  • 1.  Take crosspoint
    Posted 01-21-2021 19:30
    I'm creating an custom panel to be applied on UltricoreBCS 2RU, which will works as a take crosspoint button. For example, If I select the button called "Src 1", my video source 1 will be directed to my destination 2. The same will happens with my all other sources buttons.
    When I was using the ultrix, I could create a parameter (source) -> then add an task for it -> add my ultrix on devices tree -> and finally open the API folder and choose the operation take crosspoint. It was so easy.
    How Can I do it using the ultricoreBCS? Because when I added it on device tree, the API folder doesn't appears to me.
  • 2.  RE: Take crosspoint
    Posted 01-26-2021 14:45
    I've not worked with an Ultricore before.   I don't think they have an API for visual logic.
    Probably the easiest way is to send a RossTalk command to the Ultricore.   I assume they respond to RossTalk the same way an Ultrix responds.
    See this document for the list of Ultrix commands:  http://help.rossvideo.com/acuity-device/Topics/Protocol/External/UT/RT-UT-Comm.html#topic.rosstalk-ultrix
    If that does not work for you, let us know and we can dig further.
