  • 1.  INCEPTION MOS PANEL
    Posted 09-24-2020 16:42
    I want to share here basic panel that i created, that demonstrates MOS protocol workflow with Ross Inception NRCS.
    Protocol reference:
    http://mosprotocol.com/wp-content/MOS-Protocol-Documents/MOS-Protocol-2.8.4-Current.htm
    The panel will  read all monitored lineups on connect  –  just be patient, any <roReq> request causing to NCS build-up the lineup stories - its takes about 10-15 sec per lineup - this is normal, and it can register new monitored lineups and delete unmonitored lineups. It can work with up to 6 active lineups. It is still doesn’t react to lineup changes – inserts, moves , name changes etc.. so, don’t do that while you check it.
    I just think, that maybe it will be good start point to somebody who interested in MOS monitor lineup tool etc..
    The lineups represents in represents in struct parameters (ROTable1 -6), and there is some hidden columns that you can unhide if you go to 'glossary API', dynamicTable() function. As i use setXML to represent the tables - the table parameter saved as string - so in that string edit the config key:
    <config key="w.columns">video,name,itemNumber</config>
    The app mosID is 'VTR1' , an ncsID is INCEPTION.
    Alex.
    <abs contexttype="opengear" gridsize="20" id="_top" keepalive="true" scroll="vertical">
    <meta>
    <params>
    <param access="1" constrainttype="STRUCT" name="ROTableTemplate" oid="ROTableTemplate" structtype="ROlist" type="STRUCT" widget="table">
    <value>
    <subparam access="1" maxlength="-1" name="VTR" suboid="video" type="STRING" value="Test" widget="default"/>
    <subparam access="1" maxlength="-1" name="אייטם" suboid="name" type="STRING" value="Test" widget="default"/>
    <subparam access="1" maxlength="-1" name="מס'" suboid="itemNumber" type="STRING" value="Test" widget="default"/>
    <subparam access="1" maxlength="-1" name="channel" suboid="channel" type="STRING" value="Test" widget="default"/>
    <subparam access="1" maxlength="-1" name="available" suboid="available" type="STRING" value="Test" widget="default"/>
    <subparam access="1" maxlength="-1" name="storyID" suboid="storyID" type="STRING" value="Test" widget="default"/>
    <subparam access="1" maxlength="-1" name="roID" suboid="roID" type="STRING" value="Test" widget="default"/>
    </value>
    </param>
    <param access="1" constrainttype="STRUCT" name="ROTableTemplate" oid="ROTable1" structtype="ROlist" templateoid="ROTableTemplate" type="STRUCT_ARRAY" widget="table">
    <value>
    <subparam suboid="video" value=" "/>
    <subparam suboid="name" value=""/>
    <subparam suboid="itemNumber" value=" "/>
    <subparam suboid="channel" value=" "/>
    <subparam suboid="available" value=""/>
    <subparam suboid="storyID" value=""/>
    <subparam suboid="roID" value=""/>
    </value>
    </param>
    <param access="1" constrainttype="STRUCT" name="ROTableTemplate" oid="ROTable2" structtype="ROlist" templateoid="ROTableTemplate" type="STRUCT_ARRAY" widget="table">
    <value>
    </value>
    </param>
    <param access="1" constrainttype="STRUCT" name="ROTableTemplate" oid="ROTable3" structtype="ROlist" templateoid="ROTableTemplate" type="STRUCT_ARRAY" widget="table">
    <value>
    </value>
    </param>
    <param access="1" constrainttype="STRUCT" name="ROTableTemplate" oid="ROTable4" structtype="ROlist" templateoid="ROTableTemplate" type="STRUCT_ARRAY" widget="table">
    <value>
    </value>
    </param>
    <param access="1" constrainttype="STRUCT" name="ROTableTemplate" oid="ROTable5" structtype="ROlist" templateoid="ROTableTemplate" type="STRUCT_ARRAY" widget="table">
    <value>
    </value>
    </param>
    <param access="1" constrainttype="STRUCT" name="ROTableTemplate" oid="ROTable6" structtype="ROlist" templateoid="ROTableTemplate" type="STRUCT_ARRAY" widget="table">
    <value>
    </value>
    </param>
    <param access="1" constrainttype="INT_NULL" name="selected" oid="selected" precision="0" type="INT16" value="0" widget="default"/>
    <param access="1" maxlength="0" name="textinput" oid="textinput" type="STRING" value="&lt;mos&gt;&#10;&lt;mosID&gt;VTR1&lt;/mosID&gt;&#10;&lt;ncsID&gt;INCEPTION&lt;/ncsID&gt;&#10;&lt;roStorySend&gt;&#10;&lt;roID&gt;5685&lt;/roID&gt;&#10;&lt;storyID&gt;1110200&lt;/storyID&gt;&#10;&lt;storySlug&gt;slug-4&lt;/storySlug&gt;&#10;&lt;storyNum&gt;4&lt;/storyNum&gt;&#10;&lt;storyBody&gt;&#10;&lt;p&gt;&lt;/p&gt;&#10;&lt;/storyBody&gt;&#10;&lt;mosExternalMetadata&gt;&#10;&lt;mosScope&gt;PLAYLIST&lt;/mosScope&gt;&#10;&lt;mosSchema&gt;null&lt;/mosSchema&gt;&#10;&lt;mosPayload&gt;&#10;&lt;video&gt;&lt;/video&gt;&#10;&lt;anchor&gt;&lt;/anchor&gt;&#10;&lt;break&gt;false&lt;/break&gt;&#10;&lt;targetTime&gt;&lt;/targetTime&gt;&#10;&lt;estimatedTime&gt;00:00:00&lt;/estimatedTime&gt;&#10;&lt;mediaTime&gt;&lt;/mediaTime&gt;&#10;&lt;totalTime&gt;00:00:00&lt;/totalTime&gt;&#10;&lt;customAttributes&gt;&#10;&lt;actualTime&gt;&lt;/actualTime&gt;&lt;ADIR&gt;&lt;/ADIR&gt;&lt;approval&gt;&lt;/approval&gt;&lt;approved&gt;&lt;/approved&gt;&lt;approvedBy&gt;&lt;/approvedBy&gt;&lt;blacklisted&gt;&lt;/blacklisted&gt;&lt;breaked&gt;&lt;/breaked&gt;&lt;testitay&gt;&lt;/testitay&gt;&lt;child&gt;&lt;/child&gt;&lt;coded&gt;&lt;/coded&gt;&lt;created&gt;&lt;/created&gt;&lt;createdBy&gt;&lt;/createdBy&gt;&lt;dirnotes&gt;&lt;/dirnotes&gt;&lt;endAirTime&gt;&lt;/endAirTime&gt;&lt;floated&gt;&lt;/floated&gt;&lt;fourBroadcast&gt;&lt;/fourBroadcast&gt;&lt;ForPostProduction&gt;&lt;/ForPostProduction&gt;&lt;iNK2&gt;Yes&lt;/iNK2&gt;&#10;&lt;k2&gt;This is test&lt;/k2&gt;&#10;&lt;modified&gt;&lt;/modified&gt;&lt;modifiedBy&gt;&lt;/modifiedBy&gt;&lt;note&gt;&lt;/note&gt;&lt;onAir&gt;&lt;/onAir&gt;&lt;page&gt;&lt;/page&gt;&lt;productionNotes&gt;&lt;/productionNotes&gt;&lt;publish&gt;&lt;/publish&gt;&lt;published&gt;&lt;/published&gt;&lt;publishedBy&gt;&lt;/publishedBy&gt;&lt;quickCodeCC&gt;&lt;/quickCodeCC&gt;&lt;quickCodeCC1&gt;&lt;/quickCodeCC1&gt;&lt;quickCodeCC2&gt;&lt;/quickCodeCC2&gt;&lt;runningOrder&gt;&lt;/runningOrder&gt;&lt;segment&gt;&lt;/segment&gt;&lt;slug&gt;&lt;/slug&gt;&lt;SOURCE&gt;CG&lt;/SOURCE&gt;&#10;&lt;startAirTime&gt;&lt;/startAirTime&gt;&lt;class&gt;&lt;/class&gt;&lt;submitted&gt;&lt;/submitted&gt;&lt;submittedBy&gt;&lt;/submittedBy&gt;&lt;titels&gt;&lt;/titels&gt;&lt;type&gt;&lt;/type&gt;&lt;video&gt;&lt;/video&gt;&lt;vIDEOEDITED&gt;&lt;/vIDEOEDITED&gt;&lt;/customAttributes&gt;&#10;&lt;/mosPayload&gt;&#10;&lt;/mosExternalMetadata&gt;&#10;&lt;/roStorySend&gt;&#10;&lt;/mos&gt;" widget="multiline-text"/>
    <param access="1" maxlength="0" name="timerCounter" oid="timerCounter" type="STRING" value="00:00:00:000" widget="label"/>
    <param access="1" maxlength="0" name="textinput2" oid="textinput2" type="STRING" value="&lt;mos&gt;&#10;&lt;mosID&gt;VTR1&lt;/mosID&gt;&#10;&lt;ncsID&gt;INCEPTION&lt;/ncsID&gt;&#10;&lt;roList&gt;&#10;&lt;roID&gt;5685&lt;/roID&gt;&#10;&lt;roSlug&gt;&amp;#1500;&amp;#1497;&amp;#1497;&amp;#1504;&amp;#1488;&amp;#1508; &amp;#1489;&amp;#1491;&amp;#1497;&amp;#1511;&amp;#1492; &amp;#1495;&amp;#1491;&amp;#1513;&lt;/roSlug&gt;&#10;&lt;roEdStart&gt;2020-09-24T05:57:01&lt;/roEdStart&gt;&#10;&lt;roEdDur&gt;47:40:20&lt;/roEdDur&gt;&#10;&lt;story&gt;&#10;&lt;storyID&gt;1110197&lt;/storyID&gt;&#10;&lt;storySlug&gt;slug-1&lt;/storySlug&gt;&#10;&lt;storyNum&gt;1&lt;/storyNum&gt;&#10;&lt;/story&gt;&#10;&lt;story&gt;&#10;&lt;storyID&gt;1110198&lt;/storyID&gt;&#10;&lt;storySlug&gt;slug-2&lt;/storySlug&gt;&#10;&lt;storyNum&gt;2&lt;/storyNum&gt;&#10;&lt;/story&gt;&#10;&lt;story&gt;&#10;&lt;storyID&gt;1110199&lt;/storyID&gt;&#10;&lt;storySlug&gt;slug-3&lt;/storySlug&gt;&#10;&lt;storyNum&gt;3&lt;/storyNum&gt;&#10;&lt;/story&gt;&#10;&lt;story&gt;&#10;&lt;storyID&gt;1110200&lt;/storyID&gt;&#10;&lt;storySlug&gt;slug-4&lt;/storySlug&gt;&#10;&lt;storyNum&gt;4&lt;/storyNum&gt;&#10;&lt;/story&gt;&#10;&lt;/roList&gt;&#10;&lt;/mos&gt;" widget="multiline-text"/>
    </params>
    <api name="Message Router">function mosRouter(message){
    xml = ogscript.parseXML(message);
    var roList = xml.getElementsByTagName('roList').item(0);
    var roListAll = xml.getElementsByTagName('roListAll').item(0);
    var roCreate = xml.getElementsByTagName('roCreate').item(0);
    var roDelete = xml.getElementsByTagName('roDelete').item(0);
    var roStorySend = xml.getElementsByTagName('roStorySend').item(0);
    if(roCreate!==null){ // New lineup is monitored
    roCreateEvent1(xml,'roCreate');
    if(roListAll!==null ){ // onconnect lineups dropmenu build
    setLineupList(xml);
    if(roStorySend!==null){ // slug data with 'video' (send for each story in new lineup )
    roStorySendEvent1(xml);
    if(roDelete!==null){ // lineup monitor is turned off - reset table data
    deleteRO(xml);
    if(roList!==null){ // lineup monitor is turned off - reset table data
    roCreateEvent1(xml,'roList');
    </api>
    <api name="ack messages">//******************************* ACK functions ***********************************
    function ack(xml){
    var roID = Number(xml.getElementsByTagName('roID').item(0).getTextContent());
    var messageID = ogscript.getObject('ackCount');
    var NRCS = ogscript.getObject('E');
    NRCS.writeAsBytes(ackGen(messageID,roID));
    ogscript.debug('sent ack: ' + messageID);
    ogscript.putObject('ackCount', messageID+1);
    function ackGen(messageID,roID){
    return strToHex(mosAck0) + numberToHex(messageID) + strToHex(mosAck1) + numberToHex(Number(roID)) + strToHex(mosAck2);
    //******************************* data convertors functions ************************
    function numberToHex(number){
    var hex = '';
    number=number.toString().split('');
    for(i=0;i&lt;number.length;i++){
    hex +='00'+ (48+ Number(number[i])).toString(16);
    return hex;
    function strToHex(str){
    var hex = '';
    str=str.split('');
    for(i=0;i&lt;str.length;i++){
    hex +='00'+ Number(str[i].charCodeAt(0)).toString(16);
    return hex;
    }</api>
    <api name="onconnect">function sendRoReqAll(){ //triggered from client listener onConnect() event
    var client = ogscript.getObject('client10541');
    client.writeAsBytes(strToHex(roReqAll));
    function createNewTableRow(name,itemNumber,storyID,tableIndex,roId){ //triggered by roCreateEvent1() func
    var structCount = params.getElementCount('ROTable'+tableIndex);
    if (structCount == 1 &amp;&amp; params.getValue('ROTable' + tableIndex + '.0.name', 0) == "") {structCount = 0;}
    var newValue = {"channel": " ","available": "" ,"video": "","name": name ,"itemNumber": itemNumber,"storyID": storyID,"roID":roId };
    params.setValue('ROTable' + tableIndex, structCount, newValue);
    function sendRoReq(){ //triggered first by setLineupList() (who generate lineup list object 'rolist', and then by roCreateEvent())
    var count = Number(ogscript.getObject('ROCounter'));
    var ROList = ogscript.getObject('roList');
    ogscript.debug('sent roReq for:' + ROList[count-1]);
    if (count&gt;0){
    var NRCSclient = ogscript.getObject('client10541');
    NRCSclient.writeAsBytes(strToHex('&lt;mos&gt;&lt;mosID&gt;VTR1&lt;/mosID&gt;&lt;ncsID&gt;INCEPTION&lt;/ncsID&gt;&lt;messageID&gt;&lt;/messageID&gt;&lt;roReq&gt;&lt;roID&gt;') + numberToHex(Number(ROList[count-1])) + strToHex('&lt;/roID&gt;&lt;/roReq&gt;&lt;/mos&gt;'));
    ogscript.putObject('ROCounter', count-1);
    function setLineupList(xml) { //triggered by &lt;roListAll&gt;
    var ROList = [];
    for (i=0 ; i&lt;xml.getElementsByTagName('roID').length ;i++){
    var roID = xml.getElementsByTagName('roID').item(i).getTextContent();
    var roSlug = xml.getElementsByTagName('roSlug').item(i).getTextContent();
    ROList.push(roID);
    ogscript.debug('roID' + i +': ' + ROList[i]);
    //Set Names to empty buttons
    for (x = 1; x &lt; 7; x++) {
    if(params.getValue("ROTable" + x +".0" + ".roID", 0) == "" ){
    params.setValue("ROTable" + x +".0" + ".roID",0,roID);
    ogscript.rename('table'+x, roSlug);
    break;
    var ROListObject = ogscript.putObject('roList',ROList);
    ogscript.putObject('ROCounter', ROList.length);
    if(ROList.length&gt;0){sendRoReq(ROListObject);} // in case there is no monitored lineups, won't send roReq
    function roCreateEvent1(xml,eventType){ //triggered by &lt;roList&gt;
    ogscript.debug('event is' + eventType);
    var roId,roSlug,storyID,storySlug,storyNum,storyMeta,tableIndex;
    roId = xml.getElementsByTagName('roID').item(0).getTextContent();
    roSlug = xml.getElementsByTagName('roSlug').item(0).getTextContent();
    roStory = ogscript.runXPath('//story', xml);
    if(params.getValue("ROTable" + x +".0" + ".roID", 0) == roId ){tableIndex = (x).toString(); }
    if(eventType=='roCreate'){
    if(params.getValue("ROTable" + x +".0" + ".roID", 0) == ''){
    params.setValue("ROTable" + x +".0" + ".roID",0,roId);
    ogscript.rename('table'+tableIndex,roSlug)
    break; }
    params.setAllValues('ROTable'+tableIndex, empty);
    for(i=0;i&lt;roStory.length;i++){
    storyID = roStory.item(i).getElementsByTagName("storyID").item(0);
    storySlug = roStory.item(i).getElementsByTagName("storySlug").item(0);
    storyNum = roStory.item(i).getElementsByTagName("storyNum").item(0);
    if(storyID!==null) {storyID=storyID.getTextContent();} else { storyID=''; } // Those condition makes sure
    if(storySlug!==null) {storySlug=storySlug.getTextContent();} else { storySlug=''; } // that if there is no such values in slug,
    if(storyNum!==null) {storyNum=storyNum.getTextContent();} else { storyNum=''; } // it will fill the cells with blank
    createNewTableRow(storySlug,storyNum,storyID,tableIndex,roId);
    if(eventType!=='roCreate'){ogscript.asyncExec(sendRoReq,1000);}else{ack(xml);}
    function roStorySendEvent1(xml){ //triggered by &lt;roStorySend&gt;
    var roId = xml.getElementsByTagName('roID').item(0).getTextContent();
    var structCount,storyID,clipname;
    structCount = params.getElementCount('ROTable' + tableIndex);
    storyID = xml.getElementsByTagName('storyID').item(0).getTextContent();
    clipname = xml.getElementsByTagName('video').item(0).getTextContent();
    for(i=0;i&lt;structCount;i++){
    if (params.getValue('ROTable'+tableIndex +'.' + i + '.storyID', 0) == storyID){
    params.setValue("ROTable" + tableIndex + "." + i + ".video",0,clipname);
    ack(xml);
    function deleteRO(xml){ //triggered by &lt;roDelete&gt;
    for (x = 1; x &lt; 7; x++) { if(params.getValue("ROTable" + x +".0" + ".roID", 0) == roId ){var tableIndex = (x).toString(); } }
    ogscript.rename('table'+tableIndex,'');
    ack(xml);
    </api>
    <api name="glossary">function resetRoID(){
    for (i = 1; i &lt; 7; i++) {
    params.setValue("ROTable" + i +".0" + ".roID",0,"");
    ogscript.rename('table'+i, '');
    function resetTables(){
    for (i = 1; i &lt; 7; i++){
    params.setAllValues('ROTable'+i, empty);
    function dynamicTable(num){
    return '&lt;param evenstyle="txt-align:east;size:Big" expand="true" height="860" id="" left="0" oddstyle="txt-align:east;size:Big" oid="ROTable' + num + '" showlabel="false" top="0" width="1280"&gt;txt-align:east;size:Big&lt;config key="w.selectionparam"&gt;selected&lt;/config&gt;&lt;config key="w.cellediting"&gt;false&lt;/config&gt;&lt;config key="w.columns"&gt;video,name,itemNumber&lt;/config&gt;&lt;config key="w.columnlock"&gt;true&lt;/config&gt;&lt;config key="w.colwidth.2"&gt;40&lt;/config&gt;&lt;config key="w.rowheight"&gt;35&lt;/config&gt;&lt;config key="w.hgrid"&gt;false&lt;/config&gt;&lt;config key="w.vgrid"&gt;true&lt;/config&gt;&lt;config key="w.showheader"&gt;true&lt;/config&gt;&lt;/param&gt;';
    const roReqAll = '&lt;mos&gt;&lt;mosID&gt;VTR1&lt;/mosID&gt;&lt;ncsID&gt;INCEPTION&lt;/ncsID&gt;&lt;messageID&gt;&lt;/messageID&gt;&lt;roReqAll/&gt;&lt;/mos&gt;';
    //ack parts for &lt;roStorySend&gt;
    const mosAck0 = '&lt;mos&gt;&lt;mosID&gt;VTR1&lt;/mosID&gt;&lt;ncsID&gt;INCEPTION&lt;/ncsID&gt;&lt;messageID&gt;';
    const mosAck1 = '&lt;/messageID&gt;&lt;roAck&gt;&lt;roID&gt;';
    const mosAck2 = '&lt;/roID&gt;&lt;/roAck&gt;&lt;/mos&gt;';
    //************* roReq message:
    const roReq0 = '&lt;mos&gt;&lt;mosID&gt;VTR1&lt;/mosID&gt;&lt;ncsID&gt;INCEPTION&lt;/ncsID&gt;&lt;messageID&gt;';
    const roReq1 = '&lt;/messageID&gt;&lt;roReq&gt;&lt;roID&gt;';
    const roReq2 = '&lt;/roID&gt;&lt;/roReq&gt;&lt;/mos&gt;';
    const empty = [{"channel": " ","available": "" ,"video": " ","name": "" ,"itemNumber": " ","storyID": "","roID":"" }];
    ogscript.putObject('ackCount', 1);
    ogscript.putObject('roList', null);
    ogscript.putObject('ROCounter', 0);
    resetTables();
    resetRoID();
    </api>
    </meta>
    <abs height="940" left="0" top="0" width="1920">
    <meta>
    <listener autostart="false" buttontype="toggle" delimiter="003C002F006D006F0073003E" delimitertype="bytes" height="40" id="server10541" left="1040" listenport="10541" name="server" top="100" width="340">
    <task tasktype="ogscript">if (event.isConnectEvent())
    ogscript.putObject('E', this);
    if (event.isMessageEvent())
    ogscript.debug('msg recieved');
    var totalString = new java.lang.String(event.getBytes(), "UTF-16") + "&lt;/mos&gt;";
    params.setValue('textinput', 0,totalString.trim()); // put data on text entry
    mosRouter(totalString.trim());
    if (event.isDisconnectEvent()){
    resetTables();
    resetRoID();
    params.setValue('textinput', 0, '');
    params.setValue('textinput2', 0, '');
    }</task>
    </listener>
    <listener autostart="false" buttontype="toggle" connecthost="10.168.1.130" connectport="10541" delimiter="003C002F006D006F0073003E" delimitertype="bytes" height="40" id="client10541" left="1040" name="client" top="100" width="340">
    ogscript.putObject('client10541', this);
    this.writeAsBytes(strToHex(roReqAll));
    params.setValue('textinput2', 0,totalString.trim()); // put data on text entry
    resetTables();
    resetRoID();
    }</task>
    </listener>
    <listener autostart="false" delimiter="003C002F006D006F0073003E" delimitertype="bytes" listenport="10540" name="10540">
    ogscript.putObject('10540', this);
    ogscript.debug('10540');
    //params.setValue('textinput', 0,totalString.trim()); // put data on text entry
    ogscript.debug(totalString.trim());
    ogscript.putObject('lastMos10540', totalString.trim());
    ack10540(totalString.trim());
    }</task>
    </listener>
    </meta>
    <param expand="true" height="420" left="1300" oid="textinput" scroll="vertical" top="500" width="320"/>
    <label header="true" height="40" left="1300" name="Mos listener recieve monitor" style="txt-align:center;" top="460" width="320"/>
    <button baseurl="file:/C:/Users/alex/Desktop/dev%20project/DashBoardExamplePanels_1.0/STRUCT%20TABLE/table.grid" buttontype="push" height="60" id="table1" left="20" name="" top="0" width="213">
    <task tasktype="ogscript">ogscript.setXml('dynamic', dynamicTable("1"));</task>
    </button>
    <label header="true" height="40" left="1300" name="Mos client recieve monitor" style="txt-align:center;" top="60" width="320"/>
    <param expand="true" height="360" left="1300" oid="textinput2" scroll="true" top="100" width="320"/>
    <abs height="860" id="dynamic" left="20" top="60" width="1280"/>
    <button baseurl="file:/C:/Users/alex/Desktop/dev%20project/DashBoardExamplePanels_1.0/STRUCT%20TABLE/table.grid" buttontype="push" height="60" id="table2" left="234" name="" top="0" width="213">
    <task tasktype="ogscript">ogscript.setXml('dynamic', dynamicTable("2"));</task>
    </button>
    <button baseurl="file:/C:/Users/alex/Desktop/dev%20project/DashBoardExamplePanels_1.0/STRUCT%20TABLE/table.grid" buttontype="push" height="60" id="table3" left="448" name="" top="0" width="213">
    <task tasktype="ogscript">ogscript.setXml('dynamic', dynamicTable("3"));</task>
    </button>
    <button baseurl="file:/C:/Users/alex/Desktop/dev%20project/DashBoardExamplePanels_1.0/STRUCT%20TABLE/table.grid" buttontype="push" height="60" id="table4" left="662" name="" top="0" width="213">
    <task tasktype="ogscript">ogscript.setXml('dynamic', dynamicTable("4"));</task>
    </button>
    <button baseurl="file:/C:/Users/alex/Desktop/dev%20project/DashBoardExamplePanels_1.0/STRUCT%20TABLE/table.grid" buttontype="push" height="60" id="table5" left="876" name="" top="0" width="213">
    <task tasktype="ogscript">ogscript.setXml('dynamic', dynamicTable("5"));</task>
    </button>
    <button baseurl="file:/C:/Users/alex/Desktop/dev%20project/DashBoardExamplePanels_1.0/STRUCT%20TABLE/table.grid" buttontype="push" height="60" id="table6" left="1090" name="" top="0" width="213">
    <task tasktype="ogscript">ogscript.setXml('dynamic', dynamicTable("6"));</task>
    </button>
    <button buttontype="push" height="60" left="1320" name="CONNECT TO INCEPTION" top="0" width="280">
    <task tasktype="ogscript">var client = ogscript.getListenerById ('client10541');
    var server = ogscript.getListenerById ('server10541');
    if(client.isStarted() ==true&amp;&amp;server.isStarted()&amp;&amp;true){
    client.stop();
    server.stop();
    } else {
    client.start();
    server.start();
    }</task>
    </button>
  • 2.  RE: INCEPTION MOS PANEL
    Posted 10-01-2020 13:18
    Thank you for sharing.   This looks great!
