  • 1.  Hover function on label in a simple grid using string array
    Posted 02-24-2020 11:22
    We are trying to highlight a label within a string array in order to drag and drop its value to another parameter.
    is there a way to change the label bg color on mouse over (mouseEnter / mouseExit) of the individual elements?
    The following is an example:
    <meta>
    <params>
    <param access="1" maxlength="0" name="Players" oid="player.oid" precision="0" type="STRING_ARRAY" widget="default">
    <value>0</value>
    <value>1</value>
    <value>2</value>
    <value>3</value>
    <value>4</value>
    <value>5</value>
    <value>6</value>
    <value>7</value>
    </param>
    </params>
    <ogscript handles="onmouseenter" oid="onMouseEnter" targetid="field.players.all.id">onMouseEnter(this);</ogscript>
    <ogscript handles="onmouseexit" oid="onMouseExit" targetid="field.players.all.id">onMouseExit(this);</ogscript>
    <api>function onMouseEnter(obj)
    ogscript.debug("On Mouse Enter: " + obj.getIndex());
    //ogscript.setStyle( ... on Element with obj.getIndex() ... );
    function onMouseExit(obj)
    ogscript.debug("On Mouse Exit: " + obj.getIndex());
    }</api>
    </meta>
    <simplegrid cols="1" height="672" left="54" rows="11" top="48" vspace="5" width="149">
    <param expand="true" height="25" id="field.players.all.id" oid="player.oid" showlabel="false" style="txt-align:center;font:bold;bg#listbg;bdr:round;" width="40"/>
    </simplegrid>
  • 2.  RE: Hover function on label in a simple grid using string array
    Posted 02-24-2020 18:45
    The only way I found to do this is to split up the parameter inside the simple grid, so that each index has it's own cell.   I then gave an id to each cell, and made the mouseevents handle all those ids.
    Here is the code:
    <meta>
    <params>
    <value>0</value>
    <value>1</value>
    <value>2</value>
    <value>3</value>
    <value>4</value>
    <value>5</value>
    <value>6</value>
    <value>7</value>
    </param>
    </params>
    <ogscript handles="onmouseenter" oid="onMouseEnter" targetid="p1,p2,p3,p4,p5,p6,p7,p8">onMouseEnter(this);</ogscript>
    <ogscript handles="onmouseexit" oid="onMouseExit" targetid="p1,p2,p3,p4,p5,p6,p7,p8">onMouseExit(this);</ogscript>
    ogscript.setStyle("p" + (obj.getIndex() + 1), "bg#ff0000" );
    ogscript.setStyle("p" + (obj.getIndex() + 1), "bg#ffffff" );
    }</api>
    </meta>
    <simplegrid cols="1" height="596" left="525" top="51" width="200">
    <param element="0" expand="true" id="p1" oid="player.oid" showlabel="false" style="txt-align:center;font:bold;bdr:round;"/>
    <param element="1" expand="true" id="p2" oid="player.oid" showlabel="false" style="txt-align:center;font:bold;bdr:round;"/>
    <param element="2" expand="true" id="p3" oid="player.oid" showlabel="false" style="txt-align:center;font:bold;bdr:round;"/>
    <param element="3" expand="true" id="p4" oid="player.oid" showlabel="false" style="txt-align:center;font:bold;bdr:round;"/>
    <param element="4" expand="true" id="p5" oid="player.oid" showlabel="false" style="txt-align:center;font:bold;bdr:round;"/>
    <param element="5" expand="true" id="p6" oid="player.oid" showlabel="false" style="txt-align:center;font:bold;bdr:round;"/>
    <param element="6" expand="true" id="p7" oid="player.oid" showlabel="false" style="txt-align:center;font:bold;bdr:round;"/>
    <param element="7" expand="true" id="p8" oid="player.oid" showlabel="false" style="txt-align:center;font:bold;bdr:round;"/>
    </simplegrid>
    But that means that any time you add/remove from your array, you have to update your simplegrid manually (perhaps with setXML).
  • 3.  RE: Hover function on label in a simple grid using string array
    Posted 03-04-2020 19:07
    I just wanted to follow-up on this one with a bit of an easier approach. If you have multiple elements with the same ID, you can actually target an individual element by using 'element_id.element_index' when calling ogscript.rename or ogscript.setStyle. Here is an updated example:
    <meta>
    <params>
    <value>0</value>
    <value>1</value>
    <value>2</value>
    <value>3</value>
    <value>4</value>
    <value>5</value>
    <value>6</value>
    <value>7</value>
    </param>
    </params>
    ogscript.setStyle('field.players.all.id.' + obj.getIndex(), 'bdr#FF0000');
    ogscript.setStyle('field.players.all.id.' + obj.getIndex(), 'bdr#000000');
    }</api>
    </meta>
    </simplegrid>
  • 4.  RE: Hover function on label in a simple grid using string array
    Posted 03-06-2020 12:50
    Thanks James, that's very helpful
