Hi Leah.
Sorry that this question was missed when we were preparing to migrate forum software.
Are you using a basic table where each column is an array parameter or are you using a structure table where each column is a sub-oid in a structure parameter and each row is an entry in the structure array?
If it is the later, you can use w.columns configuration option to list the sub-oids from the structure that you would like to display.
James
