Hi Chuck,
I tried to reply but not sure if it sent. You can mark cue points using the Abekas OGP gateway on DashBoard, not RossTalk.
Attached is a the Quick Start Guide. There are tons of commands and parameters, and even a palette to create your own panel.
Hope this helps. Thank you.
Marsha Opacic
Sent: 10-17-2021 10:55
Subject: Duet Express send mark cue point in Dashboard
Hello , We just received our Tria Duet Express and all is working well. I have a need where another operator needs to set cue points (Ctrl + `) while recording from a different location through Dashboard. I didn't see this as a Rosstalk command and wonder if this is possible?
Thanks,
Chuck
Chuck Timmons
