Hi Wil,
You can connect your Carbonite and Behringer by using a proxy to share them. If you have the Carbonite and Behringer physically connected to 2 separate computers with a version of DashBoard running on each of them, you can share the Behringer through the proxy and connect to it through the other DashBoard over a TCP/IP connection and interact with the parameters there. One of your DashBoards converts the Behringer controller to an OGP device and the other consumes it. Ultritouch does not support that.
Anita McKee
Sent: 07-15-2021 17:23
Subject: Connecting to a Behringer x32 mixer through dashbaord/carbontie ultra/ultritouch
Is it possible to connect my Carbonite Ultra switcher and Behringer x32 mixer over IP, so that I can access the x32's scene/snippets using the switcher's custom controls or my ultritouch panel? I know I could use an Elgato Stream Deck, but I was really hoping to not spend money.
Wil
