'CSV Examples/CSV Reader Data.csv' is the path. In this case, it's relative to the DashBoard folder, so it does not have the Drive:/ part of this. But you can put the whole path instead.
I just made a quick change to the example panel so that it's getting the file path from a file parameter. Does that help?
Here is the code:
<abs contexttype="opengear" gridsize="20" keepalive="true">
<meta>
<params>
<param access="1" maxlength="0" name="Column 1" oid="cols.1" precision="0" stateless="true" type="STRING_ARRAY" widget="label">
<value>statecode</value>
</param>
<param access="1" maxlength="0" name="Column 2" oid="cols.2" precision="0" stateless="true" type="STRING_ARRAY" widget="label">
<value>county</value>
</param>
<param access="1" maxlength="0" name="Column 3" oid="cols.3" precision="0" stateless="true" type="STRING_ARRAY" widget="label">
<value>eq_site_limit</value>
</param>
<param access="1" maxlength="0" name="Column 4" oid="cols.4" precision="0" stateless="true" type="STRING_ARRAY" widget="label">
<value>hu_site_limit</value>
</param>
<param access="1" maxlength="0" name="Column 5" oid="cols.5" precision="0" stateless="true" type="STRING_ARRAY" widget="label">
<value>fl_site_limit</value>
</param>
<param access="1" maxlength="0" name="Column 6" oid="cols.6" precision="0" stateless="true" type="STRING_ARRAY" widget="label">
<value>fr_site_limit</value>
</param>
<param access="1" maxlength="0" name="Column 7" oid="cols.7" precision="0" stateless="true" type="STRING_ARRAY" widget="label">
<value>tiv_2011</value>
</param>
<param access="1" maxlength="0" name="Column 8" oid="cols.8" precision="0" stateless="true" type="STRING_ARRAY" widget="label">
<value>tiv_2012</value>
</param>
<param access="1" maxlength="0" name="Column 9" oid="cols.9" precision="0" stateless="true" type="STRING_ARRAY" widget="label">
<value>eq_site_deductible</value>
</param>
<param access="1" maxlength="0" name="Column 10" oid="cols.10" precision="0" stateless="true" type="STRING_ARRAY" widget="label">
<value>hu_site_deductible</value>
</param>
<param access="1" maxlength="0" name="Column 11" oid="cols.11" precision="0" stateless="true" type="STRING_ARRAY" widget="label">
<value>fl_site_deductible</value>
</param>
<param access="1" maxlength="0" name="Column 12" oid="cols.12" precision="0" stateless="true" type="STRING_ARRAY" widget="label">
<value>fr_site_deductible</value>
</param>
<param access="1" maxlength="0" name="Column 13" oid="cols.13" precision="0" stateless="true" type="STRING_ARRAY" widget="label">
<value>point_latitude</value>
</param>
<param access="1" maxlength="0" name="Column 14" oid="cols.14" precision="0" stateless="true" type="STRING_ARRAY" widget="label">
<value>point_longitude</value>
</param>
<param access="1" maxlength="0" name="Column 15" oid="cols.15" precision="0" stateless="true" type="STRING_ARRAY" widget="label">
<value>line</value>
</param>
<param access="1" maxlength="0" name="Column 16" oid="cols.16" precision="0" stateless="true" type="STRING_ARRAY" widget="label">
<value>construction</value>
</param>
<param access="1" maxlength="0" name="Column 0" oid="cols.0" precision="0" stateless="true" type="STRING_ARRAY" widget="label">
<value>policyID</value>
</param>
<param access="1" constrainttype="STRING_CHOICE" name="table" oid="table" precision="0" type="INT16" value="-1" widget="table">
<constraint>cols.0</constraint>
<constraint>cols.1</constraint>
<constraint>cols.2</constraint>
<constraint>cols.3</constraint>
<constraint>cols.4</constraint>
<constraint>cols.5</constraint>
<constraint>cols.6</constraint>
<constraint>cols.7</constraint>
<constraint>cols.8</constraint>
<constraint>cols.9</constraint>
<constraint>cols.10</constraint>
<constraint>cols.11</constraint>
<constraint>cols.12</constraint>
<constraint>cols.13</constraint>
<constraint>cols.14</constraint>
<constraint>cols.15</constraint>
<constraint>cols.16</constraint>
</param>
<param access="1" maxlength="0" name="filename" oid="filename" type="STRING" value="CSV%20Examples/CSV%20Reader%20Data2y.csv" widget="file-picker"/>
</params>
</meta>
<label height="60" left="40" name="Reading CSV Files" style="txt-align:west;size:Bigger;" top="40" width="620"/>
<label height="20" left="40" name="ogScript can be used to read in a CSV file (comma separated values), which is typically produced by a spreadsheet program." style="txt-align:west;" top="100" width="1100"/>
<label height="20" left="40" name="This panel reads the "CSV Reader Data.csv" file from the CSV Examples folder, and puts the data in a structured parameter." style="txt-align:west;" top="120" width="1120"/>
<param bottom="20" expand="true" left="40" oid="table" right="20" showlabel="false" top="260"/>
<button buttontype="push" height="80" left="40" name="Read" top="160" width="180">
<task tasktype="ogscript">function processCSV(fileContent)
if (fileContent == null)
ogscript.debug("CAN'T LOAD FILE");
return;
var rows = fileContent.split('\n');
var dataByColumn = []; //It is more efficient if we only call "SET" on the parameters once
for (var r = 0; r < rows.length; r++)
var cols = rows[r].trim().split(',');
for (var c = 0; c < cols.length; c++)
if (c >= dataByColumn.length)
dataByColumn.push([]); //Add a new column if it wasn't already created
dataByColumn[c][r] = cols[c].trim(); //Push the cell's value into the array of column data at row "r"
//Now that we have collected all of the data for each column into an array, we can call setAllValues for the array parameter
for (var c = 0; c < dataByColumn.length; c++)
params.setAllValues('cols.' + c, dataByColumn[c]); //Set all of the values in the column
ogscript.asyncPost(params.getValue("filename",0), null, processCSV);</task>
</button>
<param expand="true" height="40" left="260" oid="filename" showlabel="false" top="160" width="580"/>
