Looking to create a custom panel for a Ultrix where the buttons are customized etc. Coming from using a NK router where you can easily add source/destination/level buttons to a panel but Ultrix doesn't seem to be as easy. Can custom panels be created using Dashboard for the Ultrix or are you limited to the templates provided in the Ultrix portion of Dashboard (ie. push button, multi-bus, etc)? Have an example below of the panels we use for the NK which is what we are trying to mimic.
Not sure if I'm missing something here and maybe it is as easy as NK. Also I should state not very proficient in scripting. Thanks.
