Hi Ryan, I will answer your questions to the best of my knowledge. 1. You cannot split protocols. If you're using VDCP for Sony, you cannot do AMP as well for Carbonite, or vice versa, unfortunately. 2. I am not sure about Carbonite supporting setting TC cues. Usually a Carbonite integrated with a Mira or Tria is simply cuing and playing out videos. 3. You can connect to DB using VDCP, with the Mira as a device. We are currently working on a native API DB panel, and that is hoping to be launched in the next couple of months, so keep an eye out for it. Hope this helps.
#Mira
