  • 1.  Dashboard/Dak
    Posted 04-15-2020 20:39
    Following up on the Dashboard webinar this morning. Is it possible to make a dashboard panel which can be linked to "buttons" in Dak Show control?
  • 2.  RE: Dashboard/Dak
    Posted 04-21-2020 19:21
    Hi Patrick,
    Which way to do you want to go?   Do you want Show Control to trigger a button in DashBoard, or do you want Dashboard to trigger a button in Show Control?
    If it's DB -> Show Control, I'm pretty sure that the Daktronics responds to rosstalk (TCP) commands.   So you should be able to make a button that sends a rosstalk command, with a task like:
    rosstalk.sendMessage(10.1.2.3, 7788, "GPI 31");
    Where 10.1.2.3 is the IP address of the Dak, and 7788 is the port it's listening on.   I don't have show control installed here, so I can't confirm.
