I have add dropdown aften my first share of code but it has OID test
it is string
<timer id="klokken" pattern="HH:mm:ss" rate="500">
<timertask tasktype="ogparamset">params.setValue('kl', 0, event.getDisplay());</timertask>
</timer>
<meta>
<params>
<param access="1" maxlength="0" name="Ident" oid="0x2" precision="0" type="STRING_ARRAY" widget="text-display">
<value>Ident</value>
</param>
<param access="1" maxlength="0" name="Navn" oid="0x3" precision="0" type="STRING_ARRAY" widget="text-display">
<value>Navn</value>
</param>
<param access="1" maxlength="0" name="Title" oid="0x4" precision="0" type="STRING_ARRAY" widget="text-display">
<value>Title</value>
</param>
<param access="1" maxlength="0" name="SubType" oid="0x5" precision="0" type="STRING_ARRAY" widget="text-display">
<value>B</value>
</param>
<param access="1" maxlength="0" name="Subtype-c" oid="0x6" precision="0" type="STRING_ARRAY" widget="default">
<value>sfd</value>
<value>ada</value>
<value>t1</value>
</param>
<param access="1" maxlength="0" name="SubNavn-c" oid="0x7" precision="0" type="STRING_ARRAY" widget="text-display">
<value>asf</value>
<value>dasd</value>
<value>sub top 1</value>
</param>
<param access="1" maxlength="0" name="Sub Take ID" oid="0x8" precision="0" type="STRING_ARRAY" widget="text-display">
<value>asd</value>
<value>6</value>
<value>5</value>
</param>
<param access="1" maxlength="0" name="Sub Prew ID" oid="0x9" precision="0" type="STRING_ARRAY" widget="text">
<value>ad</value>
<value>34</value>
<value>90</value>
</param>
<param access="1" constrainttype="INT_CHOICE" name="Table Config" oid="Table_Config" precision="0" type="INT32" value="0" widget="default">
<constraint key="6">Syb Type</constraint>
<constraint key="7">Sub Navn</constraint>
<constraint key="8">Take ID</constraint>
<constraint key="9">Prev ID</constraint>
</param>
<param access="1" maxlength="0" name="syb-type-n" oid="sybtypen" type="STRING" value="" widget="text"/>
<param access="1" maxlength="0" name="sub-n-n" oid="subnn" type="STRING" value="" widget="text"/>
<param access="1" maxlength="0" name="take-id-n" oid="takeidn" type="STRING" value="" widget="text"/>
<param access="1" maxlength="0" name="prev-n" oid="prevn" type="STRING" value="" widget="text"/>
<param access="1" constrainttype="INT_NULL" name="div" oid="0xA" precision="0" type="INT16_ARRAY" value="0" widget="default"/>
<param access="1" maxlength="0" name="o-st" oid="ost" type="STRING" value="" widget="default"/>
<param access="1" maxlength="0" name="O-sn" oid="Osn" type="STRING" value="" widget="default"/>
<param access="1" maxlength="0" name="O-ti" oid="Oti" type="STRING" value="" widget="default"/>
<param access="1" maxlength="0" name="o-pi" oid="opi" type="STRING" value="" widget="default"/>
<param access="1" constrainttype="INT_CHOICE" name="TEAT" oid="TEAT" precision="0" type="INT32" value="1" widget="combo">
<constraint key="1">T1</constraint>
</param>
<param access="1" constrainttype="INT_CHOICE" name="Table list" oid="0xB" precision="0" type="INT32" value="1" widget="default">
<constraint key="5">ID</constraint>
<constraint key="3">Navn</constraint>
<constraint key="4">Title</constraint>
<constraint key="2">Sub Type</constraint>
</param>
<param access="1" constrainttype="INT_CHOICE" name="test" oid="test" precision="0" type="INT32" value="1" widget="combo">
<constraint key="1">sfd</constraint>
<constraint key="2">ada</constraint>
<constraint key="3">t1</constraint>
</param>
<param access="1" maxlength="0" name="kl" oid="kl" type="STRING" value="18:23:04" widget="label"/>
</params>
</meta>
<tab height="1064" left="10" top="6" width="1898">
<abs name="Afvikling" style="bg#tablezebra;" virtualheight="1080" virtualwidth="1920">
<param constrainttype="INT_CHOICE" evenstyle="f:size:Big;f:txt-align:center;" expand="true" height="753" left="8" oddstyle="f:size:Big;f:txt-align:center;" oid="0xB" precision="0" showlabel="false" top="2" widget="table" width="1359">
<constraint key="2">ID</constraint>
<constraint key="5">Sub Type</constraint>
</param>
<widget height="353" name="CG1" right="-2" top="4" widgetid="com.rossvideo.xpression.preview" width="553">
<config>
<params>
<param oid="preview_widget_channel" value="1"/>
<param oid="preview_widget_show_channel" value="1"/>
<param oid="preview_widget_show_name" value="1"/>
</params>
</config>
</widget>
<abs bottom="7" height="298" id="main" left="8" name="main" style="bg#listbg;" width="1359">
<param colspan="5" expand="true" fill="both" height="427" oid="klokke" rowspan="3" style="style:timerLabel;size:150;" weightx="1.0" weighty="1.0" width="2033"/>
<param bottom="7" expand="true" height="133" left="67" oid="kl" style="style:timerLabel;size:100;" width="536"/>
<table bottom="-2" right="1" top="0" width="247">
<tr>
<dropspot colspan="1" fill="both" rowspan="1" weightx="1.0" weighty="1.0"/>
</tr>
<tr>
<button buttontype="push" colspan="1" fill="both" name="Opret" rowspan="1" style="size:Bigger;" weightx="1.0" weighty="1.0">
<task tasktype="ogscript">/*! block id=1025 !*/
ogscript.reveal("edit");
/*! block id=1026 !*/
ogscript.hide("main");
<block id="1025" type="ogscript_reveal" x="572" y="160" w="243" ID="edit" next="ID:1026" />
<block id="1026" type="ogscript_hide" x="605" y="298" w="243" ID="main" />
/*!!<checksum>67463d996644a973f7b42c0edc380bc0</checksum>!!*/</task>
</button>
</tr>
<tr>
<button buttontype="push" colspan="1" fill="both" name="Rediger" rowspan="1" weightx="1.0" weighty="1.0"/>
</tr>
</table>
<abs bottom="3" height="300" id="edit" left="2" name="edit" style="bg#listbg;" width="1363">
<table bottom="5" right="2" top="0" width="255">
<tr>
</tr>
<tr>
<button buttontype="push" colspan="1" fill="both" name="GEM" rowspan="1" weightx="1.0" weighty="1.0"/>
</tr>
<tr>
<button buttontype="push" colspan="1" fill="both" name="Tilbage" rowspan="1" weightx="1.0" weighty="1.0">
<task tasktype="ogscript">/*! block id=1027 !*/
ogscript.reveal("main");
/*! block id=1028 !*/
ogscript.hide("edit");
<block id="1027" type="ogscript_reveal" x="601" y="168" w="243" ID="main" next="ID:1028" />
<block id="1028" type="ogscript_hide" x="557" y="372" w="243" ID="edit" />
/*!!<checksum>7bc9567781888b8d20add27e6a5a229f</checksum>!!*/</task>
</button>
</tr>
</table>
<abs name="Config">
<meta>
<ogscript/>
<ogscript element="0" handles="onchange" oid="Table_Config">ogscript.debug(params.getValue('Table_Config', 0));
params.setValue(0xA, 0, params.getValue('Table_Config', 0));</ogscript>
</meta>
<param constrainttype="INT_CHOICE" croll="true" expand="true" height="526" left="17" oid="Table_Config" precision="0" showlabel="false" top="25" widget="table" width="950">
<constraint key="6">Sub Type</constraint>
</param>
<table height="78" left="15" top="562" width="953">
<tr>
<button buttontype="push" colspan="1" fill="both" name="Opret" rowspan="1" weightx="1.0" weighty="1.0">
<task tasktype="ogscript">/*! block id=1016 !*/
ogscript.reveal("c-opret");
/*! block id=1017 !*/
ogscript.hide("_top");
<block id="1016" type="ogscript_reveal" x="314" y="153" w="243" ID="c-opret" next="ID:1017" />
<block id="1017" type="ogscript_hide" x="317" y="284" w="243" ID="_top" />
/*!!<checksum>b279a6e27ad82b64e6950d8750455a45</checksum>!!*/</task>
<task tasktype="ogscript">params.setValue('opi', 0, '');
params.setValue('Osn', 0, '');
params.setValue('ost', 0, '');
params.setValue('Oti', 0, '');</task>
</button>
<button buttontype="push" colspan="1" fill="both" name="Rediger" rowspan="1" weightx="1.0" weighty="1.0">
<task tasktype="ogscript">/*! block id=1018 !*/
ogscript.reveal("c-edit");
ogscript.hide("c-opret");</task>
<task tasktype="ogscript"/>
<task tasktype="ogscript">var id = params.getValue(0xA, 0);
var a = params.getValue(0x6, id);
var b = params.getValue(0x7, id);
var c = params.getValue(0x8, id);
var d = params.getValue(0x9, id);
params.setValue('ost', 0, a);
params.setValue('Osn', 0, b);
params.setValue('Oti', 0, c);
params.setValue('opi', 0, d);
ogscript.debug(id);</task>
</button>
<button buttontype="push" colspan="1" fill="both" name="Slet" rowspan="1" weightx="1.0" weighty="1.0">
params.getParam(0x6, id).remove();
params.getParam(0x7, id).remove();
params.getParam(0x8, id).remove();
params.getParam(0x9, id).remove();
ogscript.debug("slettede linje " + id );</task>
</button>
</tr>
</table>
<abs height="136" id="c-edit" left="18" name="c-edit" style="bg#000000;" top="659" width="952">
<table bottom="8" left="0" right="5" top="4">
<tr>
<label colspan="1" fill="both" name="Sub Type" rowspan="1" style="txt-align:center;bg-align:center;font:default;size:Big;" weightx="1.0" weighty="1.0"/>
<label colspan="1" fill="both" name="Sub Navn" rowspan="1" style="txt-align:center;bg-align:center;font:default;size:Big;" weightx="1.0" weighty="1.0"/>
<label colspan="1" fill="both" name="Take ID" rowspan="1" style="txt-align:center;bg-align:center;font:default;size:Big;" weightx="1.0" weighty="1.0"/>
<label colspan="1" fill="both" name="Prev ID" rowspan="1" style="txt-align:center;bg-align:center;font:default;size:Big;" weightx="1.0" weighty="1.0"/>
<button buttontype="push" colspan="1" fill="both" name="Opdater" rowspan="1" weightx="1.0" weighty="1.0">
<task tasktype="ogscript">var id = params.getValue('0xA', 0)
ogscript.debug(id);
var a = params.getValue('ost', 0);
var b = params.getValue('Osn', 0);
var c = params.getValue('Oti', 0);
var d = params.getValue('opi', 0);
params.setValue(0x6, id, a);
params.setValue(0x7, id, b);
params.setValue(0x8, id, c);
params.setValue(0x9, id, d);</task>
</button>
</tr>
<tr>
<param colspan="1" expand="true" fill="both" oid="ost" rowspan="1" style="bdr:shadow;grid#lightdivider;bdr#lightdivider;txt-align:center;" weightx="1.0" weighty="1.0"/>
<param colspan="1" expand="true" fill="both" oid="Osn" rowspan="1" style="bdr:shadow;grid#lightdivider;bdr#lightdivider;txt-align:center;" weightx="1.0" weighty="1.0"/>
<param colspan="1" expand="true" fill="both" oid="Oti" rowspan="1" style="bdr:shadow;grid#lightdivider;bdr#lightdivider;txt-align:center;" weightx="1.0" weighty="1.0"/>
<param colspan="1" expand="true" fill="both" oid="opi" rowspan="1" style="bdr:shadow;grid#lightdivider;bdr#lightdivider;txt-align:center;" weightx="1.0" weighty="1.0"/>
</tr>
</table>
<abs height="137" id="c-opret" left="17" name="c-opret" style="bg#000000;" top="659" width="951">
<table bottom="5" left="1" right="3" top="2">
<tr>
<button buttontype="push" colspan="1" fill="both" name="Opret" rowspan="1" style="size:Big;" weightx="1.0" weighty="1.0">
<task tasktype="ogscript">var id = params.getParam("0x6",0);
var idc = id.getElementCount();
ogscript.debug(idc);
var p = params.getValue('opi', 0);
var sn = params.getValue('Osn', 0);
var st = params.getValue('ost', 0);
var ti = params.getValue('Oti', 0);
params.setValue(0x6, idc, st);
params.setValue(0x7, idc, sn);
params.setValue(0x8, idc, ti);
params.setValue(0x9, idc, p);</task>
</button>
</tr>
<tr>
</tr>
</table>
<param expand="true" height="46" left="1046" oid="test" top="483" width="265"/>
<label height="50" left="1058" name="SUB Type " style="txt-align:center" top="426" width="237"/>
</tab>
