  • 1.  Panel with slider audio control
    Posted 08-27-2020 14:58
    Hello
    I've been wanting to create a panel where I can put a slider audio button for each video source and a audio feed that controls the levels of dB of each video. I'm not quite sure how to do that. I'm working with Ultrix.
  • 2.  RE: Panel with slider audio control
    Posted 08-27-2020 20:12
    I don't know a lot about Ultrix.   Are those audio levels displayed anywhere in the Ultrix panels?
    If so, can you point them out to me?
    You could drag and drop those parameters onto your panel, or you can go into inspector mode in DashBoard (Ctrl-I) and see which parameters they use.
    Once I know more about which parameters they are, I can advise you better as to how to integrate them into a custom panel.
  • 3.  RE: Panel with slider audio control
    Posted 09-25-2020 18:20
    Hey Ben! Sorry for the late reply
    So what I'm trying to do is bring 2 of the 16 audio channels to the panel so I can look at the audio slider and change it if needed. It's supposed to be with the video source, on the screen.
    I need to get the audio sources out of here but the drag and drop doesn't work. When I drop on my panel it disappear and the only way I can see is if I change some parameters, but it will only show one channel, and as I said earlier I've been trying to get two channels.
    Thank you for your time.
