  • 1.  Password Protect Grid File
    Posted 02-18-2020 12:27
    Hi All, Is there a way to password protect a grid file so a user couldn't access and edit it? Here is the example. We have many clients using the same panel layout at different locations and some of the locations have people knowledgeable enough to make changes to the panels, but we do not want to allow access to see or edit the back end. Is it possible to set a password where if you go into panel builder mode it won't allow to you see or edit the source code behind the UI? Thanks
  • 2.  RE: Password Protect Grid File
    Posted 02-18-2020 13:06
    open a .Grid file and go to editmode. Doubleclick on the grid and Edit Component <abs> select the abs map and click on the Source tab.
    change this line with the content you want to protect youre file with
    <abs contexttype="opengear" editlock="password" encrypt="SimpleEncrypt" id="_top">
    editlock=""   //is a password protect option
    encrypt="SimpleEncrypt"  //protect the gridfile to open in notepad++ to see the script its encode the text
  • 3.  RE: Password Protect Grid File
    Posted 11-23-2023 04:15
    work like superman , thank you i have been trying this for month and finally found this
    sunil Blank
    Freelancer Graphics Designer
    Freelancer
    Kathmandu Nepal
  • 4.  RE: Password Protect Grid File
    Posted 02-26-2020 01:57
    Thanks, this worked great
