  • 1.  HTTP Get with Authorization Header
    Posted 05-05-2021 04:34
    Hi All,
    Could someone help me out?
    I've searched the board and found a few posts relating a HTTP Post using headers but I just can't make it work with a GET.
    I need to send an HTTP Get with an authorization header for a web API.
    Here's my code:
    var requestURL = "https://app.singular.live/apiv1/appinstances"
    var credentials = "Username@username.com" + ":" + "Password"
    ogscript.debug(credentials);
    var credentials64 = base64Encode(credentials)
    ogscript.debug("base64Encode =" + credentials64);
    params.setValue('Base64', 0, credentials64);
    var creds = "Basic " + params.getValue('Base64', 0);
    var headers = {}
    headers["Authorization"] = creds;
    ogscript.asyncHTTP(requestURL, "GET", "application/json" , null, null);
    var headerstring = JSON.stringify(headers)
    ogscript.debug("headers =" + headerstring);
    In this state the server returns an unauthorised message which I'd expect, but trying to insert my "headers" array anywhere into this command makes it unrecognizable to the server.
    Cheers,
    Chris
    Chris Mason
    ES BROADCAST LTD
  • 2.  RE: HTTP Get with Authorization Header
    Posted 05-05-2021 15:59
    Hi Chris
    Provided your password does not have a '@' character in it, we do have a shortcut to use a base64 authentication.  Just use:
    var requestURL = "https://" + credentials + "@app.singular.live/apiv1/appinstances"
    Another option you can use is to replace the content-type argument with a JSON object containing any headers you wish to send:
    var headers = {}
    headers["Content-Type"] = "application/json";
    ogscript.asyncHTTP(requestURL, "GET", headers , null, null);
    Cheers
    James
    James Peltzer
  • 3.  RE: HTTP Get with Authorization Header
    Posted 05-06-2021 07:53
    Hi James,
    Thanks for the reply.
    Unfortunately I can't guarantee that the @ character won't be in a password so calling a separate function for that. But good to know for future reference!
    I've been trying the JSON object previously and couldn't make it work. Using httpbin.org/get, I can see that although you can change the Content-Type Header data, the Header remains as Content-Type.
    I have managed a work around by fiddling with the asyncHTTP Visual Block XML to allow me to add any headers I want and it works fine.
    Cheers,
    Chris
    Chris Mason
    ES BROADCAST LTD
