  • 1.  Permanently hide collumns from table - but keep data
    Posted 02-02-2021 17:48
    Hi guys!
    So, I'm using struct tables to organize a lot of my different player information and data etc. in my DashBoard. And while the main table now holds about 18 different columns of data, it would be nice to be able to use a smaller version of this table elsewhere in the DashBoard.
    Now, I know I can easily place this table again somewhere else, and have the exact same data be shown. I can also click the top-right corner of the table to select what columns are shown. As long as I don't close that DashBoard again...
    If I close the DashBoard, and reopen it again, both instances of the table with then show all the columns again.
    I'm looking for a way to use the same table of data, but limit the view of the columns in one place, while seeing all columns in another. And KEEP that view when the panel closes/reopens. Is this doable?
  • 2.  RE: Permanently hide collumns from table - but keep data
    Posted 02-03-2021 00:40
    Hi Alexander,
    The follow config option should work for you:
    This can be applied per table, so you can customize you tables, even if all of them linked to same struct parameter.
    Also, Ross support has released brilliant examples pack, working example can be found there (Parameter Widgets\tables.grid)
    https://support.rossvideo.com/hc/en-us/community/posts/360065970252-Free-DashBoard-Example-Panels-for-Everyone
  • 3.  RE: Permanently hide collumns from table - but keep data
    Posted 02-03-2021 12:48
    Ohhh come on!! I thought I had looked through all the extra config options for a table, and there is it...
    Two rows below, a single config for struct tables only...
    Thanks. Though I feel I should've seen that one myself... Heh...
  • 4.  RE: Permanently hide collumns from table - but keep data
    Posted 02-03-2021 13:54
    Ok! Follow up then from simple testing here.
    I set up two, and it works, perfect!
    I turned on the w.reorder to true, to move rows up and down, and sure enough, they update on both tables.
    However, turns out I can only move rows up? I cant move a row down?
