  • 1.  Dashboard shortcuts
    Posted 05-02-2019 09:19
    Hello
    Is it possible that DB will react to shortcut while minimized (not active window).
    Thank,
    Alex.
  • 2.  RE: Dashboard shortcuts
    Posted 05-02-2019 20:14
    Hi Alex.
    No, DashBoard will only receive keyboard input if it is the application in focus (active). We do listen to Joystick or MIDI Panel input regardless of whether or not the application - if you have a button pad that can talk to DashBoard through either its Joystick or MIDI plug-ins, it could be a potential workaround for you.
    Cheers
    James
  • 3.  RE: Dashboard shortcuts
    Posted 05-03-2019 03:22
    Ok, i got it, thanks!
