I have learned some of the
nk.doSwitch command in Dashboard to be able to control my
NK Router through scripts in
Dashboard.
If I want to set Destination 41 to Source 15, everything works beautifully (once I figured the numbering scheme).
However, I need to send a source I cannot figure out how to access. It seems that, in this numbering scheme, source 0 is actually the 11th source in the switchboard. I need to access sources 1-10, which align with the defined outputs of our Carbonite. I have tried everything I can think of, including negative numbers which I knew wouldn't work, but gave it the good old college try. I feel this is going to be obvious, but right now it it oblivious to me. This is likely very simple, but I am not seeing it.
Someone please help me out here! Thanks!
Marty
