Hi @Lanthade
The RCP-ME only sends configuration information to DashBoard and does not send updates when buttons are pressed. The API available for "NK CustomPanels" is developed around sending relatively simple commands to the routers through their specialized NK protocol. In short, DashBoard has no way of directly-knowing when a button on the RCP-ME has been pressed.
Now, the NK protocol does send DashBoard status information, so it would be possible to execute script based on something like a specific crosspoint change as a result of your button press, but that's as close as you would get with this protocol.
Cheers.
James
