  • 1.  Ultritouch dashboard configuration
    Posted 02-13-2020 22:57
    I am having trouble getting my STOP button for my directors’s timer to work. I have created the START button and it starts and resets the timer but for whatever reason the STOP button isn’t stopping the timer. Does anyone know how to configure that part of the timer?
  • 2.  RE: Ultritouch dashboard configuration
    Posted 02-14-2020 20:15
    Hi Bridget,
    A good way to do this is to use the "TimerControl" tasks. When you make your timer, give it an ID.
    1. Make a button.
    2. Click "Add" for a new task.
    3. On the leftmost column, select "Timer Control"
    4. Select your timer.
    5. Select an action. In your case, you'd want the "Stop Timer".
    Does that help? Let me know if you want any more clarification!
    Kyle
