  • 1.  To control BMD Video Router
    Posted 06-04-2021 13:20
    Hi.
    We would like integrate BlackMagic Video Router with DashBoard U in order to control Blackmagic Video Router via Dashboard Panel.
    But, I could not find any example grid to carry out procedure.
    Is there any Dashboard examples I can control Blackmagic Video router via Dashboard U?
    Thanks.
    Shamil Gasim
  • 2.  RE: To control BMD Video Router
    Posted 06-07-2021 07:42
    Here's an example grid file on GitHub that shows you how to get Dashboard to talk to a Blackmagic router: RossDashboardPanels/VideoHub Control.grid at master · josephdadams/RossDashboardPanels (github.com)
    It's a basic example but it does the job, using ogScript to send TCP commands to a Blackmagic router. I recently borrowed the code in this example and adapted it to allow our TV directors to control a Blackmagic router at our facility, and it's working well.
    Orry Verducci
    Broadcast Engineer
    Ideal Shopping Direct Limited
  • 3.  RE: To control BMD Video Router
    Posted 06-07-2021 08:27
    Could you attach the grid file, please?
    Shamil Gasim
  • 4.  RE: To control BMD Video Router
    Posted 06-08-2021 03:46
    Thanks for reply. I have copied all codes into DashBoard, I am new for coding, should I delete <?xml version="1.0" encoding="UTF-8"?>   ?
    Shamil Gasim
  • 5.  RE: To control BMD Video Router
    Posted 06-08-2021 10:31
    Hi Shamil
    If you are editing the file in a text editor (something like Notepad), you would keep the XML declaration in the code you copy/paste.
    If you are using the source tab of DashBoard's OGLML editor, you would paste everything after the XML declaration.
    James Peltzer
