After upgrading our NLE systems to After Effects CC we are finding that animations rendered as Quicktime Animation aren't being recognized by Blackstorm. Files rendered on After Effects CS6 using the exact same settings are recognized and play normally. Has anyone else encountered or found a solution? Our system format is 1080i, and the only change is After Effects CC - otherwise using the same workflow for the past 2 years.
Josh
