  • 1.  Display Carbonite media store thumbnail
    Posted 08-03-2020 23:05
    Is it possible to display a MediaStore thumbnail in a Dashboard panel? For example, the currently loaded still?
    Thanks,
    Gene
  • 2.  RE: Display Carbonite media store thumbnail
    Posted 08-17-2020 18:55
    Hi Gene,
    Sorry for the delay in answering this question.   I've been trying to get access to a Carbonite on our network to figure this out.
    I think if you go to the Live Assist panel, and click on the ME you want, and then click on Media, you can see what media is loaded.
    You should be able to drag and drop that into your panel.
    If I go into panel inspector mode (Ctrl I), and then double click on the media 1 box, I see it is OID 0x97E.    So that's another way you can access it.
    Unfortunately, I still don't have access to a live Carbonite, so I could not test it (I have a graphite device file which is not live).   Give it a shot, and if it does not work, let me know and I'll see if I can find a real connection to a Carbonite to test it out.
  • 3.  RE: Display Carbonite media store thumbnail
    Posted 08-18-2020 17:35
    Thanks Ben, dragging it in from Live Assist worked. I was trying from the media manager before which dragged the whole panel in.
