The only XML commands available in the XML file import at this time are: create, delete, creategroup and clear.
You can set up a watch folder in the XPression Preferences which will automatically import the new playlist into the sequencer when the XML file is updated. In the Preferences there are some options to control the behaviour of the XML file import from the watch folder.
