The issue with holds is normally things are 1 press, but that makes it a 2 press. I'm essentially using the old workflow, just splitting it into two buttons so I don't have to make that first press during the play every time. In cues out, Out cues in doesn't really work as our replay changes per quarter. The 5 load buttons plus an in and out seems like the best work-around for the cue time.
If the BVS cue time was improved I would be very interested in an update. I worked with Ivan on the phone a bit over a year ago and he was able to get us from 18 frames to 15 after an update. On trucks 8 frames is what I typically need. At double the cue time it really changes how I need to build my show.
Jeff
