  • 1.  Loss of input data
    Posted 04-26-2020 12:16
    Hello
    I had a problem, the data I entered suddenly disappeared.
    The data is restored to its original form
    here is the log, the error occured at 18:48. Somebody help.
    !ENTRY org.slf4j.pde 1 0 2020-04-26 18:48:32.762
    !MESSAGE Closing connection to /127.0.0.1:59434
    !ENTRY org.slf4j.pde 1 0 2020-04-26 18:48:32.801
    !MESSAGE Waiting for key connections on 2230
    !ENTRY org.slf4j.pde 1 0 2020-04-26 18:48:34.529
    !MESSAGE Creating new connection on /127.0.0.1:62030
    !ENTRY org.slf4j.pde 1 0 2020-04-26 18:48:34.855
    !MESSAGE Waiting for key connections on 7070
  • 2.  RE: Loss of input data
    Posted 04-27-2020 17:38
    Hi <x-zendesk-user data-user-name="Ding YouXing">372662251012</x-zendesk-user>
    I'm afraid we don't have enough information to assist you here. The post you have provided from the DashBoard log does not show anything unusual. Can you tell us:
    • What device or panel were you working with when you experienced an issue?
    • What happened just prior to the reset? That is, what were you doing at the time?
    • What you were modifying?
    • What was reset?
    • What was it reset to?
    If you are talking about a custom panel with an XML data source, there may be a backup of the XML data in the same folder as your current XML. It would be called [Name of your panel].bak#
    James
