The load command takes in the whole path name of the clip. If you're fetching the data from the clip_list parameter, make sure to get it from path_name, not clip_name.
It also takes an integer as the channel, so if you're passing a letter (A, B, C, etc) as the "Channel" argument, that could also be why it isn't working.
Christian
