Hi Guillaume,
Acuity TSL Out is using the TSL v5.0 Protocol and does not have support for TSL v3.1 (since 3.1 only supports 0-127 IDs). There is an issue with DashBoard TSL v5 input and it is not able to supply the info for you.
The fact that any data is populated when you set it up for TSL v3.1 is kind of neat... an unexpected result. There must be some subset of v5.0 that is getting parsed and displayed when you setup DashBoard to take in v3.1.
At this point we will need to have the DashBoard team investigate why v5.0 is not working.
Sorry for the inconvenience as I am sure you were going to be doing some cool stuff with dashboard using this interface.
Product Manager - Production Switchers
Sent: 07-14-2021 11:31
Subject: Tally from Acuity to Dashboard.
I'm trying to get TSL tally from a Acuity switcher to a Dashboard panel.
I got a network port on the switcher panel set up to Serial Tally - TSLOut - Network TCP. In the Dashboard Tally Service. I'm getting data when I pick TSL UMD 3.1 (TCP) in the configuration tab of the Tally Service but it's seem that something is not working exactly as it should. As you can see on the picture here, I'm getting for ID 1 the text @IN 130 but I don't have that much input with in the switcher. Also, everything else is greyed out wich make me thing that I got something wrong.
Any hint on what could I do to fix that would be really appreciated
Guillaume Hebert
TVA
