Now i believe its not about the constraint type - its about "toggle buttons" widget. Because in "list" widget its work as expected. So, i miss something, or this is an new release bug? Unfortunately, i dont have lower DB version right now, so i cant test it on prev. version DB.
Note i running Dashboard 9.02. I just prepared an example so you can see it by yourself:
<abs contexttype="opengear" gridsize="20" id="_top">
<meta>
<params>
<param access="1" constrainttype="STRING_CHOICE" maxlength="0" name="toggle" oid="toggle" type="STRING" value="basda" widget="radio-toggle">
<constraint>asd</constraint>
<constraint>basda</constraint>
<constraint>hjk</constraint>
</param>
<param access="1" constrainttype="INT_CHOICE" name="list" oid="list" precision="0" type="INT32" value="5" widget="list">
<constraint key="0">cam1</constraint>
<constraint key="1">cam2</constraint>
<constraint key="5">cam3</constraint>
</param>
</params>
</meta>
<meta/>
<param expand="true" height="140" left="240" oid="toggle" style="style:toggleButton;" top="140" width="600"/>
<button buttontype="push" height="40" left="420" name="3 Letters" top="380" width="100">
<task tasktype="ogscript">var choices = new Array();
choices[0] = 'One';
choices[1] = 'Two';
choices[2] = 'three';
var newCon = params.createStringChoiceConstraint(choices);
params.replaceConstraint("toggle", newCon);</task>
</button>
<param expand="true" height="400" left="1420" oid="list" top="320" width="260"/>
<button buttontype="push" height="40" left="520" name="3 Numbers" top="380" width="100">
choices[0] = '12';
choices[1] = '13';
choices[2] = '14';
</button>
<label height="40" left="40" name="While changing the same amounth of values, no problem" style="txt-align:west;" top="380" width="340"/>
<label height="40" left="40" name="What happenes now? changing the amounth of values to 4" style="txt-align:west;" top="440" width="360"/>
<button buttontype="push" height="40" left="420" name="4 Letters" top="440" width="100">
choices[0] = 'One';
choices[1] = 'Two';
choices[3] = 'four';
</button>
<button buttontype="push" height="40" left="520" name="4 Numbers" top="440" width="100">
choices[0] = '12';
choices[1] = '13';
choices[2] = '14';
choices[3] = '15';
</button>
<label height="60" left="240" name="Simple string choice constrint" style="txt-align:center" top="60" width="600"/>
