  • 1.  Folders on Blackstorm
    Posted 09-20-2013 11:01
    When I make folders on the media drive on our Blackstorm they do not appear in the Directory window of Media Manager in Dashboard. The only folder appearing is the default folder named Media and the subfolders named with different resoulutions containing files that came with the system.
    I would like to make folders to organise the videoclips I will use if that is possible.
    Anyone knows anything about this?
  • 2.  RE: Folders on Blackstorm
    Posted 09-29-2013 14:52
    I have the same problem. Just the "resolution" folders show up in the Media Folder.
  • 3.  RE: Folders on Blackstorm
    Posted 02-18-2014 11:21
    Any update to this post?
    I am having the same issue.
  • 4.  RE: Folders on Blackstorm
    Posted 02-18-2014 11:57
    Yes
    The answer is that the folders only will show up if there are files in them that Blackstorm accepts as useable for playout - IE right format and audio
    Regards
    Egil
