  • 1.  Freezes and slows UI on panel with large struct table
    Posted 09-16-2020 14:46
    Hello Ross support,
    I'm working on panel that works with Ross inception lineups, via MOS protocol. So, i fetching lineups, and represents them in struct table. Its works fantastic with small amount of rows, but if i go higher ( some lineups contains up to 400 rows), the UI is getting very slow, scrolling delays, etc. But, its still possible to work that way. BUT, and this is deal breaker in my project, on lineups changes, table should update (add, remove row ) and its seems like its so hard to dashboards that you see distortion movements on the table.
    * Our lineups are Hebrew based.
    I publish here example panel that i created to demonstrate the issue, maybe there is a way to solve that somehow?
    <abs contexttype="opengear" gridsize="20" style="">
    <meta>
    <params>
    <param access="1" constrainttype="STRUCT" name="ROTableTemplate" oid="ROTableTemplate" structtype="ROlist" type="STRUCT" widget="table">
    <value>
    <subparam access="1" maxlength="-1" name="VTR" suboid="video" type="STRING" value="Test" widget="default"/>
    <subparam access="1" maxlength="-1" name="אייטם" suboid="name" type="STRING" value="Test" widget="default"/>
    <subparam access="1" maxlength="-1" name="מס'" suboid="itemNumber" type="STRING" value="Test" widget="default"/>
    <subparam access="1" maxlength="-1" name="channel" suboid="channel" type="STRING" value="Test" widget="default"/>
    <subparam access="1" maxlength="-1" name="available" suboid="available" type="STRING" value="Test" widget="default"/>
    <subparam access="1" maxlength="-1" name="storyID" suboid="storyID" type="STRING" value="Test" widget="default"/>
    </value>
    </param>
    <param access="1" constrainttype="STRUCT" name="ROTableTemplate" oid="ROTable" structtype="ROlist" templateoid="ROTableTemplate" type="STRUCT_ARRAY" widget="table">
    <value>
    <subparam suboid="video" value=" "/>
    <subparam suboid="name" value="אייטם -1 "/>
    <subparam suboid="itemNumber" value="1"/>
    <subparam suboid="channel" value=" "/>
    <subparam suboid="available" value=""/>
    <subparam suboid="storyID" value="1101634"/>
    </value>
    <value>
    <subparam suboid="name" value=""/>
    <subparam suboid="itemNumber" value=""/>
    <subparam suboid="storyID" value="1102105"/>
    </value>
    <value>
    <subparam suboid="name" value="אייטם -2"/>
    <subparam suboid="itemNumber" value="2"/>
    <subparam suboid="storyID" value="1101633"/>
    </value>
    <value>
    <subparam suboid="name" value="למילוי ע&quot;י מפיק:"/>
    <subparam suboid="storyID" value="1102150"/>
    </value>
    <value>
    <subparam suboid="name" value="עורך: נוה"/>
    <subparam suboid="storyID" value="1102151"/>
    </value>
    <value>
    <subparam suboid="name" value="מפיקה: תמי "/>
    <subparam suboid="storyID" value="1102152"/>
    </value>
    <value>
    <subparam suboid="name" value="במאי: כהן "/>
    <subparam suboid="storyID" value="1102153"/>
    </value>
    <value>
    <subparam suboid="name" value="מנחים: אברי + טלי "/>
    <subparam suboid="storyID" value="1102154"/>
    </value>
    <value>
    <subparam suboid="name" value="מעברון"/>
    <subparam suboid="storyID" value="1102155"/>
    </value>
    <value>
    <subparam suboid="name" value="פתיח מנחים מוקלט"/>
    <subparam suboid="storyID" value="1102156"/>
    </value>
    <value>
    <subparam suboid="name" value="הפנייה למבזק"/>
    <subparam suboid="itemNumber" value="3"/>
    <subparam suboid="storyID" value="1102157"/>
    </value>
    <value>
    <subparam suboid="name" value="מבזק 06:15"/>
    <subparam suboid="itemNumber" value="4"/>
    <subparam suboid="storyID" value="1102158"/>
    </value>
    <value>
    <subparam suboid="name" value="חזרה ממבזק"/>
    <subparam suboid="itemNumber" value="5"/>
    <subparam suboid="storyID" value="1102159"/>
    </value>
    <value>
    <subparam suboid="storyID" value="1102160"/>
    </value>
    <value>
    <subparam suboid="name" value="פאנל פותח - אמיר בר שלום + דניאל רוט אבנרי "/>
    <subparam suboid="itemNumber" value="6"/>
    <subparam suboid="storyID" value="1102161"/>
    </value>
    <value>
    <subparam suboid="name" value="מלחמה ושלום "/>
    <subparam suboid="storyID" value="1102162"/>
    </value>
    <value>
    <subparam suboid="name" value="הסכם היסטורי "/>
    <subparam suboid="storyID" value="1102163"/>
    </value>
    <value>
    <subparam suboid="name" value="כותרת עיתונים"/>
    <subparam suboid="itemNumber" value="6.1"/>
    <subparam suboid="storyID" value="1102164"/>
    </value>
    <value>
    <subparam suboid="itemNumber" value="6.2"/>
    <subparam suboid="storyID" value="1102165"/>
    </value>
    <value>
    <subparam suboid="name" value="החתימה על ההסכם "/>
    <subparam suboid="itemNumber" value="23.1"/>
    <subparam suboid="storyID" value="1102166"/>
    </value>
    <value>
    <subparam suboid="name" value="נאום ביבי "/>
    <subparam suboid="itemNumber" value="23.2"/>
    <subparam suboid="storyID" value="1102167"/>
    </value>
    <value>
    <subparam suboid="name" value="נאום טרמפ "/>
    <subparam suboid="itemNumber" value="23.3"/>
    <subparam suboid="storyID" value="1102168"/>
    </value>
    <value>
    <subparam suboid="name" value="נאום שר החוץ האמירתי "/>
    <subparam suboid="itemNumber" value="23.4"/>
    <subparam suboid="storyID" value="1102169"/>
    </value>
    <value>
    <subparam suboid="name" value="הבית הלבן כללי מההסכם "/>
    <subparam suboid="itemNumber" value="23.5"/>
    <subparam suboid="storyID" value="1102170"/>
    </value>
    <value>
    <subparam suboid="name" value="ביבי וטראמפ בחדר הסגלגל"/>
    <subparam suboid="itemNumber" value="23.6"/>
    <subparam suboid="storyID" value="1102171"/>
    </value>
    <value>
    <subparam suboid="name" value="הר הבית "/>
    <subparam suboid="itemNumber" value="23.8"/>
    <subparam suboid="storyID" value="1102173"/>
    </value>
    <value>
    <subparam suboid="name" value="אבו מאזן "/>
    <subparam suboid="itemNumber" value="23.9"/>
    <subparam suboid="storyID" value="1102174"/>
    </value>
    <value>
    <subparam suboid="name" value="חמאס"/>
    <subparam suboid="itemNumber" value="23.10"/>
    <subparam suboid="storyID" value="1102175"/>
    </value>
    <value>
    <subparam suboid="name" value="חמד בן עיסא אאל ח'ליפה מלך בחריין"/>
    <subparam suboid="itemNumber" value="6.8"/>
    <subparam suboid="storyID" value="1102176"/>
    </value>
    <value>
    <subparam suboid="name" value="שליט אמירויות מוחמד בן זאיד אאל נהיאן"/>
    <subparam suboid="itemNumber" value="6.9"/>
    <subparam suboid="storyID" value="1102177"/>
    </value>
    <value>
    <subparam suboid="name" value="עבדאללה בן זאיד אאל נהיאן"/>
    <subparam suboid="itemNumber" value="6.10"/>
    <subparam suboid="storyID" value="1102178"/>
    </value>
    <value>
    <subparam suboid="name" value="מוחמד בן סלמאן אאל סעוד"/>
    <subparam suboid="itemNumber" value="6.11"/>
    <subparam suboid="storyID" value="1102179"/>
    </value>
    <value>
    <subparam suboid="name" value="שר החוץ איחוד האמירויות אנוואר גרגש"/>
    <subparam suboid="itemNumber" value="6.12"/>
    <subparam suboid="storyID" value="1102180"/>
    </value>
    <value>
    <subparam suboid="name" value="המשלחת הישראלית באבו דאבי"/>
    <subparam suboid="itemNumber" value="6.13"/>
    <subparam suboid="storyID" value="1102181"/>
    </value>
    <value>
    <subparam suboid="name" value="בחריין כללי "/>
    <subparam suboid="itemNumber" value="6.14"/>
    <subparam suboid="storyID" value="1102182"/>
    </value>
    <value>
    <subparam suboid="name" value="דובאי כללי"/>
    <subparam suboid="itemNumber" value="6.15"/>
    <subparam suboid="storyID" value="1102183"/>
    </value>
    <value>
    <subparam suboid="name" value="איחוד האמירויות"/>
    <subparam suboid="itemNumber" value="6.16"/>
    <subparam suboid="storyID" value="1102184"/>
    </value>
    <value>
    <subparam suboid="name" value="רחובות ריקים"/>
    <subparam suboid="itemNumber" value="6.17"/>
    <subparam suboid="storyID" value="1102185"/>
    </value>
    <value>
    <subparam suboid="name" value="אנשים ברחוב עם מסיכות"/>
    <subparam suboid="itemNumber" value="6.18"/>
    <subparam suboid="storyID" value="1102186"/>
    </value>
    <value>
    <subparam suboid="name" value="רוני גמזו"/>
    <subparam suboid="itemNumber" value="6.19"/>
    <subparam suboid="storyID" value="1102187"/>
    </value>
    <value>
    <subparam suboid="name" value="ערים חרדיות סגר"/>
    <subparam suboid="itemNumber" value="6.20"/>
    <subparam suboid="storyID" value="1102188"/>
    </value>
    <value>
    <subparam suboid="name" value="סגר בערים"/>
    <subparam suboid="itemNumber" value="6.21"/>
    <subparam suboid="storyID" value="1102189"/>
    </value>
    <value>
    <subparam suboid="name" value="עוצר בערים בארץ האדומות"/>
    <subparam suboid="itemNumber" value="6.22"/>
    <subparam suboid="storyID" value="1102190"/>
    </value>
    <value>
    <subparam suboid="name" value="סגר בערים ערביות"/>
    <subparam suboid="itemNumber" value="6.23"/>
    <subparam suboid="storyID" value="1102191"/>
    </value>
    <value>
    <subparam suboid="name" value="ביטוח לאומי "/>
    <subparam suboid="itemNumber" value="6.24"/>
    <subparam suboid="storyID" value="1102192"/>
    </value>
    <value>
    <subparam suboid="name" value="עסקים סגורים בצל הקורונה"/>
    <subparam suboid="itemNumber" value="6.25"/>
    <subparam suboid="storyID" value="1102193"/>
    </value>
    <value>
    <subparam suboid="name" value="לשכת תעסוקה "/>
    <subparam suboid="itemNumber" value="6.26"/>
    <subparam suboid="storyID" value="1102194"/>
    </value>
    <value>
    <subparam suboid="name" value="מאות חסידים תקועים בגבול בין בלארוס לאוקראינה "/>
    <subparam suboid="itemNumber" value="6.29"/>
    <subparam suboid="storyID" value="1102195"/>
    </value>
    <value>
    <subparam suboid="name" value="קורונה בצה&quot;ל "/>
    <subparam suboid="itemNumber" value="6.30"/>
    <subparam suboid="storyID" value="1102196"/>
    </value>
    <value>
    <subparam suboid="name" value="לימודים מקוונים "/>
    <subparam suboid="itemNumber" value="6.28"/>
    <subparam suboid="storyID" value="1102198"/>
    </value>
    <value>
    <subparam suboid="name" value="לומדים בקפסולות "/>
    <subparam suboid="storyID" value="1102199"/>
    </value>
    <value>
    <subparam suboid="name" value="סעודיה"/>
    <subparam suboid="storyID" value="1102200"/>
    </value>
    <value>
    <subparam suboid="name" value="מלך סעודיה"/>
    <subparam suboid="itemNumber" value="6.31"/>
    <subparam suboid="storyID" value="1102201"/>
    </value>
    <value>
    <subparam suboid="storyID" value="1102202"/>
    </value>
    <value>
    <subparam suboid="itemNumber" value="8"/>
    <subparam suboid="storyID" value="1102210"/>
    </value>
    <value>
    <subparam suboid="name" value="פרסומת 1"/>
    <subparam suboid="itemNumber" value="9"/>
    <subparam suboid="storyID" value="1102211"/>
    </value>
    <value>
    <subparam suboid="name" value="מבזק 06:45 "/>
    <subparam suboid="itemNumber" value="12"/>
    <subparam suboid="storyID" value="1102215"/>
    </value>
    <value>
    <subparam suboid="itemNumber" value="13"/>
    <subparam suboid="storyID" value="1102216"/>
    </value>
    <value>
    <subparam suboid="storyID" value="1102222"/>
    </value>
    <value>
    <subparam suboid="name" value="אלמוג בוקר"/>
    <subparam suboid="itemNumber" value="14"/>
    <subparam suboid="storyID" value="1102223"/>
    </value>
    <value>
    <subparam suboid="storyID" value="1102224"/>
    </value>
    <value>
    <subparam suboid="name" value="המשך פאנל - אמיר בר שלום + דניאל רוט אבנרי "/>
    <subparam suboid="itemNumber" value="15"/>
    <subparam suboid="storyID" value="1102225"/>
    </value>
    <value>
    <subparam suboid="storyID" value="1102226"/>
    </value>
    <value>
    <subparam suboid="name" value="הבטחות :"/>
    <subparam suboid="itemNumber" value="16"/>
    <subparam suboid="storyID" value="1102227"/>
    </value>
    <value>
    <subparam suboid="name" value="הבטחה - נזק באשדוד + הסכם שלום "/>
    <subparam suboid="itemNumber" value="7.1"/>
    <subparam suboid="storyID" value="1102228"/>
    </value>
    <value>
    <subparam suboid="name" value="הבטחה - סגר בערים "/>
    <subparam suboid="itemNumber" value="7.2"/>
    <subparam suboid="storyID" value="1102229"/>
    </value>
    <value>
    <subparam suboid="name" value="הבטחה - לירז צ'רכי "/>
    <subparam suboid="itemNumber" value="7.3"/>
    <subparam suboid="storyID" value="1102230"/>
    </value>
    <value>
    <subparam suboid="name" value="הבטחה - שירי ונוגה מהמירוץ למיליון "/>
    <subparam suboid="itemNumber" value="7.4"/>
    <subparam suboid="storyID" value="1102231"/>
    </value>
    <value>
    <subparam suboid="name" value="הבטחה - כושר"/>
    <subparam suboid="itemNumber" value="7.5"/>
    <subparam suboid="storyID" value="1102232"/>
    </value>
    <value>
    <subparam suboid="name" value="הבטחה - שעשועון "/>
    <subparam suboid="itemNumber" value="7.6"/>
    <subparam suboid="storyID" value="1102233"/>
    </value>
    <value>
    <subparam suboid="itemNumber" value="17"/>
    <subparam suboid="storyID" value="1102234"/>
    </value>
    <value>
    <subparam suboid="name" value="מבזק 07:00"/>
    <subparam suboid="itemNumber" value="18"/>
    <subparam suboid="storyID" value="1102235"/>
    </value>
    <value>
    <subparam suboid="itemNumber" value="19"/>
    <subparam suboid="storyID" value="1102236"/>
    </value>
    <value>
    <subparam suboid="storyID" value="1102237"/>
    </value>
    <value>
    <subparam suboid="name" value="פתיח + הבטחות בע&quot;פ "/>
    <subparam suboid="itemNumber" value="20"/>
    <subparam suboid="storyID" value="1102238"/>
    </value>
    <value>
    <subparam suboid="storyID" value="1102239"/>
    </value>
    <value>
    <subparam suboid="name" value="5 סיבות ליום מצויין"/>
    <subparam suboid="itemNumber" value="21"/>
    <subparam suboid="storyID" value="1102240"/>
    </value>
    <value>
    <subparam suboid="name" value="סיבה 1 - הפיתוח ששם קץ לפחד מזריקות"/>
    <subparam suboid="itemNumber" value="21.1"/>
    <subparam suboid="storyID" value="1102241"/>
    </value>
    <value>
    <subparam suboid="name" value="סיבה 2 - תכנית הכשרה לבני נוער למען קשישים וניצולי שואה"/>
    <subparam suboid="itemNumber" value="21.2"/>
    <subparam suboid="storyID" value="1102242"/>
    </value>
    <value>
    <subparam suboid="name" value="סיבה 3 - ברקע חגיגות הסכם השלום, אבו דאבי נצבעה אתמול בכחול-לבן"/>
    <subparam suboid="itemNumber" value="21.3"/>
    <subparam suboid="storyID" value="1102243"/>
    </value>
    <value>
    <subparam suboid="name" value="סיבה 4 - להציל את חיות הבר"/>
    <subparam suboid="itemNumber" value="21.4"/>
    <subparam suboid="storyID" value="1102244"/>
    </value>
    <value>
    <subparam suboid="name" value="סיבה 5 - חברת התחבורה הציבורית &quot;אפיקים&quot; יצאה במחווה לאומית ממלכתית "/>
    <subparam suboid="itemNumber" value="21.5"/>
    <subparam suboid="storyID" value="1102245"/>
    </value>
    <value>
    <subparam suboid="storyID" value="1102246"/>
    </value>
    <value>
    <subparam suboid="itemNumber" value="21.6"/>
    <subparam suboid="storyID" value="1102247"/>
    </value>
    <value>
    <subparam suboid="storyID" value="1102248"/>
    </value>
    <value>
    <subparam suboid="name" value="המכבסה שנפגעה ביירוטים - משה דרמון"/>
    <subparam suboid="itemNumber" value="22"/>
    <subparam suboid="storyID" value="1102249"/>
    </value>
    <value>
    <subparam suboid="name" value="יירוטים באשדוד"/>
    <subparam suboid="itemNumber" value="22.1"/>
    <subparam suboid="storyID" value="1102250"/>
    </value>
    <value>
    <subparam suboid="name" value="המכבסה "/>
    <subparam suboid="itemNumber" value="22.2"/>
    <subparam suboid="storyID" value="1102251"/>
    </value>
    <value>
    <subparam suboid="name" value="אחרי היירוטים "/>
    <subparam suboid="itemNumber" value="22.3"/>
    <subparam suboid="storyID" value="1102252"/>
    </value>
    <value>
    <subparam suboid="storyID" value="1102253"/>
    </value>
    <value>
    <subparam suboid="name" value="ראש המלל לשעבר על ההסכם ההיסטורי - יעקב נגל "/>
    <subparam suboid="itemNumber" value="23"/>
    <subparam suboid="storyID" value="1102254"/>
    </value>
    <value>
    <subparam suboid="storyID" value="1102255"/>
    </value>
    <value>
    <subparam suboid="storyID" value="1102256"/>
    </value>
    <value>
    <subparam suboid="storyID" value="1102257"/>
    </value>
    <value>
    <subparam suboid="storyID" value="1102258"/>
    </value>
    <value>
    <subparam suboid="storyID" value="1102259"/>
    </value>
    <value>
    <subparam suboid="storyID" value="1102260"/>
    </value>
    <value>
    <subparam suboid="name" value="האמרויות וטראמפ בחדר הסגלגל "/>
    <subparam suboid="itemNumber" value="23.7"/>
    <subparam suboid="storyID" value="1102261"/>
    </value>
    <value>
    <subparam suboid="storyID" value="1102262"/>
    </value>
    <value>
    <subparam suboid="storyID" value="1102263"/>
    </value>
    <value>
    <subparam suboid="storyID" value="1102264"/>
    </value>
    <value>
    <subparam suboid="storyID" value="1102265"/>
    </value>
    <value>
    <subparam suboid="storyID" value="1102266"/>
    </value>
    <value>
    <subparam suboid="name" value="ביבי"/>
    <subparam suboid="itemNumber" value="k.1"/>
    <subparam suboid="storyID" value="1102267"/>
    </value>
    <value>
    <subparam suboid="name" value="ליברמן"/>
    <subparam suboid="itemNumber" value="k.2"/>
    <subparam suboid="storyID" value="1102268"/>
    </value>
    <value>
    <subparam suboid="name" value="כחלון"/>
    <subparam suboid="itemNumber" value="k.3"/>
    <subparam suboid="storyID" value="1102269"/>
    </value>
    <value>
    <subparam suboid="name" value="שמולי"/>
    <subparam suboid="itemNumber" value="k.4"/>
    <subparam suboid="storyID" value="1102270"/>
    </value>
    <value>
    <subparam suboid="name" value="סתיו שפיר"/>
    <subparam suboid="itemNumber" value="k. 5"/>
    <subparam suboid="storyID" value="1102271"/>
    </value>
    <value>
    <subparam suboid="name" value="עמיר פרץ"/>
    <subparam suboid="itemNumber" value="k.6"/>
    <subparam suboid="storyID" value="1102272"/>
    </value>
    <value>
    <subparam suboid="name" value="ניצן הורוביץ"/>
    <subparam suboid="itemNumber" value="k.7"/>
    <subparam suboid="storyID" value="1102273"/>
    </value>
    <value>
    <subparam suboid="name" value="עודה איימן"/>
    <subparam suboid="itemNumber" value="k.8"/>
    <subparam suboid="storyID" value="1102274"/>
    </value>
    <value>
    <subparam suboid="name" value="איתמר בן גביר"/>
    <subparam suboid="itemNumber" value="k.9"/>
    <subparam suboid="storyID" value="1102275"/>
    </value>
    <value>
    <subparam suboid="name" value="גנץ"/>
    <subparam suboid="itemNumber" value="k.10"/>
    <subparam suboid="storyID" value="1102276"/>
    </value>
    <value>
    <subparam suboid="name" value="לפיד"/>
    <subparam suboid="itemNumber" value="k.11"/>
    <subparam suboid="storyID" value="1102277"/>
    </value>
    <value>
    <subparam suboid="name" value="אהוד ברק"/>
    <subparam suboid="itemNumber" value="k.12"/>
    <subparam suboid="storyID" value="1102278"/>
    </value>
    <value>
    <subparam suboid="name" value="בנט"/>
    <subparam suboid="itemNumber" value="k.13"/>
    <subparam suboid="storyID" value="1102279"/>
    </value>
    <value>
    <subparam suboid="name" value="איילת שקד"/>
    <subparam suboid="itemNumber" value="k.14"/>
    <subparam suboid="storyID" value="1102280"/>
    </value>
    <value>
    <subparam suboid="name" value="רפי פרץ"/>
    <subparam suboid="itemNumber" value="k.15"/>
    <subparam suboid="storyID" value="1102281"/>
    </value>
    <value>
    <subparam suboid="name" value="סמוטריץ"/>
    <subparam suboid="itemNumber" value="k.16"/>
    <subparam suboid="storyID" value="1102282"/>
    </value>
    <value>
    <subparam suboid="name" value="ליצמן"/>
    <subparam suboid="itemNumber" value="k.17"/>
    <subparam suboid="storyID" value="1102283"/>
    </value>
    <value>
    <subparam suboid="name" value="דרעי "/>
    <subparam suboid="itemNumber" value="k.18"/>
    <subparam suboid="storyID" value="1102284"/>
    </value>
    <value>
    <subparam suboid="name" value="טראמפ"/>
    <subparam suboid="itemNumber" value="k.19"/>
    <subparam suboid="storyID" value="1102285"/>
    </value>
    <value>
    <subparam suboid="name" value="טיבי"/>
    <subparam suboid="itemNumber" value="k.20"/>
    <subparam suboid="storyID" value="1102286"/>
    </value>
    <value>
    <subparam suboid="name" value="שרה נתניהו"/>
    <subparam suboid="itemNumber" value="k.21"/>
    <subparam suboid="storyID" value="1102287"/>
    </value>
    <value>
    <subparam suboid="storyID" value="1102288"/>
    </value>
    <value>
    <subparam suboid="itemNumber" value="25"/>
    <subparam suboid="storyID" value="1102289"/>
    </value>
    <value>
    <subparam suboid="storyID" value="1102290"/>
    </value>
    <value>
    <subparam suboid="name" value="הבטחה - תמונות הקופה שנמצאה"/>
    <subparam suboid="itemNumber" value="25.1"/>
    <subparam suboid="storyID" value="1102292"/>
    </value>
    <value>
    <subparam suboid="storyID" value="1102293"/>
    </value>
    <value>
    <subparam suboid="storyID" value="1102294"/>
    </value>
    <value>
    <subparam suboid="itemNumber" value="26"/>
    <subparam suboid="storyID" value="1102295"/>
    </value>
    <value>
    <subparam suboid="name" value="פרסומות 2"/>
    <subparam suboid="itemNumber" value="27"/>
    <subparam suboid="storyID" value="1102296"/>
    </value>
    <value>
    <subparam suboid="name" value="מבזק 07:30 "/>
    <subparam suboid="itemNumber" value="31"/>
    <subparam suboid="storyID" value="1102302"/>
    </value>
    <value>
    <subparam suboid="itemNumber" value="32"/>
    <subparam suboid="storyID" value="1102303"/>
    </value>
    <value>
    <subparam suboid="storyID" value="1102304"/>
    </value>
    <value>
    <subparam suboid="name" value="הצד שלהם: דיווח מדובאי בבוקר שאחרי ההסכם ההיסטורי - אלכס"/>
    <subparam suboid="itemNumber" value="33"/>
    <subparam suboid="storyID" value="1102305"/>
    </value>
    <value>
    <subparam suboid="storyID" value="1102306"/>
    </value>
    <value>
    <subparam suboid="storyID" value="1102308"/>
    </value>
    <value>
    <subparam suboid="name" value="מה מותר ואיך נחגוג את ערב החג - סנ&quot;צ רועי ולדמן "/>
    <subparam suboid="itemNumber" value="34"/>
    <subparam suboid="storyID" value="1102309"/>
    </value>
    <value>
    <subparam suboid="storyID" value="1102310"/>
    </value>
    <value>
    <subparam suboid="storyID" value="1102311"/>
    </value>
    <value>
    <subparam suboid="storyID" value="1102312"/>
    </value>
    <value>
    <subparam suboid="storyID" value="1102313"/>
    </value>
    <value>
    <subparam suboid="storyID" value="1102314"/>
    </value>
    <value>
    <subparam suboid="storyID" value="1102315"/>
    </value>
    <value>
    <subparam suboid="storyID" value="1102316"/>
    </value>
    <value>
    <subparam suboid="storyID" value="1102317"/>
    </value>
    <value>
    <subparam suboid="storyID" value="1102318"/>
    </value>
    <value>
    <subparam suboid="itemNumber" value="36"/>
    <subparam suboid="storyID" value="1102319"/>
    </value>
    <value>
    <subparam suboid="storyID" value="1102320"/>
    </value>
    <value>
    <subparam suboid="storyID" value="1102321"/>
    </value>
    <value>
    <subparam suboid="storyID" value="1102322"/>
    </value>
    <value>
    <subparam suboid="name" value="מעברון "/>
    <subparam suboid="itemNumber" value="36.1"/>
    <subparam suboid="storyID" value="1102323"/>
    </value>
    <value>
    <subparam suboid="name" value="פרסומות 3"/>
    <subparam suboid="itemNumber" value="39"/>
    <subparam suboid="storyID" value="1102324"/>
    </value>
    <value>
    <subparam suboid="name" value="להקליט פתיח + סגיר ללקט + פתיח למחר"/>
    <subparam suboid="itemNumber" value="39.1"/>
    <subparam suboid="storyID" value="1102325"/>
    </value>
    <value>
    <subparam suboid="itemNumber" value="40"/>
    <subparam suboid="storyID" value="1102326"/>
    </value>
    <value>
    <subparam suboid="storyID" value="1102327"/>
    </value>
    <value>
    <subparam suboid="name" value="הבטחה באולפן"/>
    <subparam suboid="itemNumber" value="41"/>
    <subparam suboid="storyID" value="1102328"/>
    </value>
    <value>
    <subparam suboid="storyID" value="1102329"/>
    </value>
    <value>
    <subparam suboid="name" value="בין הסכם השלום לראש השנה: אבישי בן חיים לקראת אירוע הסליחות המרגש מחר בכותל - אבישי בן חיים "/>
    <subparam suboid="itemNumber" value="35"/>
    <subparam suboid="storyID" value="1102330"/>
    </value>
    <value>
    <subparam suboid="name" value="סליחות בכותל "/>
    <subparam suboid="itemNumber" value="35.1"/>
    <subparam suboid="storyID" value="1102331"/>
    </value>
    <value>
    <subparam suboid="storyID" value="1102332"/>
    </value>
    <value>
    <subparam suboid="name" value="הפניה למבזק"/>
    <subparam suboid="itemNumber" value="42"/>
    <subparam suboid="storyID" value="1102333"/>
    </value>
    <value>
    <subparam suboid="name" value="מבזק חדשות 08:00 "/>
    <subparam suboid="itemNumber" value="43"/>
    <subparam suboid="storyID" value="1102334"/>
    </value>
    <value>
    <subparam suboid="itemNumber" value="44"/>
    <subparam suboid="storyID" value="1102335"/>
    </value>
    <value>
    <subparam suboid="storyID" value="1102336"/>
    </value>
    <value>
    <subparam suboid="storyID" value="1102337"/>
    </value>
    <value>
    <subparam suboid="name" value="איך אומרים ראש השנה בפרסית ? לירז צ'רכי "/>
    <subparam suboid="itemNumber" value="46"/>
    <subparam suboid="storyID" value="1102338"/>
    </value>
    <value>
    <subparam suboid="name" value="השיר החדש שלה -Injah"/>
    <subparam suboid="itemNumber" value="46.1"/>
    <subparam suboid="storyID" value="1102339"/>
    </value>
    <value>
    <subparam suboid="name" value="קליפ - נוזי נוזי "/>
    <subparam suboid="storyID" value="1102340"/>
    </value>
    <value>
    <subparam suboid="name" value=" מהקליפ"/>
    <subparam suboid="itemNumber" value="46.3"/>
    <subparam suboid="storyID" value="1102341"/>
    </value>
    <value>
    <subparam suboid="name" value="מתוך הקמפייין "/>
    <subparam suboid="itemNumber" value="46.4"/>
    <subparam suboid="storyID" value="1102342"/>
    </value>
    <value>
    <subparam suboid="name" value=" משפחה"/>
    <subparam suboid="itemNumber" value="46.5"/>
    <subparam suboid="storyID" value="1102343"/>
    </value>
    <value>
    <subparam suboid="storyID" value="1102345"/>
    </value>
    <value>
    <subparam suboid="name" value="שי לחג: מצאה מדף ובו כספי בת מצווה מוסלקים אלפי שקלים - והחזירה לילדה - נעמי + ורד ונויה "/>
    <subparam suboid="itemNumber" value="45"/>
    <subparam suboid="storyID" value="1102346"/>
    </value>
    <value>
    <subparam suboid="name" value="הקופה שנמצאה"/>
    <subparam suboid="itemNumber" value="45.1"/>
    <subparam suboid="storyID" value="1102347"/>
    </value>
    <value>
    <subparam suboid="name" value="המכתב"/>
    <subparam suboid="itemNumber" value="45.2"/>
    <subparam suboid="storyID" value="1102348"/>
    </value>
    <value>
    <subparam suboid="storyID" value="1102349"/>
    </value>
    <value>
    <subparam suboid="itemNumber" value="47"/>
    <subparam suboid="storyID" value="1102350"/>
    </value>
    <value>
    <subparam suboid="storyID" value="1102351"/>
    </value>
    <value>
    <subparam suboid="storyID" value="1102352"/>
    </value>
    <value>
    <subparam suboid="storyID" value="1102353"/>
    </value>
    <value>
    <subparam suboid="itemNumber" value="48"/>
    <subparam suboid="storyID" value="1102354"/>
    </value>
    <value>
    <subparam suboid="name" value="פרסומות 4"/>
    <subparam suboid="itemNumber" value="49"/>
    <subparam suboid="storyID" value="1102355"/>
    </value>
    <value>
    <subparam suboid="name" value="מבזק חדשות 8:30 "/>
    <subparam suboid="itemNumber" value="53"/>
    <subparam suboid="storyID" value="1102361"/>
    </value>
    <value>
    <subparam suboid="itemNumber" value="54"/>
    <subparam suboid="storyID" value="1102362"/>
    </value>
    <value>
    <subparam suboid="storyID" value="1102363"/>
    </value>
    <value>
    <subparam suboid="name" value="אימון- אברי+טלי+מיכל מנור"/>
    <subparam suboid="itemNumber" value="55"/>
    <subparam suboid="storyID" value="1102364"/>
    </value>
    <value>
    <subparam suboid="name" value="אימון כושר בזום"/>
    <subparam suboid="itemNumber" value="55.1"/>
    <subparam suboid="storyID" value="1102365"/>
    </value>
    <value>
    <subparam suboid="name" value="מוזיקת אימון כושר "/>
    <subparam suboid="itemNumber" value="55.2"/>
    <subparam suboid="storyID" value="1102366"/>
    </value>
    <value>
    <subparam suboid="storyID" value="1102367"/>
    </value>
    <value>
    <subparam suboid="itemNumber" value="56"/>
    <subparam suboid="storyID" value="1102368"/>
    </value>
    <value>
    <subparam suboid="storyID" value="1102369"/>
    </value>
    <value>
    <subparam suboid="storyID" value="1102370"/>
    </value>
    <value>
    <subparam suboid="name" value="הבטחה - כוורות דבש"/>
    <subparam suboid="itemNumber" value="56.1"/>
    <subparam suboid="storyID" value="1102371"/>
    </value>
    <value>
    <subparam suboid="itemNumber" value="57"/>
    <subparam suboid="storyID" value="1102372"/>
    </value>
    <value>
    <subparam suboid="name" value="פרסומות 5"/>
    <subparam suboid="itemNumber" value="58"/>
    <subparam suboid="storyID" value="1102373"/>
    </value>
    <value>
    <subparam suboid="itemNumber" value="59"/>
    <subparam suboid="storyID" value="1102374"/>
    </value>
    <value>
    <subparam suboid="storyID" value="1102375"/>
    </value>
    <value>
    <subparam suboid="name" value="מסיכות גפילטע פיש ועוד - מיכל מנור "/>
    <subparam suboid="itemNumber" value="60"/>
    <subparam suboid="storyID" value="1102376"/>
    </value>
    <value>
    <subparam suboid="storyID" value="1102377"/>
    </value>
    <value>
    <subparam suboid="itemNumber" value="61"/>
    <subparam suboid="storyID" value="1102378"/>
    </value>
    <value>
    <subparam suboid="name" value="מבזק חדשות 9:00 "/>
    <subparam suboid="itemNumber" value="62"/>
    <subparam suboid="storyID" value="1102379"/>
    </value>
    <value>
    <subparam suboid="itemNumber" value="63"/>
    <subparam suboid="storyID" value="1102380"/>
    </value>
    <value>
    <subparam suboid="storyID" value="1102381"/>
    </value>
    <value>
    <subparam suboid="itemNumber" value="64"/>
    <subparam suboid="storyID" value="1102382"/>
    </value>
    <value>
    <subparam suboid="storyID" value="1102383"/>
    </value>
    <value>
    <subparam suboid="itemNumber" value="65"/>
    <subparam suboid="storyID" value="1102384"/>
    </value>
    <value>
    <subparam suboid="name" value="פרסומות 6"/>
    <subparam suboid="itemNumber" value="66"/>
    <subparam suboid="storyID" value="1102385"/>
    </value>
    <value>
    <subparam suboid="itemNumber" value="67"/>
    <subparam suboid="storyID" value="1102386"/>
    </value>
    <value>
    <subparam suboid="storyID" value="1102387"/>
    </value>
    <value>
    <subparam suboid="name" value="שעשועון העולם הבוקר גרסת הראש בראש - שוקי ויכטר + לורה ניסים"/>
    <subparam suboid="itemNumber" value="68"/>
    <subparam suboid="storyID" value="1102388"/>
    </value>
    <value>
    <subparam suboid="storyID" value="1102389"/>
    </value>
    <value>
    <subparam suboid="name" value="1. שאלה + תשובה - היום יום הולדת 28 לניב סולטן, שהתפרסמה בשנה האחרונה כסוכנת מוסד בסדרה טהרן העונה לשם..."/>
    <subparam suboid="itemNumber" value="68.1"/>
    <subparam suboid="storyID" value="1102390"/>
    </value>
    <value>
    <subparam suboid="name" value="2. שאלה + תשובה - לכבוד ההסכם ההיסטורי שנחתם אתמול, אני רוצה להניף בחלון את דגל בחריין, איזה צבעים אצטרך?"/>
    <subparam suboid="itemNumber" value="68.2"/>
    <subparam suboid="storyID" value="1102391"/>
    </value>
    <value>
    <subparam suboid="name" value="3. שאלה + תשובה - אם ארצה לשתות עם חברי המקסיקני שוט של טקילה לכבוד יום העצמאות ה-210 של מקסיקו שחל היום, אוכל לייצר את המשקה מצמח בשם..."/>
    <subparam suboid="itemNumber" value="68.3"/>
    <subparam suboid="storyID" value="1102392"/>
    </value>
    <value>
    <subparam suboid="name" value="4. שאלה+ תשובה - אם יוליה מהמחזה &quot;רומיאו ויוליה&quot; רוצה למחוא כפיים לצוותים הרפואיים האיטלקיים בעודה עומדת על המרפסת שלה, זה יקרה בעיר הולדתה..."/>
    <subparam suboid="itemNumber" value="68.4"/>
    <subparam suboid="storyID" value="1102393"/>
    </value>
    <value>
    <subparam suboid="name" value="5. שאלה + תשובה - סשה ברון כהן, הודיע אתמול כי יחרים את אינסטגרם. את מי מהדמויות הבאות לא גילם ברון כהן?"/>
    <subparam suboid="itemNumber" value="68.5"/>
    <subparam suboid="storyID" value="1102394"/>
    </value>
    <value>
    <subparam suboid="name" value="6. שאלה + תשובה - אם גיבור המחזה אותלו רוצה לקנות לכבוד ראש השנה לאשתו חלוק מגבת, הוא ירקום עליו את שמה... "/>
    <subparam suboid="itemNumber" value="68.6"/>
    <subparam suboid="storyID" value="1102395"/>
    </value>
    <value>
    <subparam suboid="name" value="9. שאלה + תשובה - דן, בנו של יעקב אבינו, שעל שמו נקרא גוש דן, הוא בנה של..."/>
    <subparam suboid="itemNumber" value="68.9"/>
    <subparam suboid="storyID" value="1102398"/>
    </value>
    <value>
    <subparam suboid="name" value="11. שאלת שובר שיוויון - כמה מילים יש בכל חמישה חומשי התורה יחד?"/>
    <subparam suboid="itemNumber" value="68.11"/>
    <subparam suboid="storyID" value="1102400"/>
    </value>
    <value>
    <subparam suboid="storyID" value="1102401"/>
    </value>
    <value>
    <subparam suboid="name" value="המירוץ למיליון - שירי ונגה "/>
    <subparam suboid="itemNumber" value="69"/>
    <subparam suboid="storyID" value="1102402"/>
    </value>
    <value>
    <subparam suboid="name" value="המירוץ למיליון "/>
    <subparam suboid="itemNumber" value="69.1"/>
    <subparam suboid="storyID" value="1102403"/>
    </value>
    <value>
    <subparam suboid="name" value="שירי ונגה מתוך המירוץ למיליון"/>
    <subparam suboid="itemNumber" value="69.2"/>
    <subparam suboid="storyID" value="1102404"/>
    </value>
    <value>
    <subparam suboid="name" value="קטע שלהן מהמירוץ "/>
    <subparam suboid="itemNumber" value="69.3"/>
    <subparam suboid="storyID" value="1102405"/>
    </value>
    <value>
    <subparam suboid="name" value="הצצה המירוץ למיליון "/>
    <subparam suboid="itemNumber" value="69.4"/>
    <subparam suboid="storyID" value="1102406"/>
    </value>
    <value>
    <subparam suboid="storyID" value="1102407"/>
    </value>
    <value>
    <subparam suboid="name" value="מיזם דיגיטלי למציאת תפילה מקום תפילה - יקי הפשטיין "/>
    <subparam suboid="itemNumber" value="70"/>
    <subparam suboid="storyID" value="1102408"/>
    </value>
    <value>
    <subparam suboid="name" value=" מיזם מתפללים יחד"/>
    <subparam suboid="itemNumber" value="70.1"/>
    <subparam suboid="storyID" value="1102409"/>
    </value>
    <value>
    <subparam suboid="name" value="גלילת התוכנה"/>
    <subparam suboid="itemNumber" value="70.2"/>
    <subparam suboid="storyID" value="1102410"/>
    </value>
    <value>
    <subparam suboid="name" value="מתפללים בימי קורונה"/>
    <subparam suboid="itemNumber" value="70.3"/>
    <subparam suboid="storyID" value="1102411"/>
    </value>
    <value>
    <subparam suboid="storyID" value="1102412"/>
    </value>
    <value>
    <subparam suboid="name" value=" כוורות עמית"/>
    <subparam suboid="itemNumber" value="71.1"/>
    <subparam suboid="storyID" value="1102414"/>
    </value>
    <value>
    <subparam suboid="name" value=" כוורת נגה "/>
    <subparam suboid="itemNumber" value="71.2"/>
    <subparam suboid="storyID" value="1102415"/>
    </value>
    <value>
    <subparam suboid="name" value="דבש"/>
    <subparam suboid="itemNumber" value="71.3"/>
    <subparam suboid="storyID" value="1102416"/>
    </value>
    <value>
    <subparam suboid="name" value="כוורות "/>
    <subparam suboid="itemNumber" value="71.4"/>
    <subparam suboid="storyID" value="1102417"/>
    </value>
    <value>
    <subparam suboid="storyID" value="1102418"/>
    </value>
    <value>
    <subparam suboid="itemNumber" value="72"/>
    <subparam suboid="storyID" value="1102419"/>
    </value>
    <value>
    <subparam suboid="itemNumber" value="73"/>
    <subparam suboid="storyID" value="1102421"/>
    </value>
    <value>
    <subparam suboid="name" value="פרסומות 7"/>
    <subparam suboid="itemNumber" value="74"/>
    <subparam suboid="storyID" value="1102422"/>
    </value>
    <value>
    <subparam suboid="itemNumber" value="75"/>
    <subparam suboid="storyID" value="1102423"/>
    </value>
    <value>
    <subparam suboid="storyID" value="1102424"/>
    </value>
    <value>
    <subparam suboid="name" value="המשך מסיכות גפילטע פיש ועוד - מיכל מנור "/>
    <subparam suboid="storyID" value="1102425"/>
    </value>
    <value>
    <subparam suboid="storyID" value="1102426"/>
    </value>
    <value>
    <subparam suboid="name" value="מחזור כללי "/>
    <subparam suboid="itemNumber" value="76.1"/>
    <subparam suboid="storyID" value="1102428"/>
    </value>
    <value>
    <subparam suboid="name" value="בקבוקי פלסטיק בשמורות טבע ובים "/>
    <subparam suboid="itemNumber" value="76.2"/>
    <subparam suboid="storyID" value="1102429"/>
    </value>
    <value>
    <subparam suboid="storyID" value="1102430"/>
    </value>
    <value>
    <subparam suboid="name" value="מנחי פותחים- אלעד ונועה"/>
    <subparam suboid="itemNumber" value="77"/>
    <subparam suboid="storyID" value="1102431"/>
    </value>
    <value>
    <subparam suboid="storyID" value="1102432"/>
    </value>
    <value>
    <subparam suboid="name" value="פרידה ורולר"/>
    <subparam suboid="itemNumber" value="78"/>
    <subparam suboid="storyID" value="1102433"/>
    </value>
    <value>
    <subparam suboid="name" value="אייטם 3"/>
    <subparam suboid="storyID" value="1101632"/>
    </value>
    <value>
    <subparam suboid="itemNumber" value=" "/>
    <subparam suboid="storyID" value=""/>
    </value>
    <value>
    </value>
    <value>
    </value>
    <value>
    </value>
    <value>
    </value>
    </param>
    <param access="1" constrainttype="INT_NULL" name="selected" oid="selected" precision="0" type="INT16" value="252" widget="default"/>
    </params>
    </meta>
    <param expand="true" height="40" left="340" oid="1" top="340" width="160"/>
    <param evenstyle="f:txt-align:east;f:size:Big;t:txt-align:east;t:size:Big;" expand="true" height="720" left="20" oddstyle="f:txt-align:east;f:size:Big;t:txt-align:east;t:size:Big;" oid="ROTable" showlabel="false" style="txt-align:east;f:txt-align:east;t:txt-align:east;" top="20" width="1020">
    <config key="w.selectionparam">selected</config>
    <config key="w.cellediting">false</config>
    <config key="w.columns">video,name,itemNumber</config>
    <config key="w.columnlock">true</config>
    <config key="w.colwidth.2">35</config>
    </param>
    <button buttontype="push" height="80" left="360" name="Add row " top="760" width="140">
    <task tasktype="ogscript">var structCount = params.getElementCount('ROTable');
    ogscript.debug(structCount);
    if (structCount == 1 &amp;&amp; params.getValue('raceList.0.name', 0) == "") // If this is the first element and it has not been set yet
    structCount = 0;
    var newValue = {
    "channel": " ",
    "available": "" ,
    "video": " ",
    "name": "" ,
    "itemNumber": " ",
    "storyID": ""
    params.setValue('ROTable', structCount, newValue);</task>
    </button>
    <button buttontype="push" height="80" left="520" name="Delete selected" top="760" width="140">
    <task tasktype="ogscript">var x = params.getValue('selected', 0);
    params.getParam('ROTable', x).remove();</task>
    </button>
  • 2.  RE: Freezes and slows UI on panel with large struct table
    Posted 09-16-2020 15:27
    Hi Alex,
    I just copied and pasted your panel into a DB panel here.   I have a couple questions and comments:
    1. I see a bit of slowdown when scrolling, but it's not horrible on my computer.   What version of DB are you using, and how much memory does your computer have?    I have a fairly performant computer with lots of memory.
    2. When I was scrolling the table, it looked as if it was resizing the rows on the fly.   I added a w.rowheight config option, set to 40, and the scrolling seems smoother to me.  I'm wondering if without that option, it's trying to calculate the rowheights as you scroll.   Try adding that option.
    3. There is a 64-bit version of DashBoard that allows you to use more of your system memory, you could try that as well.
    If those things don't work, then are you open to other options?   Instead of cramming all the information in one large table, you could use an API table, and only show 20-30 items at a time, with page buttons on the bottom.   Let me know if that would be acceptable, and I'll see if I can whip up an example for you.
  • 3.  RE: Freezes and slows UI on panel with large struct table
    Posted 09-16-2020 19:49
    Hi Ben , thanks for quick answer
    1. I run it on DB 9.1.2 , 64 bit. And the pc have enough resources (i7, 16 G RAM) .
    2. With w.rowheight its looks much more better - and if there is no other option i will work with that.
    3. 64 bit version. Just downloaded and installer fresh copy at home.
    So, after an little investigation, i'm pretty sure that's Hebrew language character issue. What i did: just created 2 buttons: one replaces all the rows with English text, the other one is the same but with Hebrew analogue.
    English:
    var newValue,i;
    for(i=0;i<structCount;i++){
    ogscript.debug('count is :' + i);
    newValue = {
    "channel": " ",
    "available": "" ,
    "video": 'text',
    "name": "some text in english" ,
    "itemNumber": '0'+i,
    "storyID": ""
    params.setValue('ROTable', i, newValue);
    Hebrew:
    var newValue,i;
    newValue = {
    "channel": " ",
    "available": "" ,
    "video": 'טקסט',
    "name": "טקסט כלשהו בעיברית" ,
    "storyID": ""
    Conclusion: It's run perfect with English, and bad with Hebrew.
    I also tried to change windows non-Unicode language to Hebrew - didn't helped.
  • 4.  RE: Freezes and slows UI on panel with large struct table
    Posted 09-16-2020 20:11
    I took the code and added both buttons to my panel.  I can confim that it seems to scroll slightly better on the English version compared to the Hebrew version.   I'm not sure why that is.   I'll see if I can find anything.
  • 5.  RE: Freezes and slows UI on panel with large struct table
    Posted 09-16-2020 20:22
    You also have a lot of repetitive style information for that parameter table:
    The evenstyle, oddstyle and style are all the same.  The true and false states are also the same.
    You could just have style="txt-align:east;size:Big" and get rid of the evenstyle and oddstyle completely.
    That may help a bit too.
  • 6.  RE: Freezes and slows UI on panel with large struct table
    Posted 09-16-2020 20:36
    Thats because you have different styles for odd and even rows, and also for selected and unselected row. Of course if it can be set by single defenition, its preffered.
    I'll check it tomorrow, thanks, Ben.
  • 7.  RE: Freezes and slows UI on panel with large struct table
    Posted 09-16-2020 20:42
    I understand why the different styles are there, you just seem to have them all set to the same value (txt-align:east, size:Big).
  • 8.  RE: Freezes and slows UI on panel with large struct table
    Posted 09-16-2020 20:52
    Yes, i set them all to same value, correct. Because hebrew text starts from rigth to left, and default dashboard is left to rigth. So, i wanted that in all cases it will get east align.
    Ill will fix it tommorow with
  • 9.  RE: Freezes and slows UI on panel with large struct table
    Posted 09-17-2020 09:57
    OK, i fixed the repetitive style data.
    Still, as you saw, there is Unicode encoding issue. When you work with that as live and dynamic lineup, that also react to lineup changes (rebuilds, changing cell values etc) it's becomes real liability.
    And DB is fantastic product!
    So, i believe you and other develop Ross team will find whats wrong there, and fix it in future releases.
