Yes, you can. I have found doing this through Dashboard is the easiest way. Open a tab to the CC editor and start recording a new CC. Then open a tab for the Configuration settings, go to Reference, and change your frame sync accordingly. Go back to the CC editor tab and stop recording. You'll have a CC with 1 event to change the frame sync. Hope this helps!
