  • 1.  PivotCam commands for joystick buttons
    Posted 02-24-2021 02:39
    Hi all,
    I was finally able to get joystick control up and running with my pivot cams last night.  I have a bunch of buttons on the joystick I would like to invoke for things like iris up / down, focus near/far, etc... but the list of available commands in the PivotCam manual seems horribly short and incomplete - especially since they give you a ton of available button programming lines in the dashboard panel to work with.
    I'm wondering if anyone knows where there's a full list of available commands that can be programmed into a joystick.
    Thanks.
  • 2.  RE: PivotCam commands for joystick buttons
    Posted 03-10-2021 17:23
    If you look in the User Manual for PTZ Camera Control Plugin (https://documentation.rossvideo.com/files/Manuals/Cameras/PivotCam/User_Manual_for_PTZ_Camera_Control_Plugin_(8351DR-015).pdf) on pages 74 & 75, there is a list of most of the commonly used camera functions that you might want to access from your joystick buttons, including the correct mode and values to set in the DashBoard Game Controller configuration panel.
    You mention focus near/far which is not on the list in the manual.  Focus is a velocity-based control, but you could set up two buttons to adjust focus at a fixed velocity by setting.  These would have the effect of continuing to adjust focus for as long as you held the button down.  You can do the same thing with ptzjoystick.vel.zoom for zoom.
    - Mapped OID: ptzjoystick.vel.focus
    - Action: Stateless
    - Value: - your desired velocity (in range 1 to 7).  Set one button with a positive value and the second button with a negative value.
    Here is a screenshot of focus set up on my DashBoard
