  • 1.  Dashboard import connections
    Posted 12-04-2020 17:12
    Hi, I've got a dashboard running on a pc with several ACID Cameras connected. Is there a way to save these connections to a file and import it to a second pc? I saw the "save to file" when i right click to the connection tree, but can't find how to load it in the new dashboard.. Any help?
  • 2.  RE: Dashboard import connections
    Posted 12-04-2020 18:22
    Hi Gabriele,
    You can do this by copying over the connections.xml file from your current PC to your new PC. The file can be found in the DashBoard install directory in the following subfolder:
    \workspace\.metadata\.plugins\com.rossvideo.rice.dashboardsuite\users\default\connections
    Hope that helps!
