  • 1.  STRUCT Array from JSON
    Posted 05-10-2021 14:44
    Hi, me again,
    I have a JSON array that I'm trying to import to a Struct Array that for life of me I cannot get to load into Dashboard.
    It will load other JSON arrays even though several online JSON checkers tell me the array is ok, Dashboard won't bring it into a struct array.
    Using this code borrowed from one of the example panels:
    //load app instance data from file
    function loadappinstancejson()
    function getappjson(resultStr)
    if (resultStr != null)
    var json = JSON.parse(resultStr);
    ogscript.debug("json =" + resultStr)
    var a = null;
    if (Array.isArray(json))
    a = json;
    ogscript.debug("a =" + JSON.stringify(a))
    ogscript.debug("1 =" + JSON.stringify(a[0]))
    ogscript.debug("2 =" + JSON.stringify(a[1]))
    ogscript.debug("3 =" + JSON.stringify(a[2]))
    ogscript.debug("4 =" + JSON.stringify(a[3]))
    else
    a = [];
    a.push(json);
    var apushed = a.push(json)
    ogscript.debug("apushed =" + apushed)
    params.setAllValues('getappinstancesdata', a);
    params.resetAllValues('getappinstancesdata');
    ogscript.asyncPost(params.getValue('getappinstancesurl', 0), null, getappjson)
    When I run this I can see the JSON array items in the debug window and all looks ok, it even briefly builds a Struct_Array in the parameters screen but no actual data seems to make it.
    What am I doing wrong?
    Here is my JSON:
    "id":686114,
    "account_id":13162,
    "tenant_id":0,
    "user_id":14807,
    "is_deleted":0,
    "is_deleted_depend":0,
    "fid":"61e33a0a-3563-451a-81d8-63b5761c6272",
    "name":"",
    "firebaseUrl":"",
    "thumbnail":0,
    "category":0,
    "apptemplate_id":57,
    "apptemplate_version":160,
    "created_at":"2021-04-08T12:58:15.000Z",
    "updated_at":"2021-04-08T12:58:37.000Z",
    "deleted_at":0,
    "is_package":0,
    "support_multipleDBs":0,
    "token":"0R0rZkylFoT0eJJjBf7EBh",
    "last_user_token":"14807",
    "composition_size":2873,
    "flowjob_id":0,
    "onair_url":"",
    "control_url":"",
    "access_token":"0R0rZkylFoT0eJJjBf7EBh",
    "id":470443,
    "account_id":13162,
    "tenant_id":0,
    "user_id":14807,
    "is_deleted":0,
    "fid":"96dfa193-a521-45c6-86d9-fb9b8dc3fbea",
    "name":"Glass - Sports",
    "firebaseUrl":"",
    "thumbnail":"",
    "category":0,
    "apptemplate_version":144,
    "created_at":"2020-10-20T15:27:25.000Z",
    "updated_at":"2021-04-08T12:57:17.000Z",
    "deleted_at":0,
    "is_package":0,
    "token":"69YbOa1iqNTNTA2RgdCbAV",
    "last_user_token":"15641",
    "composition_size":5047,
    "flowjob_id":0,
    "onair_url":"",
    "control_url":"",
    "access_token":"69YbOa1iqNTNTA2RgdCbAV",
    "id":538876,
    "account_id":13162,
    "tenant_id":0,
    "user_id":14807,
    "is_deleted":0,
    "fid":"de7b07fc-5813-4cc5-b8fe-ee3955a55e17",
    "name":"Test 2 app",
    "firebaseUrl":"https://fiery-torch-2122.firebaseio.com/accounts/13162/appinstances/538876",
    "thumbnail":0,
    "category":0,
    "apptemplate_id":85,
    "apptemplate_version":46,
    "created_at":"2021-01-05T17:47:16.000Z",
    "updated_at":"2021-04-08T12:54:58.000Z",
    "deleted_at":0,
    "is_package":0,
    "token":"7465UIdPEIhRF3VkkvehcA",
    "composition_size":2325,
    "flowjob_id":0,
    "onair_url":"",
    "control_url":"",
    "access_token":"7465UIdPEIhRF3VkkvehcA",
    "id":539019,
    "account_id":13162,
    "tenant_id":0,
    "user_id":15641,
    "is_deleted":0,
    "fid":"817664ec-ff49-4fc8-ab9e-a91c863961c5",
    "name":"CM Test app",
    "firebaseUrl":"https://fiery-torch-2122.firebaseio.com/accounts/13162/appinstances/539019",
    "thumbnail":0,
    "category":0,
    "apptemplate_version":150,
    "created_at":"2021-01-05T19:53:52.000Z",
    "updated_at":"2021-01-05T19:55:28.000Z",
    "deleted_at":0,
    "is_package":0,
    "token":"5Gzln2y1L7R7LrVIPb24pX",
    "composition_size":1382,
    "flowjob_id":0,
    "onair_url":"",
    "control_url":"",
    "access_token":"5Gzln2y1L7R7LrVIPb24pX",
    This is the working sample:
    "team":"Eagles",
    "sport":"Flight",
    "players": [
    "Eddie",
    "Sam",
    "Steagle"
    "team":"Dogs",
    "sport":"Fetch",
    "players": [
    "Rover",
    "Fido",
    "Rex"
    "team":"Cats",
    "sport":"Ignoring",
    "players": [
    "Minou",
    "Felix",
    "Garfield"
    "team":"Horses",
    "sport":"Jumping",
    "players": [
    "Secretariat",
    "Seabiscuit",
    "Big Ben"
    Chris
    Chris Mason
    ES BROADCAST LTD
  • 2.  RE: STRUCT Array from JSON
    Posted 06-01-2021 14:34
    Hi Chris,
    You have commas after each key/value pair for access_token which would indicate there is another key/value pair to follow. There is not which is why this is not a valid JSON.
    I removed these commas and then the import worked for me. Please give it a shot and let me know.
    Thanks,
    Dave Sampson
