  • 1.  Control Graphite Audio Faders
    Posted 08-27-2019 08:23
    Not sure wether to post this in the Graphite section or the DashBoard section.
    It is control through DashBoard however, so I feel this is more the place for it.
    So... I'm looking to control the Graphite Audio faders through DashBoard.
    So, I know I can jut open the graphite audio panel and use the edit mode and drag the channels I need over.
    That works fine! And I will do that in most cases!
    However, I've found that if I (or someone else) do a reboot, the audio levels go back down to 0 on all channels. Ok, so that aint all that bad really, as it makes sense.
    However I'm working on a DashBoard that will be used by people with little or no experience in this, and they just expect it to "work". So, what I'm looking for is to have an "initialize" button at the start, that will set the audio level to a specific value on that specific source (or several sources). It will do a whole lot more as well, but that's the main thing I'm after here anyway.
    So, is there a way to set the value on a Graphite audio fader through a button in DashBoard?
  • 2.  RE: Control Graphite Audio Faders
    Posted 08-28-2019 13:27
    Hi Aleksander,
    Each audio fader has an oid that you can hook onto and modify, So, if you drag the audio fader onto another panel and use the parameter inspector(ctrl + i) you can get the specific parameter that you want.
    The parameter inspector is similar to panelbuilder mode in its interface however it lets you look at individual parameters of a panel.
    This way you can get all the oids that you want and then create a button or any task that you want to run and set these parameters.
    for setting the values of the audio mixers I use Visual Logic since i can just add whichever device i want to modify to my basic tree
    then i just search for the name of the parameter that i want to modify
    double click it to add it to our graph.
    Then I add a number using the search area in the "Control and Apis" section
    give it a value in the graph and then link it to the parameter that you previously selected.
    This is an example of how my graph for a parameter looks like.
    This should generate the ogscript code necessary to set this parameter value when the button is pressed.
    Rinse and repeat and you should be able to get all the parameters you want initialized!
    Mohamed
  • 3.  RE: Control Graphite Audio Faders
    Posted 08-29-2019 20:27
    AAAAAHHHH!!!
    Of course, use the inspector AFTER I drag it into the panel for that matter...
    Well, that definetly helps! Thanks alot!
