Hi Christian
Do you mean the 'clock middle part' on your XPression graphic? The only thing this button is doing is setting a parameter value and triggering 3 XPression RossTalk Smart GPIs. If you are using XPression DataLinq to put the value of the Qtr_Text_Rep parameter onto your graphic, I would verify in your DataLinq manager that the value is still correct after the button is pressed and, if it is, take a closer look at what scripts in your XPression Project are tied to those GPI triggers.
