  • 1.  Showing Clip Remaining time in dashboard
    Posted 01-14-2020 20:27
    Hi all,
    I am building a dashboard and looking for a way to display time remaining on a clip playing off of expressions clips server on an expression dashboard. Any help will be greatly appreciated.
    Thank You!
  • 2.  RE: Showing Clip Remaining time in dashboard
    Posted 01-15-2020 14:19
    Hi Kemal,
    Thanks for your query.
    Here is what I found for you!.
    I have attached an example DashBoard Custom Panel, that can display Clip ID  and Time remaining once you connect to VDCP client successfully.
    Basic Set-ups that need to be there before you run this panel
    1. Start Xpression media control gateway(clip server to feed) in order to run clips
    2.  Configure and VDCP port number and start it
    3.  Make sure Clip Store has been set up
    4. Start clip server chanel on xpression
    5. Open clip browser to view clips
    6.  Now open up the example panel on the DashBoard
    7.  Enter the Host number. If you are running it locally then you can add as localhost
    8.  Enter the port number
    9.  Enter the valid clip name that currently exists in the clip browser
    10.  Hit button cue and play
    11.  It should display the time remaining which will matches time remaining for clip running on XPression .
    Example Panel Code (You can paste this into note pad and name it as .grid and then open it through DashBoard)
    Note: I have also highlighted the code snippet in Bold that you may interested.
    Panel Code:
    <abs contexttype="opengear" keepalive="true">
    <meta>
    <params>
    <param access="1" maxlength="0" name="Time Remaining" oid="timeremaining" stateless="true" type="STRING" value="" widget="label"/>
    <param access="1" maxlength="0" name="bvs-host" oid="bvs-host" type="STRING" value="172.16.9.112" widget="text"/>
    <param access="1" constrainttype="INT_NULL" name="bvs-channel" oid="bvs-channel" precision="0" type="INT32" value="1" widget="spinner"/>
    <param access="1" constrainttype="INT_NULL" name="bvs-port" oid="bvs-port" precision="0" type="INT32" value="9091" widget="spinner"/>
    <param access="1" maxlength="0" name="Clip Name" oid="clipname" stateless="true" type="STRING" value="" widget="label"/>
    <param access="1" maxlength="0" name="Cue ID" oid="cueid" type="STRING" value="000226_VTXHD" widget="label"/>
    </params>
    <api>var myVDCP = ogscript.createVDCPSender();
    myVDCP.setSessionKeepAlive(true);
    function updateActiveClip(success, cmd, result, exception)
    if (success &amp;&amp; result != null)
    var clipName = result.getClipID();
    params.setValue('clipname', 0, clipName);
    var currentClip = ogscript.getObject('active-clip');
    if (currentClip != clipName)
    ogscript.putObject('active-clip', clipName);
    ogscript.putObject('oldTime', result.getClipPosition());
    var time = ogscript.getTimerManager().getTimer('time-display');
    time.stopTimer(true);
    time.setStart(result.getClipDuration());
    time.setTime(result.getClipPosition());
    time.startTimer(false);
    else
    if (result.getClipPosition() != ogscript.getObject('oldTime'))
    if (!time.isRunning())
    else
    time.stopTimer(false);
    function checkCurrentClip()
    vdcp.activeClipInfo(params.getValue('bvs-host', 0), params.getValue('bvs-port', 0), params.getValue('bvs-channel', 0), updateActiveClip);
    }</api>
    </meta>
    <timer autostart="false" id="time-display" pattern="HH:mm:ss:SSS" rate="29" start="10:00:00:000" stop="00:00:00:000">
    <timertask tasktype="ogparamset">params.setValue('timeremaining', 0, event.getDisplay());</timertask>
    </timer>
    <timer id="clip-checker" pattern="HH:mm:ss:SSS" rate="100">
    <timertask tasktype="ogscript"/>
    <timertask tasktype="ogscript">checkCurrentClip();</timertask>
    </timer>
    <param expand="true" height="92" left="21" oid="timeremaining" style="style:timerLabel" top="121" width="392"/>
    <table height="185" left="416" style="bg#dark;bdr:etched;" top="27" width="324">
    <tr>
    <label colspan="1" fill="both" insets="2,2,2,2" name="Host: " rowspan="1" style="txt-align:east" weightx="1.0" weighty="1.0"/>
    <param colspan="1" expand="true" fill="both" insets="2,2,2,2" oid="bvs-host" rowspan="1" showlabel="false" weightx="1.0" weighty="1.0"/>
    </tr>
    <tr>
    <label colspan="1" fill="both" insets="2,2,2,2" name="Port: " rowspan="1" style="txt-align:east;" weightx="1.0" weighty="1.0"/>
    <param colspan="1" expand="true" fill="both" insets="2,2,2,2" oid="bvs-port" rowspan="1" showlabel="false" weightx="1.0" weighty="1.0"/>
    </tr>
    <tr>
    <label colspan="1" fill="both" insets="2,2,2,2" name="Channel: " rowspan="1" style="txt-align:east;" weightx="1.0" weighty="1.0"/>
    <param colspan="1" expand="true" fill="both" insets="2,2,2,2" oid="bvs-channel" rowspan="1" showlabel="false" weightx="1.0" weighty="1.0"/>
    </tr>
    </table>
    <param expand="true" height="92" left="20" oid="clipname" style="style:timerLabel;" top="27" width="392"/>
    <simplegrid height="76" left="20" rows="1" top="282" width="711">
    <button buttontype="push" name="Cue">
    <task tasktype="ogscript">/*
    var clipID = params.getIdentifiedConstraint('ClipListChoices').getStringOf(params.getValue(0x3, 0)); //Get the String we're showing in the button for the selected clip parameter
    ogscript.debug('CUE: ' + clipID);
    var clipID = params.getValue('cueid', 0);
    vdcp.cueClip(params.getValue('bvs-host', 0), params.getValue('bvs-port', 0), params.getValue('bvs-channel', 0), clipID, false);</task>
    </button>
    <button buttontype="push" name="Continue">
    <task tasktype="vdcp">vdcp.continuePlay(params.getValue('bvs-host', 0), params.getValue('bvs-port', 0), params.getValue('bvs-channel', 0));</task>
    </button>
    <button buttontype="push" name="Play">
    <task tasktype="vdcp">vdcp.play(params.getValue('bvs-host', 0), params.getValue('bvs-port', 0), params.getValue('bvs-channel', 0));</task>
    </button>
    <button buttontype="push" name="Pause">
    <task tasktype="vdcp">vdcp.pause(params.getValue('bvs-host', 0), params.getValue('bvs-port', 0), params.getValue('bvs-channel', 0));</task>
    </button>
    <button buttontype="push" name="Rewind">
    <task tasktype="vdcp">vdcp.rewind(params.getValue('bvs-host', 0), params.getValue('bvs-port', 0), params.getValue('bvs-channel', 0));</task>
    </button>
    <button buttontype="push" name="Fast Forward">
    <task tasktype="vdcp">vdcp.fastForward(params.getValue('bvs-host', 0), params.getValue('bvs-port', 0), params.getValue('bvs-channel', 0));</task>
    </button>
    <button buttontype="push" name="STOP">
    <task tasktype="ogscript">vdcp.stop(params.getValue('bvs-host', 0), params.getValue('bvs-port', 0), params.getValue('bvs-channel', 0));</task>
    </button>
    </simplegrid>
    <param expand="true" height="56" left="20" oid="cueid" top="217" widget="3" width="392"/>
    I hope this will help you.
    Regards,
    Anand
