Hi Brian,
Thanks for your query.
Here is what I found for you!.
1. Dashboard 8.4.1 should work on macOS 10.14.6.
2. Where can I find software/OS/firmware/etc. version compatibility info documented?
We will not maintain any compatibility documentation. However the system requirements to run DashBoard in Mac OSX will be as below.
Apple Mac® OS X 10.8.3 (or higher) Systems (64bit) The following are the minimum requirements when installing DashBoard on a Mac® OS system: • 64-bit configuration only • Intel® processor • Minimum 2GB RAM (4GB or more recommended) • 300MB available HD space • Mac® Safari®.
We always recomend to use the latest version of DashBoard and always back up the DashBoard while installing new versions.
You can find more details on installing and backing up the data under User guide.
Let me know if you need any further details.
Regards,
Anand
