Apologies if this has been answered before but I can't find any posts that seem to be address my specific needs.
I'm trying to create a Custom Panel to control what Demuxed Sources an Ultrix Router will route into a 64Ch Madi output.
I've managed to extract the Sources and Destinations from the Ultrix and set them as parameters with choice constraints; with Toggle Button control.
I have 8 cameras in my system that I want to the option to route any of the Demuxed Audios to the Madi outputs. I have created 8 buttons on a Panel called CAM 1 - 8. My Aim is to create a 16 button array that will populate with relevant sources when its selected e.g click CAM 1 and it brings up 16 buttons of CAM 1 Audios 1-16 and so on.
Currently I'm having to fudge this by displaying a new parameter referencing my sources and editing the available choice constraints manually for each button, there must be an easier way?
Cheers,
Chris
