  • 1.  Receiving HEX strings over TCP
    Posted 11-27-2014 12:44
    Hi all.
    I'm working on a project where I'm trying to interface an audio deck with Dashboard, and even though I've succeded on some parts there are still some issues which I cant manage to get my head around.
    The deck transmitts commands as 16 byte HEX strings over TCP, and this little snippet show me that the memory buffer has received a command, and that there is data available to work on:
    var bytes = event.getBytes(); // (data is beeing parsed further down the code)
    ogscript.debug(bytes);
    This works all fine with a command like this:
    0X 03001102 00000020 10000000 00000000.
    While a message like this: 0X 04001103 00000002 007A0000 00000000, will not be received or recognized.
    Any ideas and hints would be highly appreciated!
  • 2.  RE: Receiving HEX strings over TCP
    Posted 11-27-2014 16:51
    Just want to be clear on this.
    You're saying your command is sending 16-byte HEX Strings over TCP. So, in your message below, you're sending the ASCII Code for '0', not the number 0?
    So, in your above example, you would be encoding 16 bytes of data in 32 bytes of ASCII text?
    If so, when you get your message from your listener (which should have a sync word of `3058` to sync on '0X' and a fixed length delimiter with a length of 32 - assuming no spaces are actually sent), you should be able to get your message as a String with `event.getBytesAsString()` and parse each 2-byte pair as a single byte with `parseInt([two characters from your string], 16);`
    Of course, it's also entirely possible that I misinterpreted your encoding - so feel free to correct me/clarify.
    James
  • 3.  RE: Receiving HEX strings over TCP
    Posted 12-05-2014 07:49
    Hi James.
    Oi. I realize now that the word "String" maybe was not the best.
    What I'm sending is 16 bytes of data as HEX, so no ASCII encoding here, and no sync words.
    A message like this will be accepted - and shown by Dashboard:
    03001102000000201000000000000000
    While a message like this will not:
    0400110300000002007A000000000000
    By using Wireshark I can confirm that the network card receives the command, but it's will not appear in Dashboard.
    Hopefully this will clarify a bit.
    Regards, Ketil
  • 4.  RE: Receiving HEX strings over TCP
    Posted 12-05-2014 14:07
    What are your settings for your listener tag?
  • 5.  RE: Receiving HEX strings over TCP
    Posted 12-05-2014 14:21
    Try a backtick (beside the '1' on a keyboard).
    That will keep the form from hiding your code.
  • 6.  RE: Receiving HEX strings over TCP
    Posted 12-05-2014 14:22
    - Connect as client
    - Delimiter type: Fixed length
    - Delimiter Value: 16 byte pr. message
    Edit: Need to experiment a little how to insert code....
    Best/Ketil.
  • 7.  RE: Receiving HEX strings over TCP
    Posted 12-05-2014 14:35
    DId this work?
  • 8.  RE: Receiving HEX strings over TCP
    Posted 12-05-2014 14:39
    Yup. That should work with the scenario you describe.
    I just created a simple listener:
    if (event.isMessageEvent())
    for (var i = 0; i < bytes.length; i++)
    ogscript.debug('Byte ' + i + ': ' + bytes[i]);
    And then two buttons to send your examples:
    rosstalk.sendAsBytes('localhost', 5445, '03 00 11 02 00 00 00 20 10 00 00 00 00 00 00 00', null);
    and
    rosstalk.sendAsBytes('localhost', 5445, '04 00 11 03 00 00 00 02 00 7A 00 00 00 00 00 00', null);
    Both messages were received and had their bytes written to the debug view.
  • 9.  RE: Receiving HEX strings over TCP
    Posted 12-05-2014 14:45
    Just got your response.
    Here is my same example and a server set up to do the same thing. Once again, 2 messages are received. There must be something else going wrong in your listener.
    if (event.isConnectEvent())
    ogscript.debug('SEND MESSAGE 1');
    this.writeAsBytes('03 00 11 02 00 00 00 20 10 00 00 00 00 00 00 00');
    ogscript.debug('SEND MESSAGE 2');
    this.writeAsBytes('04 00 11 03 00 00 00 02 00 7A 00 00 00 00 00 00');
  • 10.  RE: Receiving HEX strings over TCP
    Posted 12-05-2014 15:29
    Many thanks James.
    I will do some tests during the weekend.
