  • 1.  BlackStorm live video preview
    Posted 04-08-2014 13:32
    I'm new to BlackStorm, but I'm wondering if I'm doing something wrong. When I play a video I don't see the video play on the GUI. The video channels also appear stretched. Am I missing a codec or is their a setting in the video card that would fix that?
    In addition, I'm pretty sure that there is no way to set an attribute for a particular clip. If I have a clip that the audio is a little hot, I would love the ability to bring it down without affecting every clip that I play in that channel.
    Looping would be a plus as well.
    Thanks,
    Scott
  • 2.  RE: BlackStorm live video preview
    Posted 04-11-2014 18:52
    Hi Scott,
    There is no Video Thumbnails -- you need to have monitors and the Video feeds sent to them (or a MV/Quad).
    No you can not adjust the audio per clip (you could always pull the clip off and edit the audio levels). Proper practices with a file based workflow is to always have the Audio set before you transfer the clips.
    Loop is present already. just set the channel to loop.
