1. I'm not sure what ableton is. Can you provide a link? Is it hardware or software?
2. Do you mean you want to make a multiviewer in DashBoard? DB does have timers, and we could set them up so that as soon as a switcher's bus is changed, the timer resets and starts to count up. But that is not inside a multiviewer. Can you clarify how you would use a DashBoard Panel in this scenario?
