  • 1.  Christie Projector Control
    Posted 12-07-2020 16:48
    We are looking to control our projectors via Dashboard. They are Christie HD14KM. All we really want to do is power on and off from our control room. I asked Christie and all the could tell me was "we can't comment on control from a 3rd party" and sent me the technical reference for RS232 commands. Is it possible to control these directly from dashboard using TCP/UDP controls? Or am I stuck having to convert to RS232?
    Has anyone ever done something like this?
  • 2.  RE: Christie Projector Control
    Posted 12-07-2020 17:26
    Hi Chance
    It would be up to Christie to tell you what their control protocols are. If they give you one that is accessible via TCP/IP, UDP, or REST you will find it a little easier since you can speak those directly from within DashBoard.  If you only have access to RS232, your best bet is to use either a hardware appliance (like a Moxa Box) or a piece of software to expose the serial port to DashBoard as either TCP/IP or UDP port - you would then just send the bytes for the serial messages over that network port.
    Cheers
    James
  • 3.  RE: Christie Projector Control
    Posted 12-07-2020 18:12
    Hello Chance,
                           I haven't done it with Dashboard but you could try those commands on TCP Port 3002:
    (PWR 1)$0D to power on and (PWR 0)$0D to power off.
    It's working just fine with other software to send those command so I'm confident this could also work with Dashboard.
    Thank
