I can do tab focus change with selection mapping, and using "set value" action on joystick buttons.
And i can fire internal GPI using "GPI" action on joystick button.
But i can't got them together by single button press..
UDP: Maybe, i can refer to somehow to "selector" class in device class mapping, and change the focus that way?
UDP2: If for each button of usb controller i could set 2 independ action, that would be pretty good solution, too.
Just to describe the practical need of this : lets say that you got 4 pivot cams and you control it from the pivot cam dashboard panel. The operator have monitor for that. What if i want that the button selector will also trigger router to route the selected pivot cam to the operator? So in that case, i want to trigger panel focus change in dashboard and some ogscript to trigger some router...
