  • 1.  Multiple selection on struct table items
    Posted 09-07-2020 20:56
    Hello Ross support, I know how to make an selection on table, but wonder if it is possible to perform multiple selections, and get all selected indexes. Pretty sure i saw something like this in ultrix UI, on 'create new panel', when you choose sources, destinations,and levels. Thanks for help! Alex.
  • 2.  RE: Multiple selection on struct table items
    Posted 09-08-2020 13:36
    Hi Alex
    If you are using a parameter to store the selection (the w.selectionparam config property), you will get multi-select if that parameter is an INT16_ARRAY or INT32_ARRAY as opposed to simply INT16 or INT32. There will be one element in the array for each selected row.
    Cheers
    James
  • 3.  RE: Multiple selection on struct table items
    Posted 09-08-2020 14:16
    Hello James,
    Thanks! After change my selection parameter from INT16 to INT16_ARRAY it's started to work just as i wanted.
    Other question, is there any chance to script thumbnails or icons insertion in specific cell in the table?
  • 4.  RE: Multiple selection on struct table items
    Posted 09-09-2020 14:21
  • 5.  RE: Multiple selection on struct table items
    Posted 09-09-2020 14:43
    Something like this:
    Here is the panel:
    <meta>
    <params>
    <param access="1" maxlength="0" name="Column 1" oid="params.c1" precision="0" type="STRING_ARRAY" widget="default">
    <value>&lt;style:fg#000000;i-u:file.gif;&gt;</value>
    <value>&lt;style:fg#000000;i-u:folder-closed.gif;&gt;</value>
    <value>myText &lt;style:fg#000000;i-u:file.gif;&gt;</value>
    </param>
    <param access="1" maxlength="0" name="Column 2" oid="params.c2" precision="0" type="STRING_ARRAY" widget="default">
    <value>a2</value>
    <value>b2</value>
    <value>c2</value>
    <value>d2</value>
    <value>e2</value>
    <value>f2</value>
    <value>g2</value>
    <value>h2</value>
    <value>i2</value>
    <value>j2</value>
    <value>k2</value>
    <value>l2</value>
    </param>
    <param access="1" maxlength="0" name="Column 3" oid="params.c3" precision="0" type="STRING_ARRAY" widget="default">
    <value>a3</value>
    <value>b3</value>
    <value>c3</value>
    <value>d3</value>
    <value>e3</value>
    <value>f3</value>
    <value>g3</value>
    <value>h3</value>
    <value>i3</value>
    <value>j3</value>
    <value>k3</value>
    <value>l3</value>
    </param>
    <param access="1" constrainttype="STRING_CHOICE" name="Table" oid="params.table" precision="0" type="INT16" value="8" widget="table">
    <constraint>params.c1</constraint>
    <constraint>params.c2</constraint>
    <constraint>params.c3</constraint>
    </param>
    </params>
    </meta>
    <param expand="true" height="491" left="166" oid="params.table" showlabel="false" top="66" width="556"/>
    Here are the 2 icons I used:
  • 6.  RE: Multiple selection on struct table items
    Posted 09-09-2020 19:41
    Thanks Ben, thats exactly what i wanted, im working on panel that checks cliplist inventory from grassvalley K2 summit (AMP protocol), and represent it in table which have "lock" attribute, so my idea was to place lock 🔐 icon instead writing the word. Other option that i found useful, is utf8 characters, that have many icons. The only thing, iits needs to be decoded with decodeURI.
    https://www.utf8icons.com/amp/character/128274/lock
    The panel idea is to find clips that older then 24 (or any other number)hours, and if they are not locked, delete them. Its runs every night with schedulere function .
    If anybody interested in that, i can share it here.
    Alex.
  • 7.  RE: Multiple selection on struct table items
    Posted 09-16-2020 03:42
    Yes please do, it would be interesting to see your integration with amp
  • 8.  RE: Multiple selection on struct table items
    Posted 09-16-2020 14:59
    Hello Antony,
    I will publish it here, but without working Grassvalley K2 summit , and AMP protocol basics knowledge it will be hard to understand how the panel works.
    If you have K2 summit server - then just point his ip adress and click 'connect'  - you will get all the inventory + delete scheduler for specific bin (summit folder).
    I doesn't delete all the temp data from the inventory and log parameters, so when you will open it you will see the panel with data amount.
    Also, using config key i show only clips in cliplist table, but there are also other columns (date, duration,lock/under construction status).
    Let me know if you need addition info.
    <?xml version="1.0" encoding="UTF-8"?><abs contexttype="opengear" gridsize="20" id="_top" keepalive="true">
    <abs height="840" left="20" style="bdr:etched;" top="20" width="920">
    <label height="80" left="0" name="AMP clips killer " right="0" style="txt-align:center;size:Bigger;bdr:etched;" top="0"/>
    <button buttontype="push" height="40" id="connect.button" left="800" name="&lt;html&gt;&lt;left&gt;Connect&lt;/left&gt;&lt;/html&gt;" style="txt-align:west;" top="20" width="100">
    <task tasktype="ogscript">var listener = ogscript.getListenerById('listener1');
    var ip = params.getValue('ip', 0);
    if(listener.isStarted()){
    listener.stop();
    } else {
    listener.connectTo(ip, 3811);
    }</task>
    </button>
    <param expand="true" height="40" left="860" oid="led" top="20" width="40"/>
    <param editable="false" expand="true" height="36" left="700" oid="ip" style="txt-align:center;" top="22" width="100"/>
    <label height="20" left="20" name="Activity log" style="txt-align:center;" top="160" width="480"/>
    <param editable="false" expand="true" height="640" left="20" oid="log" scroll="vertical" showlabel="false" style="bg-align:north;bg#modaloverlay;font:default;fg#blue;txt-align:north;" top="180" width="480"/>
    <param expand="true" height="600" id="list" left="560" oid="clipTable" showlabel="false" top="220" width="280">
    <config key="w.cellediting">false</config>
    <config key="w.selectionparam">selected</config>
    <config key="w.sortable">true</config>
    <config key="w.columns">clipname</config>
    </param>
    <label height="40" left="560" name="Inventory:" style="txt-align:center;" top="180" width="100"/>
    <param expand="true" height="40" left="660" oid="binList" top="180" width="180">
    <task tasktype="ogscript">function changeBin(){
    var clips = ogscript.getObject('clips');
    var status = ogscript.getObject('idStatusCounter');
    if(clips.length==0&amp;&amp;status==''){
    var bin = params.getValueAsString('binList', 0);
    setBin(bin);
    } else {
    ogscript.debug('busy,retry in 1 sec..');
    ogscript.asyncExec(changeBin,1000);
    changeBin();</task>
    </param>
    <table height="34" left="5" right="5" top="100">
    <tr>
    <label colspan="1" fill="both" left="0" name="Delete clips older than" rowspan="1" style="txt-align:west;" top="80" weightx="1.0" weighty="1.0"/>
    <param colspan="1" expand="true" fill="both" left="140" oid="hourslimit" rowspan="1" top="80" weightx="1.0" weighty="1.0"/>
    <label colspan="1" fill="both" left="200" name=" hours, from bin" rowspan="1" style="txt-align:west;" top="80" weightx="1.0" weighty="1.0"/>
    <param colspan="1" expand="true" fill="both" left="340" oid="binListCopy" rowspan="1" top="80" weightx="1.0" weighty="1.0"/>
    <label colspan="1" fill="both" left="300" name="at:" rowspan="1" style="txt-align:center;" top="80" weightx="1.0" weighty="1.0"/>
    <param colspan="1" expand="true" fill="both" left="460" oid="h1" rowspan="1" top="80" weightx="1.0" weighty="1.0"/>
    <label colspan="1" fill="both" left="520" name=":" rowspan="1" style="txt-align:center;" top="80" weightx="1.0" weighty="1.0"/>
    <param colspan="1" expand="true" fill="both" left="540" oid="m1" rowspan="1" top="80" weightx="1.0" weighty="1.0"/>
    <param colspan="1" expand="true" fill="both" left="620" oid="s1" rowspan="1" top="80" weightx="1.0" weighty="1.0"/>
    <label colspan="1" fill="both" left="680" name="daily" rowspan="1" style="txt-align:center;" top="80" weightx="1.0" weighty="1.0"/>
    <button buttontype="push" colspan="1" fill="both" left="720" name="SET" rowspan="1" top="80" weightx="1.0" weighty="1.0">
    <task tasktype="ogscript">updateScheduler();</task>
    </button>
    <button buttontype="push" colspan="1" fill="both" gpi="delete1" left="780" name="&lt;html&gt;&lt;center&gt;DELETE &lt;br&gt; NOW&lt;/center&gt;&lt;/html&gt;" rowspan="1" style="tt:Click if you want to remove older clips now;" top="80" weightx="1.0" weighty="1.0">
    <task tasktype="ogscript">params.setValue('binList', 0, params.getValue('binListCopy', 0));
    ogscript.asyncExec(oldClipsListMaker,100);</task>
    </button>
    </tr>
    </table>
    <help height="22" left="879" message="&lt;html&gt;&lt;left&gt;This is first demo ver.&lt;br/&gt;Log have reports trouble&lt;br/&gt;&lt;br/&gt;&lt;/left&gt;&lt;/html&gt;" name="?" title="AMP clips killer v 1.0" top="803" width="28"/>
    <label baseurl="file:/C:/Users/alex/Desktop/dev%20project/AMP/Release/0.91/ui.grid" height="26" id="totalClips" left="720" name="Total clips:" style="txt-align:west" top="220" width="103"/>
    <meta>
    <params>
    <param access="1" constrainttype="INT_CHOICE" name="binList" oid="binList" precision="0" type="INT32" value="12" widget="combo">
    <constraint key="0">default</constraint>
    <constraint key="1">Recycle Bin</constraint>
    <constraint key="2">IMPORTS</constraint>
    <constraint key="3">PGM'S</constraint>
    <constraint key="4">CLEEN</constraint>
    <constraint key="5">01 BOKER</constraint>
    <constraint key="6">02 OPEN DAY</constraint>
    <constraint key="7">03 DOH YOMI</constraint>
    <constraint key="8">08 TOKER</constraint>
    <constraint key="9">12 DIGITAL</constraint>
    <constraint key="10">ZZZZZ</constraint>
    <constraint key="11">AMNONLEVY</constraint>
    <constraint key="12">HAYOM_SHEHAYA</constraint>
    <constraint key="13">MIVZAK13</constraint>
    <constraint key="14">SHAY</constraint>
    <constraint key="15">STERN</constraint>
    </param>
    <param access="1" constrainttype="STRUCT" name="List Definition" oid="listDefinition" structtype="listInfo" type="STRUCT" widget="table">
    <value>
    <subparam access="1" maxlength="-1" name="Clip name" suboid="clipname" type="STRING" value="Test" widget="default"/>
    <subparam access="1" maxlength="-1" name="Date created" suboid="date" type="STRING" value="Test" widget="default"/>
    <subparam access="1" maxlength="-1" name="Lock" suboid="lock" type="STRING" value="Test" widget="default"/>
    <subparam access="1" maxlength="-1" name="Length" suboid="length" type="STRING" value="Test" widget="default"/>
    </value>
    </param>
    <param access="1" constrainttype="STRUCT" name="List Definition" oid="clipTable" structtype="listInfo" templateoid="listDefinition" type="STRUCT_ARRAY" widget="table">
    <value>
    <subparam suboid="clipname" value="#MAAVARON ELAD NEW"/>
    <subparam suboid="date" value="2020-08-02 11:16:53"/>
    <subparam suboid="lock" value="&lt;html&gt;&lt;font color=&quot;#FF0000&quot;&gt;&lt;/font&gt;&lt;/html&gt;"/>
    <subparam suboid="length" value="00:00:04:01"/>
    </value>
    <value>
    <subparam suboid="clipname" value="#OPEN TERMINAL"/>
    <subparam suboid="date" value="2019-07-28 10:26:54"/>
    <subparam suboid="length" value="00:00:12:05"/>
    </value>
    <value>
    <subparam suboid="clipname" value="@ OPEN MUST"/>
    <subparam suboid="date" value="2020-02-11 17:10:00"/>
    <subparam suboid="length" value="00:00:12:00"/>
    </value>
    <value>
    <subparam suboid="clipname" value="@@FM_VTR_FROMCOM_WW13"/>
    <subparam suboid="date" value="2020-04-09 20:47:50"/>
    <subparam suboid="length" value="00:00:53:03"/>
    </value>
    <value>
    <subparam suboid="clipname" value="@AMNON_CLOSE"/>
    <subparam suboid="date" value="2020-04-12 15:11:22"/>
    <subparam suboid="length" value="00:00:21:17"/>
    </value>
    <value>
    <subparam suboid="clipname" value="@SAGIR"/>
    <subparam suboid="date" value="2019-06-10 23:51:17"/>
    <subparam suboid="length" value="00:00:03:01"/>
    </value>
    <value>
    <subparam suboid="clipname" value="@S_VTR_BACKSHABAT"/>
    <subparam suboid="date" value="2020-04-09 20:50:59"/>
    <subparam suboid="length" value="00:01:21:00"/>
    </value>
    <value>
    <subparam suboid="clipname" value="@S_VTR_CLEANOUTSHABAT"/>
    <subparam suboid="date" value="2020-04-09 20:51:52"/>
    <subparam suboid="length" value="00:01:01:00"/>
    </value>
    <value>
    <subparam suboid="clipname" value="@S_VTR_EIPERRAAYONBILADI"/>
    <subparam suboid="date" value="2020-04-09 20:52:13"/>
    <subparam suboid="length" value="00:00:30:00"/>
    </value>
    <value>
    <subparam suboid="clipname" value="@S_VTR_FROMCOM13SHABAT"/>
    <subparam suboid="date" value="2020-04-09 20:52:27"/>
    <subparam suboid="length" value="00:00:45:22"/>
    </value>
    <value>
    <subparam suboid="clipname" value="@S_VTR_FROMCOM13SHABATCLEAN"/>
    <subparam suboid="date" value="2020-04-09 20:52:45"/>
    </value>
    <value>
    <subparam suboid="clipname" value="@S_VTR_MAGAZINNEW"/>
    <subparam suboid="date" value="2020-04-09 20:53:03"/>
    </value>
    <value>
    <subparam suboid="clipname" value="@S_VTR_OUTSHABAT"/>
    <subparam suboid="date" value="2020-04-09 20:53:44"/>
    </value>
    <value>
    <subparam suboid="clipname" value="@S_VTR_TOCOM13SHABAT"/>
    <subparam suboid="date" value="2020-04-09 20:54:10"/>
    <subparam suboid="length" value="00:00:23:03"/>
    </value>
    <value>
    <subparam suboid="clipname" value="@S_VTR_TOCOM13SHABATCLEAN"/>
    <subparam suboid="date" value="2020-04-09 20:54:24"/>
    </value>
    <value>
    <subparam suboid="clipname" value="@S_VTR_WIPERBILADI"/>
    <subparam suboid="date" value="2020-04-09 20:54:37"/>
    <subparam suboid="length" value="00:00:10:00"/>
    </value>
    <value>
    <subparam suboid="clipname" value="@S_VTR_WIPERGENERICCLEAN"/>
    <subparam suboid="date" value="2020-04-09 20:54:45"/>
    </value>
    <value>
    <subparam suboid="clipname" value="@S_VTR_WIPERPIRSOMRISHON"/>
    <subparam suboid="date" value="2020-04-09 20:54:58"/>
    </value>
    <value>
    <subparam suboid="clipname" value="@me 1 dont delete"/>
    <subparam suboid="date" value="2020-08-30 06:07:17"/>
    <subparam suboid="length" value="00:00:28:10"/>
    </value>
    <value>
    <subparam suboid="clipname" value="B02-F-PATIACH MANCHIM"/>
    <subparam suboid="date" value="2020-09-13 01:35:22"/>
    <subparam suboid="length" value="00:00:30:18"/>
    </value>
    <value>
    <subparam suboid="clipname" value="B06-03-RECHOVOT REKIM"/>
    <subparam suboid="date" value="2020-09-13 01:37:27"/>
    <subparam suboid="length" value="00:01:07:13"/>
    </value>
    <value>
    <subparam suboid="clipname" value="B06-04-ANASHIM IM MASECHOT"/>
    <subparam suboid="date" value="2020-09-13 01:40:22"/>
    <subparam suboid="length" value="00:01:25:00"/>
    </value>
    <value>
    <subparam suboid="clipname" value="B06-05-RONI GAMZO"/>
    <subparam suboid="date" value="2020-09-13 01:38:42"/>
    <subparam suboid="length" value="00:01:10:03"/>
    </value>
    <value>
    <subparam suboid="clipname" value="B06-06-SEGER ARIM HAREDIOT"/>
    <subparam suboid="date" value="2020-09-13 01:40:36"/>
    <subparam suboid="length" value="00:01:28:18"/>
    </value>
    <value>
    <subparam suboid="clipname" value="B06-07-SEGER ARIM"/>
    <subparam suboid="date" value="2020-09-13 01:39:21"/>
    <subparam suboid="length" value="00:01:16:08"/>
    </value>
    <value>
    <subparam suboid="clipname" value="B06-08-OTZER ARIM ADUMOT"/>
    <subparam suboid="date" value="2020-09-13 01:39:32"/>
    <subparam suboid="length" value="00:01:22:08"/>
    </value>
    <value>
    <subparam suboid="clipname" value="B06-09-SEGER ARIM ARAVIYOT"/>
    <subparam suboid="date" value="2020-09-13 01:36:17"/>
    <subparam suboid="length" value="00:00:32:17"/>
    </value>
    <value>
    <subparam suboid="clipname" value="B06-10-BITUACH LEUMI"/>
    <subparam suboid="date" value="2020-09-13 01:38:27"/>
    <subparam suboid="length" value="00:00:52:23"/>
    </value>
    <value>
    <subparam suboid="clipname" value="B06-11-ASAKIM SGURIM CORONA"/>
    <subparam suboid="date" value="2020-09-13 01:35:11"/>
    <subparam suboid="length" value="00:00:38:06"/>
    </value>
    <value>
    <subparam suboid="clipname" value="B06-12-LISHKAT TASUKA"/>
    <subparam suboid="date" value="2020-09-13 01:35:41"/>
    <subparam suboid="length" value="00:00:39:08"/>
    </value>
    <value>
    <subparam suboid="clipname" value="B06-13-BATEI SEFER REKIM"/>
    <subparam suboid="date" value="2020-09-13 01:36:46"/>
    <subparam suboid="length" value="00:00:40:01"/>
    </value>
    <value>
    <subparam suboid="clipname" value="B06-15-LIMUDIM MEKUVANIM"/>
    <subparam suboid="date" value="2020-09-13 01:40:11"/>
    <subparam suboid="length" value="00:01:27:00"/>
    </value>
    <value>
    <subparam suboid="clipname" value="B06-16-BAHAREIN KLALI"/>
    <subparam suboid="date" value="2020-09-13 01:39:07"/>
    <subparam suboid="length" value="00:01:59:11"/>
    </value>
    <value>
    <subparam suboid="clipname" value="B06-17-MELECH BAHAREIN"/>
    <subparam suboid="date" value="2020-09-13 01:36:26"/>
    <subparam suboid="length" value="00:00:38:08"/>
    </value>
    <value>
    <subparam suboid="clipname" value="B06-18-DUBAI KLALI"/>
    <subparam suboid="date" value="2020-09-13 01:36:56"/>
    <subparam suboid="length" value="00:00:30:16"/>
    </value>
    <value>
    <subparam suboid="clipname" value="B06-20-MUHAMAD BEN ZAID"/>
    <subparam suboid="date" value="2020-09-13 01:35:31"/>
    <subparam suboid="length" value="00:00:48:21"/>
    </value>
    <value>
    <subparam suboid="clipname" value="B06-22F-EL ASDI MESIBA GALIL"/>
    <subparam suboid="date" value="2020-09-13 01:31:36"/>
    <subparam suboid="length" value="00:00:15:24"/>
    </value>
    <value>
    <subparam suboid="clipname" value="B06-23F-ERAN MITAMET SHOTRIM"/>
    <subparam suboid="date" value="2020-09-13 01:33:31"/>
    <subparam suboid="length" value="00:00:09:01"/>
    </value>
    <value>
    <subparam suboid="clipname" value="B06-24-YULI EDELSTEIN"/>
    <subparam suboid="date" value="2020-09-13 01:36:37"/>
    <subparam suboid="length" value="00:00:39:15"/>
    </value>
    <value>
    <subparam suboid="clipname" value="B06-25-ISRAEL KATZ"/>
    <subparam suboid="date" value="2020-09-13 01:37:36"/>
    <subparam suboid="length" value="00:01:04:07"/>
    </value>
    <value>
    <subparam suboid="clipname" value="B06-27-ERAN MITAMET SHOTRIM"/>
    <subparam suboid="date" value="2020-09-13 01:34:01"/>
    <subparam suboid="length" value="00:00:27:15"/>
    </value>
    <value>
    <subparam suboid="clipname" value="B07-01-HEZI LEVI"/>
    <subparam suboid="date" value="2020-09-13 01:32:56"/>
    <subparam suboid="length" value="00:00:15:21"/>
    </value>
    <value>
    <subparam suboid="clipname" value="B07-02-MELONOT HADREI KOSHER"/>
    <subparam suboid="date" value="2020-09-13 01:34:11"/>
    <subparam suboid="length" value="00:00:16:00"/>
    </value>
    <value>
    <subparam suboid="clipname" value="B07-03-HADACHA ALINA"/>
    <subparam suboid="date" value="2020-09-13 03:21:59"/>
    </value>
    <value>
    <subparam suboid="clipname" value="B07-04-KOSHER AVRI"/>
    <subparam suboid="date" value="2020-09-13 01:32:46"/>
    <subparam suboid="length" value="00:00:15:19"/>
    </value>
    <value>
    <subparam suboid="clipname" value="B07-05-HIDON"/>
    <subparam suboid="date" value="2020-09-13 01:33:51"/>
    <subparam suboid="length" value="00:00:17:01"/>
    </value>
    <value>
    <subparam suboid="clipname" value="B13-01-GALANT"/>
    <subparam suboid="date" value="2020-09-13 01:38:16"/>
    <subparam suboid="length" value="00:00:46:14"/>
    </value>
    <value>
    <subparam suboid="clipname" value="B24-01-SIGAL SHACHMON"/>
    <subparam suboid="date" value="2020-09-13 01:33:06"/>
    </value>
    <value>
    <subparam suboid="clipname" value="B32-01-MELONOT KLALI"/>
    <subparam suboid="date" value="2020-09-13 01:39:57"/>
    <subparam suboid="length" value="00:01:26:21"/>
    </value>
    <value>
    <subparam suboid="clipname" value="B32-02-HADREI KOSHER REKIM"/>
    <subparam suboid="date" value="2020-09-13 01:39:46"/>
    <subparam suboid="length" value="00:01:39:07"/>
    </value>
    <value>
    <subparam suboid="clipname" value="B32-03-HADREI KOSHER MELEIM"/>
    <subparam suboid="date" value="2020-09-13 01:38:06"/>
    <subparam suboid="length" value="00:01:02:00"/>
    </value>
    <value>
    <subparam suboid="clipname" value="B32-05-MECHAAT SHULMANIM"/>
    <subparam suboid="date" value="2020-09-13 01:38:52"/>
    <subparam suboid="length" value="00:02:05:06"/>
    </value>
    <value>
    <subparam suboid="clipname" value="B42-02F-HADACHA ALINA"/>
    <subparam suboid="date" value="2020-09-13 03:22:33"/>
    <subparam suboid="length" value="00:00:37:00"/>
    </value>
    <value>
    <subparam suboid="clipname" value="B42-03F-IDAN BENI"/>
    <subparam suboid="date" value="2020-09-13 03:21:24"/>
    <subparam suboid="length" value="00:00:36:19"/>
    </value>
    <value>
    <subparam suboid="clipname" value="B42-04-ALINA KLALI"/>
    <subparam suboid="date" value="2020-09-13 03:22:24"/>
    <subparam suboid="length" value="00:00:40:18"/>
    </value>
    <value>
    <subparam suboid="clipname" value="B43-03-BIBI TAL GILBOA"/>
    <subparam suboid="date" value="2020-09-13 01:35:52"/>
    <subparam suboid="length" value="00:00:52:06"/>
    </value>
    <value>
    <subparam suboid="clipname" value="B44-01-TMUNOT MESSI"/>
    <subparam suboid="date" value="2020-09-13 01:33:42"/>
    </value>
    <value>
    <subparam suboid="clipname" value="B44-02F-ASI HAVIV"/>
    <subparam suboid="date" value="2020-09-13 03:21:39"/>
    <subparam suboid="length" value="00:00:12:06"/>
    </value>
    <value>
    <subparam suboid="clipname" value="B44-04-MITOCH HAPEREK BESHIDUR"/>
    <subparam suboid="date" value="2020-09-13 03:22:08"/>
    <subparam suboid="length" value="00:01:45:04"/>
    </value>
    <value>
    <subparam suboid="clipname" value="B68-01-BAKBUKIM PLASTIC SHMUROT"/>
    <subparam suboid="date" value="2020-09-13 01:37:57"/>
    <subparam suboid="length" value="00:01:06:21"/>
    </value>
    <value>
    <subparam suboid="clipname" value="B68-02-BAKBUKIM SECHER YARDEN"/>
    <subparam suboid="date" value="2020-09-13 01:34:57"/>
    <subparam suboid="length" value="00:00:25:05"/>
    </value>
    <value>
    <subparam suboid="clipname" value="B69-01-KETA STAND UP"/>
    <subparam suboid="date" value="2020-09-13 01:31:16"/>
    <subparam suboid="length" value="00:00:14:09"/>
    </value>
    <value>
    <subparam suboid="clipname" value="B73-03F-KETA STAND UP"/>
    <subparam suboid="date" value="2020-09-13 01:34:30"/>
    <subparam suboid="length" value="00:00:31:14"/>
    </value>
    <value>
    <subparam suboid="clipname" value="Clip"/>
    <subparam suboid="date" value="2020-09-13 08:21:32"/>
    <subparam suboid="length" value="00:00:15:01"/>
    </value>
    <value>
    <subparam suboid="clipname" value="DOG"/>
    <subparam suboid="date" value="2020-09-13 06:51:35"/>
    <subparam suboid="length" value="00:00:16:12"/>
    </value>
    <value>
    <subparam suboid="clipname" value="ISO2_BLOCK5"/>
    <subparam suboid="date" value="2020-09-11 14:44:27"/>
    <subparam suboid="length" value="00:23:40:14"/>
    </value>
    <value>
    <subparam suboid="clipname" value="J-0311-VO MICHEL GMAR"/>
    <subparam suboid="date" value="2020-09-13 12:40:55"/>
    <subparam suboid="length" value="00:00:29:15"/>
    </value>
    <value>
    <subparam suboid="clipname" value="J-9001-VO KAPARA KLALI"/>
    <subparam suboid="date" value="2020-06-14 08:23:41"/>
    <subparam suboid="length" value="00:01:07:14"/>
    </value>
    <value>
    <subparam suboid="clipname" value="J-9002-VO ANTING KLALI"/>
    <subparam suboid="date" value="2020-06-14 08:23:24"/>
    <subparam suboid="length" value="00:00:39:22"/>
    </value>
    <value>
    <subparam suboid="clipname" value="J-9003-VO NAVA"/>
    <subparam suboid="date" value="2020-06-14 08:24:32"/>
    <subparam suboid="length" value="00:01:19:13"/>
    </value>
    <value>
    <subparam suboid="clipname" value="J-9004-VO ISRAEL"/>
    <subparam suboid="date" value="2020-06-14 08:24:23"/>
    <subparam suboid="length" value="00:00:53:06"/>
    </value>
    <value>
    <subparam suboid="clipname" value="J-9005-VO YARDEN"/>
    <subparam suboid="date" value="2020-06-14 08:24:02"/>
    <subparam suboid="length" value="00:00:43:08"/>
    </value>
    <value>
    <subparam suboid="clipname" value="J-9006-VO SEMION"/>
    <subparam suboid="date" value="2020-06-14 08:24:12"/>
    <subparam suboid="length" value="00:00:45:21"/>
    </value>
    <value>
    <subparam suboid="clipname" value="J-9007-VO ASI"/>
    <subparam suboid="date" value="2020-06-14 08:24:54"/>
    <subparam suboid="length" value="00:00:50:16"/>
    </value>
    <value>
    <subparam suboid="clipname" value="J-9008-VO IDAN"/>
    <subparam suboid="date" value="2020-06-14 08:25:09"/>
    <subparam suboid="length" value="00:00:51:10"/>
    </value>
    <value>
    <subparam suboid="clipname" value="J-9009-IDO"/>
    <subparam suboid="date" value="2020-06-14 08:25:23"/>
    </value>
    <value>
    <subparam suboid="clipname" value="J-9010-VO ADI BITI"/>
    <subparam suboid="date" value="2020-06-14 08:26:43"/>
    <subparam suboid="length" value="00:01:01:02"/>
    </value>
    <value>
    <subparam suboid="clipname" value="J-9011-VO REGEV"/>
    <subparam suboid="date" value="2020-06-14 08:25:43"/>
    <subparam suboid="length" value="00:01:01:11"/>
    </value>
    <value>
    <subparam suboid="clipname" value="J-9012-NICOLE"/>
    <subparam suboid="date" value="2020-06-14 08:25:34"/>
    <subparam suboid="length" value="00:00:40:03"/>
    </value>
    <value>
    <subparam suboid="clipname" value="J-9013-VO LITAL"/>
    <subparam suboid="date" value="2020-06-14 08:26:13"/>
    <subparam suboid="length" value="00:00:59:14"/>
    </value>
    <value>
    <subparam suboid="clipname" value="J-9014-VO ZOHAR"/>
    <subparam suboid="date" value="2020-06-14 08:25:54"/>
    <subparam suboid="length" value="00:00:51:03"/>
    </value>
    <value>
    <subparam suboid="clipname" value="J-9015-VO DAVID"/>
    <subparam suboid="date" value="2020-06-14 08:26:24"/>
    <subparam suboid="length" value="00:01:06:20"/>
    </value>
    <value>
    <subparam suboid="clipname" value="J-9016-VO BENNY"/>
    <subparam suboid="date" value="2020-06-14 08:26:04"/>
    <subparam suboid="length" value="00:01:07:07"/>
    </value>
    <value>
    <subparam suboid="clipname" value="J-9017-VO ALINA"/>
    <subparam suboid="date" value="2020-06-14 08:26:59"/>
    <subparam suboid="length" value="00:00:59:04"/>
    </value>
    <value>
    <subparam suboid="clipname" value="J-9018-VO ELLA"/>
    <subparam suboid="date" value="2020-06-14 08:27:19"/>
    <subparam suboid="length" value="00:00:51:11"/>
    </value>
    <value>
    <subparam suboid="clipname" value="J-9019-VO ILANA"/>
    <subparam suboid="date" value="2020-06-14 08:27:08"/>
    <subparam suboid="length" value="00:01:21:22"/>
    </value>
    <value>
    <subparam suboid="clipname" value="J-9020-VO GUY ZOAREZ"/>
    <subparam suboid="date" value="2020-06-14 08:26:34"/>
    <subparam suboid="length" value="00:00:37:15"/>
    </value>
    <value>
    <subparam suboid="clipname" value="J-9021-VO DANA RON_1"/>
    <subparam suboid="date" value="2020-07-09 08:25:03"/>
    <subparam suboid="length" value="00:00:38:20"/>
    </value>
    <value>
    <subparam suboid="clipname" value="J-9022-VO ZOHAR NEW_1"/>
    <subparam suboid="date" value="2020-07-09 08:24:43"/>
    <subparam suboid="length" value="00:00:35:23"/>
    </value>
    <value>
    <subparam suboid="clipname" value="J-9023-VO KAPRE NEW_1"/>
    <subparam suboid="date" value="2020-07-09 08:25:49"/>
    <subparam suboid="length" value="00:01:27:16"/>
    </value>
    <value>
    <subparam suboid="clipname" value="J-9024-VO ANTING NEW_1"/>
    <subparam suboid="date" value="2020-07-09 08:25:13"/>
    <subparam suboid="length" value="00:01:48:09"/>
    </value>
    <value>
    <subparam suboid="clipname" value="M_VTR_MIVZAKEND2020_V2"/>
    <subparam suboid="date" value="2020-06-14 13:18:53"/>
    <subparam suboid="length" value="00:00:36:18"/>
    </value>
    <value>
    <subparam suboid="clipname" value="M_VTR_MIVZAKFULL2020"/>
    <subparam suboid="date" value="2020-05-20 06:12:09"/>
    <subparam suboid="length" value="00:00:10:01"/>
    </value>
    <value>
    <subparam suboid="clipname" value="M_VTR_MIVZAKOPENN2020"/>
    <subparam suboid="date" value="2020-06-14 11:50:41"/>
    <subparam suboid="length" value="00:01:14:17"/>
    </value>
    <value>
    <subparam suboid="clipname" value="P05-01F-HAVARAT SHARSHERET HASINUT"/>
    <subparam suboid="date" value="2020-09-13 01:37:46"/>
    <subparam suboid="length" value="00:01:34:00"/>
    </value>
    <value>
    <subparam suboid="clipname" value="P06-01F-ASI BRIT HAGIT"/>
    <subparam suboid="date" value="2020-09-13 01:30:56"/>
    <subparam suboid="length" value="00:00:35:07"/>
    </value>
    <value>
    <subparam suboid="clipname" value="P06-02-ASI BRIT HAGIT"/>
    <subparam suboid="date" value="2020-09-13 01:31:06"/>
    </value>
    <value>
    <subparam suboid="clipname" value="P06-03F-NITZAHON TILTIL"/>
    <subparam suboid="date" value="2020-09-13 01:34:46"/>
    <subparam suboid="length" value="00:01:02:18"/>
    </value>
    <value>
    <subparam suboid="clipname" value="P07-01F-THILAT ONA"/>
    <subparam suboid="date" value="2020-09-13 01:30:31"/>
    <subparam suboid="length" value="00:00:33:15"/>
    </value>
    <value>
    <subparam suboid="clipname" value="P07-02-THILAT ONA"/>
    <subparam suboid="date" value="2020-09-13 01:31:26"/>
    </value>
    <value>
    <subparam suboid="clipname" value="P08-01F-GUY MITGAGEA ASAF"/>
    <subparam suboid="date" value="2020-09-13 01:32:12"/>
    <subparam suboid="length" value="00:00:14:10"/>
    </value>
    <value>
    <subparam suboid="clipname" value="P08-02-ASAF KLALI ONA"/>
    <subparam suboid="date" value="2020-09-13 01:25:34"/>
    <subparam suboid="length" value="00:01:04:00"/>
    </value>
    <value>
    <subparam suboid="clipname" value="P10-F-PAZ PARLAMENT POLEG NATANIA"/>
    <subparam suboid="date" value="2020-09-13 01:31:46"/>
    <subparam suboid="length" value="00:05:22:23"/>
    </value>
    <value>
    <subparam suboid="clipname" value="P11-F-CLIP ITAY SEGEV"/>
    <subparam suboid="date" value="2020-09-13 01:26:05"/>
    </value>
    <value>
    <subparam suboid="clipname" value="P11-F-YETZIA CLIP REGEV HOD"/>
    <subparam suboid="date" value="2020-09-13 01:26:50"/>
    <subparam suboid="length" value="00:01:08:03"/>
    </value>
    <value>
    <subparam suboid="clipname" value="P15-01F-NICOLE TGUVA"/>
    <subparam suboid="date" value="2020-09-13 01:26:41"/>
    <subparam suboid="length" value="00:00:52:16"/>
    </value>
    <value>
    <subparam suboid="clipname" value="P16-02-HAVARAT SHRSHERET HASINUT"/>
    <subparam suboid="date" value="2020-09-13 01:27:10"/>
    </value>
    <value>
    <subparam suboid="clipname" value="P17-01F-RIV IM LITAL"/>
    <subparam suboid="date" value="2020-09-13 01:27:21"/>
    <subparam suboid="length" value="00:00:51:00"/>
    </value>
    <value>
    <subparam suboid="clipname" value="P17-02F-MITZAD HIBUKIM"/>
    <subparam suboid="date" value="2020-09-13 01:26:25"/>
    <subparam suboid="length" value="00:00:13:23"/>
    </value>
    <value>
    <subparam suboid="clipname" value="P18-01F-ISRAEL IDAN MISHPAHOT"/>
    <subparam suboid="date" value="2020-09-13 01:27:35"/>
    <subparam suboid="length" value="00:01:13:09"/>
    </value>
    <value>
    <subparam suboid="clipname" value="P19-F-PAZ PARLAMENT"/>
    <subparam suboid="date" value="2020-09-13 01:30:41"/>
    <subparam suboid="length" value="00:02:37:15"/>
    </value>
    <value>
    <subparam suboid="clipname" value="P22-F-DOR MEVARECH ALINA"/>
    <subparam suboid="date" value="2020-09-13 01:27:46"/>
    </value>
    <value>
    <subparam suboid="clipname" value="P23-01F-ASI ZOHAR"/>
    <subparam suboid="date" value="2020-09-13 01:28:56"/>
    <subparam suboid="length" value="00:01:32:01"/>
    </value>
    <value>
    <subparam suboid="clipname" value="P23-02-ASI ZOHAR"/>
    <subparam suboid="date" value="2020-09-13 01:30:00"/>
    </value>
    <value>
    <subparam suboid="clipname" value="P23-F-YAKOV YELED ANAK"/>
    <subparam suboid="date" value="2020-09-13 01:27:56"/>
    <subparam suboid="length" value="00:00:18:16"/>
    </value>
    <value>
    <subparam suboid="clipname" value="P24-01F-NAVA PORESHET"/>
    <subparam suboid="date" value="2020-09-13 01:37:07"/>
    <subparam suboid="length" value="00:02:45:19"/>
    </value>
    <value>
    <subparam suboid="clipname" value="P24-02-NAVA PORESHET"/>
    <subparam suboid="date" value="2020-09-13 01:36:01"/>
    </value>
    <value>
    <subparam suboid="clipname" value="P25-01F-ILANA MENATZAHAT"/>
    <subparam suboid="date" value="2020-09-13 01:29:07"/>
    <subparam suboid="length" value="00:00:36:15"/>
    </value>
    <value>
    <subparam suboid="clipname" value="P25-01F-REGEV MESAPER IDAN"/>
    <subparam suboid="date" value="2020-09-13 01:28:36"/>
    <subparam suboid="length" value="00:00:36:00"/>
    </value>
    <value>
    <subparam suboid="clipname" value="P25-02-ILANA MENATZAHAT"/>
    <subparam suboid="date" value="2020-09-13 01:28:25"/>
    </value>
    <value>
    <subparam suboid="clipname" value="P25-03F-MICHSE"/>
    <subparam suboid="date" value="2020-09-13 01:28:16"/>
    <subparam suboid="length" value="00:00:22:11"/>
    </value>
    <value>
    <subparam suboid="clipname" value="P25-04-MICHSE"/>
    <subparam suboid="date" value="2020-09-13 01:28:46"/>
    </value>
    <value>
    <subparam suboid="clipname" value="P25-05-KRAV ANAKIM"/>
    <subparam suboid="date" value="2020-09-13 01:29:30"/>
    <subparam suboid="length" value="00:00:43:21"/>
    </value>
    <value>
    <subparam suboid="clipname" value="P25-05F-KRAV ANAKIM"/>
    <subparam suboid="date" value="2020-09-13 01:29:20"/>
    <subparam suboid="length" value="00:00:46:20"/>
    </value>
    <value>
    <subparam suboid="clipname" value="P28-F-PETER MEVARECH"/>
    <subparam suboid="date" value="2020-09-13 01:30:16"/>
    <subparam suboid="length" value="00:00:42:01"/>
    </value>
    <value>
    <subparam suboid="clipname" value="P33-01F-MIFGASH MISHPAHOT"/>
    <subparam suboid="date" value="2020-09-13 01:34:21"/>
    <subparam suboid="length" value="00:01:12:21"/>
    </value>
    <value>
    <subparam suboid="clipname" value="P33-02-MIFGASH MISHPAHOT"/>
    <subparam suboid="date" value="2020-09-13 01:32:26"/>
    </value>
    <value>
    <subparam suboid="clipname" value="P34-01F-MESIMAT SHAVSHAVOT"/>
    <subparam suboid="date" value="2020-09-13 01:29:51"/>
    </value>
    <value>
    <subparam suboid="clipname" value="P34-02-MESIMAT SHAVSHAVOT"/>
    <subparam suboid="date" value="2020-09-13 01:29:41"/>
    </value>
    <value>
    <subparam suboid="clipname" value="P35-01F-BREZENT"/>
    <subparam suboid="date" value="2020-09-13 01:33:17"/>
    <subparam suboid="length" value="00:01:13:03"/>
    </value>
    <value>
    <subparam suboid="clipname" value="P35-02-BREZENT"/>
    <subparam suboid="date" value="2020-09-13 01:32:37"/>
    <subparam suboid="length" value="00:01:02:14"/>
    </value>
    <value>
    <subparam suboid="clipname" value="P40-01F-BENI MOCHIAH IDAN"/>
    <subparam suboid="date" value="2020-09-13 03:27:19"/>
    </value>
    <value>
    <subparam suboid="clipname" value="P40-02-BENI MOCHIACH IDAN"/>
    <subparam suboid="date" value="2020-09-13 03:26:59"/>
    </value>
    <value>
    <subparam suboid="clipname" value="P40-03F-HAGIT MEDABERET"/>
    <subparam suboid="date" value="2020-09-13 03:26:39"/>
    <subparam suboid="length" value="00:00:57:08"/>
    </value>
    <value>
    <subparam suboid="clipname" value="P40-04-HAGIT MEDABERET"/>
    <subparam suboid="date" value="2020-09-13 03:26:25"/>
    </value>
    <value>
    <subparam suboid="clipname" value="P40-05F-HASORED HAHUV"/>
    <subparam suboid="date" value="2020-09-13 03:27:58"/>
    <subparam suboid="length" value="00:00:31:21"/>
    </value>
    <value>
    <subparam suboid="clipname" value="P40-06-HASORED HAHUV"/>
    <subparam suboid="date" value="2020-09-13 03:27:45"/>
    </value>
    <value>
    <subparam suboid="clipname" value="P40-07F-HADACHA ALINA"/>
    <subparam suboid="date" value="2020-09-13 03:30:20"/>
    <subparam suboid="length" value="00:02:39:08"/>
    </value>
    <value>
    <subparam suboid="clipname" value="P40-08-HADACHA ALINA"/>
    <subparam suboid="date" value="2020-09-13 03:31:44"/>
    </value>
    <value>
    <subparam suboid="clipname" value="P40-09F-ASI ACH MAOR"/>
    <subparam suboid="date" value="2020-09-13 03:33:15"/>
    <subparam suboid="length" value="00:01:54:10"/>
    </value>
    <value>
    <subparam suboid="clipname" value="P40-10-ASI ACH MAOR"/>
    <subparam suboid="date" value="2020-09-13 03:34:15"/>
    </value>
    <value>
    <subparam suboid="clipname" value="SH_VTR_PATIH"/>
    <subparam suboid="date" value="2020-08-13 07:03:16"/>
    <subparam suboid="length" value="00:00:13:21"/>
    </value>
    <value>
    <subparam suboid="clipname" value="SH_VTR_SAGIR"/>
    <subparam suboid="date" value="2020-08-13 07:01:20"/>
    <subparam suboid="length" value="00:00:07:07"/>
    </value>
    <value>
    <subparam suboid="clipname" value="SK_VO_HOFYAMOMES"/>
    <subparam suboid="date" value="2020-06-14 14:12:32"/>
    <subparam suboid="length" value="00:00:45:00"/>
    </value>
    <value>
    <subparam suboid="clipname" value="_Opener_morning 4"/>
    <subparam suboid="date" value="2020-06-11 13:34:15"/>
    <subparam suboid="length" value="00:00:05:14"/>
    </value>
    </param>
    <param access="1" constrainttype="INT_NULL" name="selected" oid="selected" precision="0" type="INT16_ARRAY" value="4" widget="default"/>
    <param access="1" constrainttype="INT_CHOICE" name="binListCopy" oid="binListCopy" precision="0" type="INT16" value="0" widget="default">
    </param>
    <param access="1" constraint="48.0;100.0;48.0;100.0;1" constrainttype="INT_STEP_RANGE" name="hourslimit" oid="hourslimit" precision="0" type="INT32" value="48" widget="spinner"/>
    <param access="1" maxlength="0" name="log" oid="log" type="STRING" value="2020-09-13 16:13:09 Removed: Recycle Bin / #MAAVARON ELAD NEW&#10;2020-09-13 16:13:08 Removed: Recycle Bin / #OPEN TERMINAL&#10;2020-09-13 16:13:08 Removed: Recycle Bin / @ OPEN MUST&#10;2020-09-13 16:13:07 Removed: Recycle Bin / @@FM_VTR_FROMCOM_WW13&#10;2020-09-13 16:13:07 Removed: Recycle Bin / @AMNON_CLOSE&#10;2020-09-13 16:13:06 Removed: Recycle Bin / @SAGIR&#10;2020-09-13 16:13:06 Removed: Recycle Bin / @S_VTR_BACKSHABAT&#10;2020-09-13 16:13:05 Removed: Recycle Bin / @S_VTR_CLEANOUTSHABAT&#10;2020-09-13 16:13:05 Removed: Recycle Bin / @S_VTR_EIPERRAAYONBILADI&#10;2020-09-13 16:13:04 Removed: Recycle Bin / @S_VTR_FROMCOM13SHABAT&#10;2020-09-13 16:13:04 Removed: Recycle Bin / @S_VTR_FROMCOM13SHABATCLEAN&#10;2020-09-13 16:13:03 Removed: Recycle Bin / @S_VTR_MAGAZINNEW&#10;2020-09-13 16:13:02 Removed: Recycle Bin / @S_VTR_OUTSHABAT&#10;2020-09-13 16:13:02 Removed: Recycle Bin / @S_VTR_TOCOM13SHABAT&#10;2020-09-13 16:13:01 Removed: Recycle Bin / @S_VTR_TOCOM13SHABATCLEAN&#10;2020-09-13 16:13:01 Removed: Recycle Bin / @S_VTR_WIPERBILADI&#10;2020-09-13 16:13:00 Removed: Recycle Bin / @S_VTR_WIPERGENERICCLEAN&#10;2020-09-13 16:13:00 Removed: Recycle Bin / @S_VTR_WIPERPIRSOMRISHON&#10;2020-09-13 16:12:59 Removed: Recycle Bin / @me 1 dont delete&#10;2020-09-13 16:12:59 Removed: Recycle Bin / ISO2_BLOCK5&#10;2020-09-13 16:12:58 Removed: Recycle Bin / J-9001-VO KAPARA KLALI&#10;2020-09-13 16:12:58 Removed: Recycle Bin / J-9002-VO ANTING KLALI&#10;2020-09-13 16:12:57 Removed: Recycle Bin / J-9003-VO NAVA&#10;2020-09-13 16:12:57 Removed: Recycle Bin / J-9004-VO ISRAEL&#10;2020-09-13 16:12:56 Removed: Recycle Bin / J-9005-VO YARDEN&#10;2020-09-13 16:12:56 Removed: Recycle Bin / J-9006-VO SEMION&#10;2020-09-13 16:12:55 Removed: Recycle Bin / J-9007-VO ASI&#10;2020-09-13 16:12:55 Removed: Recycle Bin / J-9008-VO IDAN&#10;2020-09-13 16:12:54 Removed: Recycle Bin / J-9009-IDO&#10;2020-09-13 16:12:54 Removed: Recycle Bin / J-9010-VO ADI BITI&#10;2020-09-13 16:12:53 Removed: Recycle Bin / J-9011-VO REGEV&#10;2020-09-13 16:12:53 Removed: Recycle Bin / J-9012-NICOLE&#10;2020-09-13 16:12:52 Removed: Recycle Bin / J-9013-VO LITAL&#10;2020-09-13 16:12:52 Removed: Recycle Bin / J-9014-VO ZOHAR&#10;2020-09-13 16:12:51 Removed: Recycle Bin / J-9015-VO DAVID&#10;2020-09-13 16:12:51 Removed: Recycle Bin / J-9016-VO BENNY&#10;2020-09-13 16:12:50 Removed: Recycle Bin / J-9017-VO ALINA&#10;2020-09-13 16:12:50 Removed: Recycle Bin / J-9018-VO ELLA&#10;2020-09-13 16:12:49 Removed: Recycle Bin / J-9019-VO ILANA&#10;2020-09-13 16:12:49 Removed: Recycle Bin / J-9020-VO GUY ZOAREZ&#10;2020-09-13 16:12:48 Removed: Recycle Bin / J-9021-VO DANA RON_1&#10;2020-09-13 16:12:48 Removed: Recycle Bin / J-9022-VO ZOHAR NEW_1&#10;2020-09-13 16:12:47 Removed: Recycle Bin / J-9023-VO KAPRE NEW_1&#10;2020-09-13 16:12:47 Removed: Recycle Bin / J-9024-VO ANTING NEW_1&#10;2020-09-13 16:12:46 Removed: Recycle Bin / M_VTR_MIVZAKEND2020_V2&#10;2020-09-13 16:12:46 Removed: Recycle Bin / M_VTR_MIVZAKFULL2020&#10;2020-09-13 16:12:45 Removed: Recycle Bin / M_VTR_MIVZAKOPENN2020&#10;2020-09-13 16:12:45 Removed: Recycle Bin / SH_VTR_PATIH&#10;2020-09-13 16:12:44 Removed: Recycle Bin / SH_VTR_SAGIR&#10;2020-09-13 16:12:44 Removed: Recycle Bin / _Opener_morning 4&#10;2020-09-13 16:12:02 Removed: Recycle Bin / #MAAVARON ELAD NEW&#10;2020-09-13 16:12:02 Removed: Recycle Bin / #OPEN TERMINAL&#10;2020-09-13 16:12:01 Removed: Recycle Bin / @ OPEN MUST&#10;2020-09-13 16:12:01 Removed: Recycle Bin / @@FM_VTR_FROMCOM_WW13&#10;2020-09-13 16:12:00 Removed: Recycle Bin / @AMNON_CLOSE&#10;2020-09-13 16:12:00 Removed: Recycle Bin / @SAGIR&#10;2020-09-13 16:11:59 Removed: Recycle Bin / @S_VTR_BACKSHABAT&#10;2020-09-13 16:11:59 Removed: Recycle Bin / @S_VTR_CLEANOUTSHABAT&#10;2020-09-13 16:11:58 Removed: Recycle Bin / @S_VTR_EIPERRAAYONBILADI&#10;2020-09-13 16:11:58 Removed: Recycle Bin / @S_VTR_FROMCOM13SHABAT&#10;2020-09-13 16:11:57 Removed: Recycle Bin / @S_VTR_FROMCOM13SHABATCLEAN&#10;2020-09-13 16:11:57 Removed: Recycle Bin / @S_VTR_MAGAZINNEW&#10;2020-09-13 16:11:56 Removed: Recycle Bin / @S_VTR_OUTSHABAT&#10;2020-09-13 16:11:56 Removed: Recycle Bin / @S_VTR_TOCOM13SHABAT&#10;2020-09-13 16:11:55 Removed: Recycle Bin / @S_VTR_TOCOM13SHABATCLEAN&#10;2020-09-13 16:11:55 Removed: Recycle Bin / @S_VTR_WIPERBILADI&#10;2020-09-13 16:11:54 Removed: Recycle Bin / @S_VTR_WIPERGENERICCLEAN&#10;2020-09-13 16:11:54 Removed: Recycle Bin / @S_VTR_WIPERPIRSOMRISHON&#10;2020-09-13 16:11:53 Removed: Recycle Bin / @me 1 dont delete&#10;2020-09-13 16:11:53 Removed: Recycle Bin / ISO2_BLOCK5&#10;2020-09-13 16:11:52 Removed: Recycle Bin / J-9001-VO KAPARA KLALI&#10;2020-09-13 16:11:52 Removed: Recycle Bin / J-9002-VO ANTING KLALI&#10;2020-09-13 16:11:51 Removed: Recycle Bin / J-9003-VO NAVA&#10;2020-09-13 16:11:51 Removed: Recycle Bin / J-9004-VO ISRAEL&#10;2020-09-13 16:11:50 Removed: Recycle Bin / J-9005-VO YARDEN&#10;2020-09-13 16:11:50 Removed: Recycle Bin / J-9006-VO SEMION&#10;2020-09-13 16:11:49 Removed: Recycle Bin / J-9007-VO ASI&#10;2020-09-13 16:11:49 Removed: Recycle Bin / J-9008-VO IDAN&#10;2020-09-13 16:11:48 Removed: Recycle Bin / J-9009-IDO&#10;2020-09-13 16:11:48 Removed: Recycle Bin / J-9010-VO ADI BITI&#10;2020-09-13 16:11:47 Removed: Recycle Bin / J-9011-VO REGEV&#10;2020-09-13 16:11:47 Removed: Recycle Bin / J-9012-NICOLE&#10;2020-09-13 16:11:46 Removed: Recycle Bin / J-9013-VO LITAL&#10;2020-09-13 16:11:46 Removed: Recycle Bin / J-9014-VO ZOHAR&#10;2020-09-13 16:11:45 Removed: Recycle Bin / J-9015-VO DAVID&#10;2020-09-13 16:11:45 Removed: Recycle Bin / J-9016-VO BENNY&#10;2020-09-13 16:11:44 Removed: Recycle Bin / J-9017-VO ALINA&#10;2020-09-13 16:11:44 Removed: Recycle Bin / J-9018-VO ELLA&#10;2020-09-13 16:11:43 Removed: Recycle Bin / J-9019-VO ILANA&#10;2020-09-13 16:11:43 Removed: Recycle Bin / J-9020-VO GUY ZOAREZ&#10;2020-09-13 16:11:42 Removed: Recycle Bin / J-9021-VO DANA RON_1&#10;2020-09-13 16:11:42 Removed: Recycle Bin / J-9022-VO ZOHAR NEW_1&#10;2020-09-13 16:11:41 Removed: Recycle Bin / J-9023-VO KAPRE NEW_1&#10;2020-09-13 16:11:41 Removed: Recycle Bin / J-9024-VO ANTING NEW_1&#10;2020-09-13 16:11:40 Removed: Recycle Bin / M_VTR_MIVZAKEND2020_V2&#10;2020-09-13 16:11:40 Removed: Recycle Bin / M_VTR_MIVZAKFULL2020&#10;2020-09-13 16:11:39 Removed: Recycle Bin / M_VTR_MIVZAKOPENN2020&#10;2020-09-13 16:11:39 Removed: Recycle Bin / SH_VTR_PATIH&#10;2020-09-13 16:11:38 Removed: Recycle Bin / SH_VTR_SAGIR&#10;2020-09-13 16:11:38 Removed: Recycle Bin / _Opener_morning 4&#10;" widget="text-display"/>
    <param access="1" maxlength="0" name="ip" oid="ip" type="STRING" value="10.168.1.89" widget="text"/>
    <param access="1" maxlength="0" name="led" oid="led" type="STRING" value="&lt;#red&gt;" widget="dot"/>
    <param access="1" constraint="0.0;23.0;0.0;23.0;1" constrainttype="INT_STEP_RANGE" name="h1" oid="h1" precision="0" type="INT32" value="18" widget="spinner"/>
    <param access="1" constraint="0.0;59.0;0.0;59.0;1" constrainttype="INT_STEP_RANGE" name="m1" oid="m1" precision="0" type="INT32" value="26" widget="spinner"/>
    <param access="1" constraint="0.0;59.0;0.0;59.0;1" constrainttype="INT_STEP_RANGE" name="s1" oid="s1" precision="0" type="INT32" value="0" widget="spinner"/>
    </params>
    </meta>
    <meta>
    <api name="scheduler">function runAtTime(functionName, time)
    function runGPI(gpi) {
    return function() {
    ogscript.debug("running gpi " + gpi);
    ogscript.fireGPI(gpi, '', false);
    scheduleTomorrow(functionName, time);
    var now = new Date();
    var delay = time.getTime() - now.getTime();
    if (delay &gt; 0) {
    ogscript.asyncExec(runGPI(functionName), delay);
    function scheduleToday(functionName, time)
    var today = new Date();
    var newTime = new Date(today.getFullYear(), today.getMonth(), today.getDate(), time.getHours(), time.getMinutes(), time.getSeconds(), time.getMilliseconds());
    if (newTime.getTime() - today.getTime() &lt; 0) //IF we are too late for today
    ogscript.debug("Too late for today.");
    else
    ogscript.debug("Scheduled task for today: " + newTime);
    runAtTime(functionName, newTime);
    function scheduleTomorrow(functionName, time)
    var newTime = new Date(today.getFullYear(), today.getMonth(), today.getDate() + 1, time.getHours(), time.getMinutes(), time.getSeconds(), time.getMilliseconds());
    ogscript.debug("Scheduling for " + newTime);
    function updateScheduler(){
    //task 1
    var h1 = params.getValue('h1', 0);
    var m1 = params.getValue('m1', 0);
    var s1 = params.getValue('s1', 0);
    var task1Time = new Date()
    task1Time.setHours(h1);
    task1Time.setMinutes(m1);
    task1Time.setSeconds(s1);
    task1Time.setMilliseconds(0);
    scheduleToday("delete1", task1Time);
    task1Time.setHours(h2);
    task1Time.setMinutes(m2);
    task1Time.setSeconds(s2);
    scheduleToday("delete2", task1Time);
    task1Time.setHours(h3);
    task1Time.setMinutes(m3);
    task1Time.setSeconds(s3);
    scheduleToday("delete3", task1Time);
    task1Time.setHours(h4);
    task1Time.setMinutes(m4);
    task1Time.setSeconds(s4);
    scheduleToday("114", task1Time);
    task1Time.setHours(h5);
    task1Time.setMinutes(m5);
    task1Time.setSeconds(s5);
    scheduleToday("115", task1Time);
    */</api>
    <api name="onload">var empty = []; // blank string for reset clips object
    ogscript.putObject('clips',empty); // reset clips object
    ogscript.putObject('idStatusCounter',empty); // reset idstatus object
    ogscript.putObject('busy', 0); // reset busy flag
    ogscript.putObject('eraseList', null); // reset busy flag
    var eraseList = null;
    params.setValue('led', 0, '&lt;#red&gt;');
    updateScheduler();
    var lockIcon = decodeURI('%F0%9F%94%92');
    var recordIcon = decodeURI('%E2%9A%99');
    var listFirstFolderALIAS = 'CMDS0004A02A' + '\n';
    var listNextFoldersALIAS = 'CMDS0004A02B' + '\n';
    var listFirstIdALIAS = 'CMDS0008A2140000' + '\n';
    var listNextIdALIAS = 'CMDS0006a115FF' + '\n';
    var getWorkingBinALIAS = 'CMDS0004A00F' + '\n';
    var getIdCountALIAS = 'CMDS0004A026' + '\n';
    var setDefaultBinALIAS = 'CMDS0026a20e0009000764656661756c74' + '\n';
    var channellessConnectionALIAS = 'CRAT00014\n';
    var stopALIAS = 'STOP0000\n';
    var setBinALIAS = 'a20e';
    var eraseIdALIAS = 'aa10';
    var ackALIAS = "1001";
    var nakALIAS = "1111";
    var error = "1112";
    var listFirstFolderReturnALIAS = '822a';
    var listNextFolderReturnALIAS = '822b';
    var binListCompleteALIAS = '802b';
    var idReturnALIAS = '8a14';
    var noMoreIdALIAS = '8014';
    var IdInfoReturnALIAS = '8a13';</api>
    <api immediate="true" name="sending funcs" src="">function firstIdRequest(){
    ogscript.debug('firstIdRequest fired');
    ogscript.putObject('busy',1);
    var server = ogscript.getObject('channel-less');
    server.writeString(listFirstIdALIAS, false);
    function nextIdRequest(){
    ogscript.debug('nextIdRequest fired');
    server.writeString(listNextIdALIAS, false);
    function firstFolderRequest(){
    server.writeString(listFirstFolderALIAS, false);
    function nextFolderRequest(){
    server.writeString(listNextFoldersALIAS, false);
    function setBin(binName){
    ogscript.putObject('busy',1); // set busy flag to true
    server.writeString(ampMessageBuilder(binName,setBinALIAS), false);
    ogscript.putObject('ack','setBin');
    }</api>
    <api name="Id status request">//++++++++++++++++++++ Sending Part +++++++++++++++++++++
    // Triggered from clipListFinilize(), when the cliplist done.
    function clipStatusRequest(){
    var counter = ogscript.getObject('idStatusCounter');
    var structCount = params.getElementCount('clipTable'); // 700/100 350
    if (counter == ''){ //if this is request for first item in the cliplist
    counter=0;
    if(counter&lt;structCount){
    var clipname = params.getValue('clipTable.' + counter + '.clipname', 0);
    var cmd = idInfoMessageBuilder(clipname,'aa13');
    server.writeString(cmd, false);
    ogscript.putObject('idStatusCounter',counter+1);
    ogscript.rename('totalClips', ' '+ ((counter*100)/structCount).toFixed(0) + '%' );
    if(counter == structCount ){
    ogscript.rename('totalClips', 'Total clips: '+structCount );
    ogscript.putObject('busy',0);
    function idInfoMessageBuilder(string,cmdType){
    var clipNameLen = ('0000' + (string.length).toString(16)).slice(-4);
    var actualCountByte = ('0000' + (string.length+3).toString(16)).slice(-4);
    var totalCmdCounter = ('0000'+(string.length*2+14).toString(10)).slice(-4);
    var hex = string.charCodeAt(0).toString(16);
    for (i = 1; i &lt; string.length; i++) {
    hex += string.charCodeAt(i).toString(16);
    return 'CMDS' + totalCmdCounter + cmdType + actualCountByte + '43'+ clipNameLen + hex + '\n' ;
    //++++++++++++++++++++ Recieve Part +++++++++++++++++++++
    function fileTimeToDate( fileTime ) {
    var date = new Date ( fileTime / 10000 - 11644473600000);
    return date.getUTCFullYear()+ '-' + ('0'+(date.getUTCMonth()+1)).slice(-2) +'-' + ('0'+date.getUTCDate()).slice(-2) + ' '+ ('0'+date.getUTCHours()).slice(-2) +':'
    + ('0'+date.getUTCMinutes()).slice(-2) +':' + ('0'+date.getUTCSeconds()).slice(-2) ;
    function dateConvertor(windowsFileTime,dur,status){
    var lock;var construction;
    status = '0000' + parseInt(status,16).toString(2);
    dur = dur.slice(6) + ':' + dur.slice(4,6) + ':' + dur.slice(2,4)+ ':' + dur.slice(0,2);
    var decimal = parseInt(String(windowsFileTime), 16);
    var counter = ogscript.getObject('idStatusCounter') ;
    if(status.slice(-4,-3) == 1){lock =lockIcon; } else {lock='';}
    if(status.slice(-2,-1) == 1){construction = recordIcon; } else {construction='';}
    params.setValue('clipTable.' + (counter-1) + '.date',0,fileTimeToDate(decimal)); // update date,
    params.setValue('clipTable.' + (counter-1) + '.length',0,dur); // duration,
    params.setValue('clipTable.' + (counter-1) + '.lock',0, '&lt;html&gt;&lt;font color="#FF0000"&gt;' +lock+construction +'&lt;/font&gt;&lt;/html&gt;'); // and lock/under construction status
    clipStatusRequest();
    }</api>
    <api name="Erase funcs">function oldClipsListMaker(){
    var erase = ogscript.getObject('eraseList');
    var busy = ogscript.getObject('busy');
    ogscript.debug('busy list status:' + busy + ', Eraselist; '+erase);
    if(busy==0){ // this condition makes sure that the table data building is finished, if not, it will try again in 0.5 secs
    var clipDate, difference, createdDate, nowtime, structCount,hoursLimit,lock,i;
    var eraseList = [];
    nowtime = new Date();
    hoursLimit = Number(params.getValue('hourslimit', 0));
    for(i=0;i&lt;structCount;i++){
    lock = params.getValue('clipTable.' + i + '.lock', 0).slice(28,30);
    createdDate = params.getValue('clipTable.' + i + '.date', 0); // example date format: 2020-02-02 09:01:02
    clipDate = new Date(createdDate.slice(0,4), createdDate.slice(5,7)-1, createdDate.slice(8,10), createdDate.slice(12,14), createdDate.slice(15,17), createdDate.slice(19,21), 0);
    difference = (nowtime.getTime() - clipDate.getTime())/3600000; // difference in hours
    if (difference&gt;hoursLimit&amp;&amp;lock!==lockIcon){ // if file older then hourLimit, and doesn't locked -
    eraseList.push(params.getValue('clipTable.' + i + '.clipname', 0)); // then add this clip to eraseList
    if(eraseList.length!==0){
    // ogscript.putObject('eraseList', null);
    ogscript.putObject('eraseList', eraseList);
    eraseOldClips();
    }else {
    ogscript.debug('busy list, restarting');
    ogscript.asyncExec(oldClipsListMaker,500)
    function eraseOldClips(){
    var list = ogscript.getObject('eraseList');
    server.writeString(ampMessageBuilder(list[list.length-1],eraseIdALIAS), false);
    var date = new Date();
    date = date.getUTCFullYear()+ '-' + ('0'+(date.getUTCMonth()+1)).slice(-2) +'-' + ('0'+date.getUTCDate()).slice(-2) + ' '+ ('0'+date.getUTCHours()).slice(-2) +':'
    + ('0'+date.getUTCMinutes()).slice(-2) +':' + ('0'+date.getUTCSeconds()).slice(-2);
    params.setValue('log', 0, date + ' Removed: ' + params.getValueAsString('binListCopy', 0) + ' / ' + list[list.length-1] + '\n' +params.getValue('log', 0) );
    list.pop(); // Remove the last element of an array
    ogscript.putObject('eraseList', list);
    if(list.length==0){
    ogscript.putObject('eraseList', 'lastRemoveClip');
    }</api>
    <api name="core functions">// msg argument should be without CMD-TYPE,BC, and CMD CODE. It should starts from CLIPNAME-LEN(2 bytes)--&gt;CLIP NAME and so on.
    // totalLength argument it's an msg length.
    // examle cmd: 000e 535f564f5f425245534c4156494d 000c 5a2d57494e4e455233313038
    function dataConvertor(msg,totalLength){
    var list = [];
    var itemName,i,result,x;
    while(totalLength&gt;0){
    result = '';
    countAndNameNumber = 4 + parseInt(msg.slice(0,4),16) * 2; // number of CLIPNAME-LEN + CLIP NAME
    itemName = msg.slice( 4 , countAndNameNumber);
    msg = msg.slice(countAndNameNumber);
    itemName = itemName.match(/.{1,2}/g); // create array of hex strings
    for (i=0; i&lt;itemName.length; i++) {
    x = parseInt(itemName[i], 16); // convert hex to dec numbers
    result += String.fromCharCode(x);
    list.push(result);
    totalLength -= countAndNameNumber;
    return list;
    function ampMessageBuilder(string,cmdType){ //CMDS0026 a20e 0009 0007 64656661756c74
    var actualCountByte = ('0000' + (string.length+2).toString(16)).slice(-4);
    var totalCmdCounter = ('0000'+(string.length*2+12).toString(10)).slice(-4);
    return 'CMDS' + totalCmdCounter + cmdType + actualCountByte + clipNameLen + hex + '\n' ;
    function clipListFinilize(){
    var clips = ogscript.getObject('clips'); // get array object with all cliplist.
    var structCount = 0;
    var newValue;
    params.setAllValues('clipTable', [{'clipname':'', 'date':'','lock':'','length':''}]);
    var binName ='/' + params.getValueAsString('binList', 0) + '/';
    for(i=0; clips.length&gt;i; i++){
    newValue = { 'clipname': clips[i], 'date': '','lock':'','length':'' };
    params.setValue('clipTable', structCount, newValue);
    ogscript.rename('totalClips','Total clips: '+ clips.length);
    if(clips.length&gt;0){
    } else {
    ogscript.putObject('busy',0); // reset busy object
    // this func copy binlist values to its copy - binlistcopy dropmenu.
    function copyFolderNames() {
    var list = [];
    var x = params.getConstraint("binList");
    var choices = x.getChoices();
    for(i=0; i&lt;choices.length ;i++){
    list.push({"key": i, "value": choices[i].getName() });
    var choiceConstraint = params.createIntChoiceConstraint(list);
    params.replaceConstraint("binListCopy", choiceConstraint);
    }</api>
    <api>function messageRouter(msg){
    // ogscript.debug('recieved msg from k2: ' + msg );
    if (msg.slice(0,4) == listFirstFolderReturnALIAS){ // first folder return (822a)
    list1Folder(msg.slice(8));
    if (msg.slice(0,4) == listNextFolderReturnALIAS){ // next folder return (822b)
    listNextBin(msg.slice(8));
    if (msg == binListCompleteALIAS){ // folder list comlete (802b)
    binListFinilize();
    if (msg.slice(0,4) == idReturnALIAS ){ // ID list (or single if it is the first id) return (8a14)
    nextId(msg.slice(8));
    ogscript.putObject('ack','');
    if (msg == noMoreIdALIAS){ // No more id found (8014)
    ogscript.debug('8014 recieved - no more id present!' );
    clipListFinilize();
    if (msg.slice(0,4) == IdInfoReturnALIAS){ // Id info return (8a13)
    dateConvertor(msg.slice(8,24),msg.slice(40,48),msg.slice(60,68)); // send date created, duration ,statusdata
    if (msg == ackALIAS &amp;&amp; ogscript.getObject('ack') == 'setBin' ){ // if recieved ack (1001) and ack flag was from setDefaulBin
    ogscript.asyncExec(firstIdRequest,150);
    if (msg == ackALIAS &amp;&amp; ogscript.getObject('eraseList') !== null&amp;&amp;ogscript.getObject('eraseList') !== 'lastRemoveClip' ){ // if recieved ack (1001) for clip remove
    ogscript.debug('recieved ack for clip removed,sending request for next delete');
    ogscript.asyncExec(eraseOldClips,500);
    if (msg == error &amp;&amp; ogscript.getObject('eraseList') !== null&amp;&amp;ogscript.getObject('eraseList') !== 'lastRemoveClip' ){ // if recieved ack (1001) for clip remove
    ogscript.debug('error,skipping,sending request for next delete');
    if (msg == ackALIAS &amp;&amp; ogscript.getObject('eraseList') == 'lastRemoveClip' ){ // if recieved ack (1001) for last clip remove
    ogscript.debug('Clips erasing done. Updating list..');
    ogscript.putObject('eraseList',null);
    ogscript.asyncExec(refreshBinList,100);
    function list1Folder(msg){
    ogscript.debug('listfirsFolder fired');
    var binList = dataConvertor(msg,msg.length); // Pass msg to dataConvertor() and get first folder name string
    ogscript.putObject('binList',binList); // Overwrite 'binList' array object with the first folder name.
    nextFolderRequest();
    function listNextBin(msg){
    ogscript.debug('listnextBin fired');
    var binList = ogscript.getObject('binList'); // get array object with first bin name from list1Folder func.
    binList = binList.concat(dataConvertor(msg,msg.length)); // add list returned from dataConvertor() to binList
    function binListFinilize(){
    ogscript.debug('folderlist finalize fired');
    var choiceConstraint = params.createIntChoiceConstraint(binList);
    params.replaceConstraint("binList", choiceConstraint);
    copyFolderNames(); // this will copy the list also to binListCopy parameter
    function nextId(msg){
    var clips = ogscript.getObject('clips'); // get array object with first bin name from list1Folder func.
    clips = clips.concat(dataConvertor(msg,msg.length)); // add list returned from dataConvertor() to binList
    ogscript.putObject('clips',clips);
    nextIdRequest();
    function refreshBinList(){
    }</api>
    </meta>
    <listener autostart="false" blockingpause="true" connecthost="10.168.1.89" connectport="3811" delimiter="1" delimitertype="fixedlen" height="40" id="listener1" left="940" name="Connect" top="100" width="80">
    <task tasktype="ogscript">if (event.isConnectEvent())
    ogscript.putObject('channel-less', this);
    this.writeString(channellessConnectionALIAS, false);
    ogscript.putObject('firstConnection', true);
    params.setValue('led', 0, '&lt;#green&gt;');
    if (event.isMessageEvent())
    var messageReader = ogscript.createMessageParser(this.getInputStream());
    var response = event.getBytesAsString();
    var bytesArr = messageReader.readBytes(3);
    var i; var ampLen = "";
    for (i = 0; i &lt; 3; i++) {
    response += String.fromCharCode(bytesArr[i]);
    ogscript.debug('FROM LISTENER: ' + response);
    if(response == ackALIAS||response == nakALIAS || response == binListCompleteALIAS || response == noMoreIdALIAS||response == error ){
    messageRouter(response);
    if(ogscript.getObject('firstConnection') == true){ // This condition runs if the ack was
    firstFolderRequest(); // recieved for the first time connection,
    ogscript.putObject('firstConnection', false); } // if so he fires 'listFirstFolder'
    } else {
    var bytesArr = messageReader.readBytes(4); // 00090007646 for example
    for (i = 0; i &lt; 4; i++) {
    ampLen += String.fromCharCode(bytesArr[i]);
    response += ampLen;
    var finalMsg = messageReader.readBytes(parseInt(ampLen,16)*2);
    for (i = 0; i &lt; parseInt(ampLen,16)*2; i++) {
    response += String.fromCharCode(finalMsg[i]);
    else if (event.isDisconnectEvent())
    var x = ogscript.getObject('channel-less');
    if (x == this)
    }</task>
    </listener>
