  • 1.  Dashboard as a dataLinq source
    Posted 08-21-2019 12:20
    I am having an issue (probably self induced) with Dashboard data sources.
    • When I create a new Dashboard panel all the old residual data sources show up when I browse the datalinq. Is this normal?
    • I realize this is a XPression query but I find the DataLinq server not to be consistent, someimes my sources show and sometimes they dont. Is there something I should be doing to ensure consistency?
    Whit
  • 2.  RE: Dashboard as a dataLinq source
    Posted 09-12-2019 13:27
    Hi Whit
    Restarting the DataLinq server or changing the connection should clear-out any old cached data. The DataLinq information is sent as a stream so the server has no idea that some of the information has been removed from the panel - from its standpoint, the data just hasn't been changed in a while (which is normal).
    For more info, I'd recommend re-posting on the XPression side.
    James
