Hi
Just to add to this, remember even at the fastest frame normally used, 60fps, you won't resolve 100ths of a second on your graphic. - it will just look like lots of fast digits, which is probably what you want.
What are you trying to time, and what mechanism do you have to start/stop the clock? If it's someone clicking something or pressing something, then 100ths accuracy is probably not achievable.
If you have an external method to start/stop the clock, I'd go down the Dashboard route as your clock source. It'll be easier to interface to external signals and program up.
I wouldn't worry about the amount of data flying around for 100ths of a second. Over a Gigabit network, that'll be a drop in the ocean, so which ever you choose as the source of your timing, it will be accurate I'd have thought.
Simon
Simon Latus
SIMON LATUS MEDIA LTD
Sent: 03-28-2022 12:10
Subject: Dashboard listening Xpression
I can't speak to the accuracy down to thousandths. There is an Xpression listener you can install on dashboard that will display data from scenes in Xpression on your dashboard. I have done that before but it wasn't for clocks. I don't want to take you down a rabbit hole if you already have a direction you are headed. If you reach out to your Ross Video rep, they might be able to hook you up with the right tech person.
Malcolm Thorpe
Sent: 03-28-2022 12:01
Hi Malcom,
We need to use a timer with hundredths of seconds. So I don´t know if passing the data from Dashboard to Xpression is going to be accurate.
What do you think?
Best regards,
Eduardo Mayone
Sent: 03-28-2022 11:34
Eduardo,
What if you did it the other way around? Build the timer in Dashboard and stream that value to your xpression scene.
Malcolm Thorpe
Sent: 03-27-2022 18:48
I have a timer running in Xpression, and I want to read the time in Dashboard.
Can I use Countdown Timer Broadcast to listening but not use Xpression Countdown Widget?
Thanks,
Eduardo
Eduardo Mayone
