In Walkabout I see UCCI and Ultricore-CC with the same IP. When I change the IP to Ultricore-CC it change to UCCI too with same IP. What should I do? In Dashboard appear two frames: Rippa-X and Ulticore-CC.
Hi Costin,
Have you tried the 'Locate' feature in Walkabout? Does it correctly find the two frames individually?
62 Auriga DriveNepean, OntarioCanada, K2E 7W6
Phone+1 613 228-0688Emailcommunity@rossvideo.com
LoginJoinHelp/FAQEventsrossvideo.com
Terms and ConditionsPrivacy PolicyDMCA Policy
