Howdy Mark,
Definitely love the idea here but you are probably going to have a bit of a hard time due to how this is being handled on the Carbonite side. I did a bit of a deep dive into this and came back with it would be much easier for you to simply remake the switcher buttons for MEP/P from the ground up using some pretty intense custom code.
definitions:
Destination Buttons - the group of buttons that manage ME/ MME key ext
Switcher Buttons - the group of buttons that manage what sources go to the ME PRV and PGM
Key Buttons - what key is selected at any given time
From what I can tell, the workflow currently displayed is:
Switcher button [sets param on carbonite to 1. change input label for destination (prv, pgm, BG) 2. Changes the button color ] -> key Button [defines what key is to be affected by the switcher button selection] -> destination button [1. defines what color set the switcher & key buttons are based on selected destination 2. Sets the destination for switcher and key buttons]
With all of this in mind, it would honestly be easier to build out your own whole code that compiles a string in the same order of switcher button to key to take instead of copying one over from the Carbonite panel.
This is a good place to start. http://help.rossvideo.com/carbonite-device/Topics/Protocol/RossTalk/CNT/RT-CNT-Comm.html
Good luck and hope you can get something working for your client.
Best,
Brandon
