Sure, but I will say that I was also experiencing this same problem even with the pre-built Carbonite Panel option in dashboard as well.
Here is the code:
<abs contexttype="opengear" id="_top" keepalive="false" style="" virtualheight="946" virtualwidth="1719">
<meta>
<lookup id="hosts">
<entry key="BCarbonite.color">-1145302</entry>
<entry key="BCarbonite.port">7788</entry>
<entry key="BCarbonite.host">params.getValue('BCarbonite_IPAddress', 0)</entry>
<entry key="BCarbonite.scripthost">true</entry>
<entry key="BCarbonite.devicetype">Carbonite</entry>
</lookup>
<params>
<param access="1" maxlength="0" name="BCarbonite_IPAddress" oid="BCarbonite_IPAddress" type="STRING" value="10/102.35.146" widget="0"/>
</params>
<style id="globalstyle" name="Global Style" value="bdr#FFFFFF;bdr:thick;font:bold;size:Bigger;"/>
</meta>
<widget height="545" id="xpressionbpreview" left="3" name="XPression B Preview" style="style:globalstyle;" top="2" widgetid="com.rossvideo.xpression.preview" width="901">
<config>
<params>
<param oid="preview_widget_show_channel" value="0"/>
<param oid="preview_widget_show_name" value="0"/>
</params>
</config>
</widget>
<table height="401" left="1" top="544" width="618">
<tr>
<button buttontype="push" colspan="1" fill="both" flat="true" id="up" name="UP" rowspan="1" style="style:globalstyle;size:Biggest;" weightx="1.0" weighty="1.0">
<task tasktype="rosstalk">rosstalk.sendMessage('10.102.35.147', 7788, 'UP');</task>
</button>
<button buttontype="push" colspan="1" fill="both" flat="true" id="take" name="TAKE" rowspan="1" style="style:globalstyle;size:Biggest;bg#blue;" weightx="1.0" weighty="1.0">
<task tasktype="rosstalk">rosstalk.sendMessage('10.102.35.147', 7788, 'READ');</task>
</button>
</tr>
<tr>
<button buttontype="push" colspan="1" fill="both" flat="true" id="down" name="DOWN" rowspan="1" style="style:globalstyle;size:Biggest;" weightx="1.0" weighty="1.0">
<task tasktype="rosstalk">rosstalk.sendMessage('10.102.35.147', 7788, 'DOWN');</task>
</button>
<button buttontype="push" colspan="1" fill="both" flat="true" id="clearfb1" name="CLEAR CGB1" rowspan="1" style="style:globalstyle;size:Biggest;bg#red;" weightx="1.0" weighty="1.0">
<task tasktype="rosstalk">rosstalk.sendMessage('10.102.35.147', 7788, 'CLFB 0');</task>
</button>
</tr>
</table>
<table height="400" left="619" top="544" width="285">
<tr>
<button buttontype="push" colspan="1" fill="both" flat="true" id="takenext" name="TAKE NEXT" rowspan="1" style="style:globalstyle;size:Bigger;bg#green;" weightx="1.0" weighty="1.0">
<task tasktype="rosstalk">rosstalk.sendMessage('10.102.35.147', 7788, 'NEXT');</task>
</button>
</tr>
<tr>
<button buttontype="push" colspan="1" fill="both" id="clearall" name="CLEAR ALL" rowspan="1" style="style:globalstyle;bg#7A1414;" weightx="1.0" weighty="1.0">
<task tasktype="rosstalk">rosstalk.sendMessage('10.102.35.147', 7788, 'CLRA');</task>
</button>
</tr>
</table>
<table height="144" right="3" top="132" width="813">
<tr>
<button buttontype="push" colspan="1" fill="both" flat="true" id="doubleboxmem" name="DOUBLE BOX" rowspan="1" style="style:globalstyle;" weightx="1.0" weighty="1.0">
<task tasktype="rosstalk">rosstalk.sendMessage('10.102.35.146', 7788, 'MEM 32');</task>
</button>
<button buttontype="push" colspan="1" fill="both" flat="true" id="tripleboxmem" name="TRIPLE BOX" rowspan="1" style="style:globalstyle;" weightx="1.0" weighty="1.0">
<task tasktype="rosstalk">rosstalk.sendMessage('10.102.35.146', 7788, 'MEM 33');</task>
</button>
</tr>
</table>
<table height="139" right="3" top="273" width="812">
<tr>
<button buttontype="push" colspan="1" fill="both" flat="true" id="leftfullmem" name="LEFT BOX FULL" rowspan="1" style="style:globalstyle;" weightx="1.0" weighty="1.0">
<task tasktype="rosstalk">rosstalk.sendMessage('10.102.35.146', 7788, 'MEM 31');</task>
</button>
<button buttontype="push" colspan="1" fill="both" flat="true" name="MID BOX FULL" rowspan="1" style="style:globalstyle;" weightx="1.0" weighty="1.0">
<task tasktype="rosstalk">rosstalk.sendMessage('10.102.35.146', 7788, 'MEM 36');</task>
</button>
<button buttontype="push" colspan="1" fill="both" flat="true" id="rightboxmem" name="RIGHT BOX FULL" rowspan="1" style="style:globalstyle;" weightx="1.0" weighty="1.0">
<task tasktype="rosstalk">rosstalk.sendMessage('10.102.35.146', 7788, 'MEM 34');</task>
</button>
</tr>
</table>
<label header="true" height="59" id="memoerylabels" name="ENN BOX CONTROL" right="2" style="style:globalstyle;txt-align:center;bg#darkdivider;" top="76" width="813"/>
<table height="75" right="7" top="2" width="810">
<tr>
<button buttontype="push" colspan="1" fill="both" flat="true" id="morningbugonline" name="BUG ONLINE" rowspan="1" style="style:globalstyle;bg#orange;" weightx="1.0" weighty="1.0">
<task tasktype="rosstalk">rosstalk.sendMessage('10.102.35.147', 7788, 'TAKE 9999:0:10');</task>
</button>
<button buttontype="push" colspan="1" fill="both" flat="true" id="morningbugoffline" name="BUG OFFLINE" rowspan="1" style="style:globalstyle;bg#red;" weightx="1.0" weighty="1.0">
<task tasktype="rosstalk">rosstalk.sendMessage('10.102.35.147', 7788, 'CLFB 0:10');</task>
</button>
</tr>
</table>
<button buttontype="push" flat="true" height="113" id="croppeddblbox" left="1120" name="Double Box Cropped" style="style:globalstyle;" top="462" width="385">
<task tasktype="rosstalk">rosstalk.sendMessage('10.102.35.146', 7788, 'MEM 42');</task>
</button>
